  2. Software Development
  3. Modal Pipe Architecture (MPA)
  4. Hires_snapshot snapshot-no-save is saving ?
Scheduled Pinned Locked Moved Modal Pipe Architecture (MPA)
5 Posts 2 Posters 1.3k Views
  • Caio Licínio Vasconcelos PantarottoC Offline
    I believe there is a bug with the command voxl-send-command hires_snapshot snapshot-no-save... when I use it it still saves to the folder :/data/snapshots.. is this the expected behaviour ?
      Im using a Starling drone... and recently updated.
        Okay. I found the problem... its snapshot_no_save (instead of snapshot-no-save)... I believe the website docs and the internal terminal info have to be updated.. Thanks... Im just leaving the topic for people who might have similar issue.
        ModeratorM 1 Reply Last reply
        • Caio Licínio Vasconcelos PantarottoC Caio Licínio Vasconcelos Pantarotto
          @Caio-Licínio-Vasconcelos-Pantarotto said in Hires_snapshot snapshot-no-save is saving ?:
          snapshot-no-save
          Thank you for the feedback, this was fixed in voxl-camera-server 1.8.3
          Caio Licínio Vasconcelos PantarottoC 1 Reply Last reply
          • ModeratorM Moderator
            snapshot-no-save
            @Moderator said in Hires_snapshot snapshot-no-save is saving ?:
            voxl-camera-server
            What is the easiest way to update it ? I looks like apt update is not doing the job right.
