  3. Voxl 2 DFS Server failed
6 Posts 3 Posters 1.2k Views 3 Watching
  • C Offline
    C Offline
    cch
    Hi, I'm using voxl2 SDK 0.9.5. Follow these steps:
    1.Use exit to get out of the shell and adb reboot to restart your VOXL2
    2.Once the device restarts, use adb shell to access the terminal and then use voxl-camera-server to start the camera server manually
    3.In a web browser access VOXL Portal as you have been. You should be able to see the stereo camera output.
    4.In another terminal, use adb shell to access the terminal and then use voxl-dfs-server to launch the DFS Server.
    I can't see 'stereo front disparity', 'stereo front disparity scaled' or 'pointcloud pc' from voxl-portal:
    ![alt text](voxl-portal2.png voxl-portal.png image url)
    Terminal output:
    Terminal 1:
    voxl2:/$ voxl-inspect-services
     docker-autorun       | Disabled  | Not Running |
     docker-daemon        | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  | Not Running |
     voxl-cpu-monitor     | Disabled  | Not Running |
     voxl-dfs-server      |  Enabled  |   Running   |     0.0
     voxl-imu-server      |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  | Disabled  | Not Running |
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             |  Enabled  |   Running   |     0.0
     voxl-qvio-server     | Disabled  | Not Running |
     voxl-remote-id       | Disabled  | Not Running |
     voxl-softap          | Disabled  | Not Running |
     voxl-static-ip       | Disabled  | Not Running |
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-vision-px4      | Disabled  | Not Running |
    voxl2:/$ voxl-camera-server
    WARNING: Camera stereo recieved much newer master than child (33), discarding child and trying again
    Terminal 2:
    system-image: 1.5.5-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   0.9.5
    voxl2:/$ voxl-dfs-server
    min_disparity:   4
    max_disparity:   64
    min_threshold:   10
    cost_threshold:  10
    width:           640
    height:          480
    pc_skip_n_lines: 4
    dfs pair #0
        enable:             1
        input_pipe:         stereo_front
        skip_n_frames:      1
        blur_size:          0
        post_median_size:   0
        intrinsics_file:    /data/modalai/opencv_stereo_front_intrinsics.yml
        extrinsics_file:    /data/modalai/opencv_stereo_front_extrinsics.yml
    dfs pair #1
        enable:             0
        input_pipe:         stereo_rear
        skip_n_frames:      1
        blur_size:          0
        post_median_size:   0
        intrinsics_file:    /data/modalai/opencv_stereo_rear_intrinsics.yml
        extrinsics_file:    /data/modalai/opencv_stereo_rear_extrinsics.yml
    existing instance of voxl-dfs-server found, attempting to stop it
    loading calibration files
    for Pair #0, loaded these lens params:
    f:  508.425964
    cx: 337.120087
    cy: 280.774963
    baseline_m: 0.037456
    initializing dfs module
    opening cameras paused
    client voxl-portal0 connected to ch 1
    client voxl-portal0 connected to ch 0
    client voxl-portal0 connected to ch 2
    Terminal 3:
     voxl-dfs-server      |  Enabled  | Not Running |
     voxl-portal          |  Enabled  |   Running   |    30.0
    • C cch
      Terminal output:
      Terminal 1:
      Terminal 2:
      hw version:   M0054
      voxl-suite:   0.9.5
      min_disparity:   4
      max_disparity:   64
      min_threshold:   10
      cost_threshold:  10
      width:           640
      height:          480
      pc_skip_n_lines: 4
      dfs pair #0
          enable:             1
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
      dfs pair #1
          enable:             0
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
      f:  508.425964
      cx: 337.120087
      cy: 280.774963
      Terminal 3:
      @cch Why are you starting it from the command line in terminal 2? It is already running so you don't need to run it again.
      C 1 Reply Last reply
        C Offline
        C Offline
        cch
        @Eric-Katzfey Thanks. I tried again but got the same result, could you please help me check out if there are other problems? Here are the steps I followed:
        1. power up the voxl2
        2. open up a terminal and check 'voxl-inspect-services':
         voxl-camera-server   |  Enabled  |   Running   |    36.4
        1. open up a web and check the output of voxl-portal:
        2. check 'voxl-inspect-services' again:
         voxl-camera-server   |  Enabled  |   Running   |    47.6
        I'm so confused because there is no error showing up from anywhere.
        • C cch
          @cch What do you see with systemctl status voxl-dfs-server
            C Offline
            C Offline
            cch
            @tom Here are the full outputs:
            hw version:   M0054
            voxl-suite:   0.9.5
             voxl-camera-server   |  Enabled  |   Running   |    55.0
            voxl2:/$ systemctl status voxl-dfs-server
            ● voxl-dfs-server.service - voxl-dfs-server
               Loaded: loaded (/usr/bin/voxl-dfs-server; enabled; vendor preset: enabled)
               Active: active (running) since Thu 2023-11-02 13:19:52 UTC; 18h ago
             Main PID: 1425 (voxl-dfs-server)
                Tasks: 14 (limit: 4915)
               CGroup: /system.slice/voxl-dfs-server.service
                       └─1425 /usr/bin/voxl-dfs-server
            Nov 02 13:19:52 m0054 systemd[1]: Started voxl-dfs-server.
            • C cch
              hw version:   M0054
              voxl-suite:   0.9.5
              C Offline
              C Offline
              cch
              Can anybody find out the problems? Many thanks.
              • C cch referenced this topic on
