    Voxl2 ESC Error
    ESCs
    • A
      AP123
      I have a Voxl 2 with SDK 1.0.0. I'm using a ModalAI 4-in-1 ESC (M0134) which i have connected with a MCBL-00029 to the Voxl. When i CD to /usr/share/modalai/voxl-esc-tools and send command voxl-esc and choose option 2 detect i get this:
      enabling bridge
      detected voxl-px4 is enabled
      Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
      detected voxl-px4 is running, stopping it now
      bridge enabled
      \e[91m[ERROR] No ESCs detected\e[0m
      disabling bridge
      re-enabling voxl-px4
      Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
      restarting voxl-px4
      bridge disabled
      EXITING VOXL-ESC WITH ERROR
      What am i missing? Is the M0134 compatible or do i have to use M0049 or M0117 only?
      I just got the unit brand new last week, do i need to install any drivers?
      All help would be much appreciated.
      Thank You So Much!
      Eric KatzfeyE A 2 Replies Last reply Reply Quote 0
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @AP123
        @AP123 What happens when you use ./voxl-esc-scan.py?
        • A
          AP123 @AP123
          [GCC 8.4.0]
          Found voxl-esc tools bin version: 1.2
          VOXL Platform: M0054
          Detected VOXL2 M0054 or M0104!
          Sending library name request: libslpi_uart_bridge_slpi.so
          Error calling voxl_uart_init
          INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
          INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
          INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
          INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
          INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 38400
          Updated baud rate to 38400
          Segmentation fault
          The M0134 lights do not turn on nor do i hear any beeps, is it defective or is this normal?
          • Eric KatzfeyE
            @AP123 I'm guessing that voxl-px4 is running and the voxl-esc commands are not able to stop it. You can try to do this manually. Run systemctl disable voxl-px4 and then reboot. You should then be able to use the voxl-esc tools. After you are done use systemctl enable voxl-px4 to get voxl-px4 on auto start again.
