  3. Unbrick Voxl2
Unbrick Voxl2
24 Posts 5 Posters 7.4k Views 2 Watching
  • C CJ
    @tom Yes, the QDL is successful.
    And installing the SDK is also successful but it just wait for adb interface to be up, which the usb is still in fastboot mode after power cycle.
    @CJ This is definitely abnormal which makes me think something hardware / power wise is causing the voxl2 to boot directly to fastboot. Your easiest resolution may be to submit an RMA so that you don't risk damaging your board further taking apart the drone
    C 1 Reply Last reply
      C Offline
      C Offline
      ck
      @tom , may I know what is the likely component that might need to replace to resolve this issues as the RMA cost of sending the drone may outweigh the replacement.
      • C ck
        @ck Can't give you an answer as it would require an inspection from our team
        • E Offline
          E Offline
          ErezI
          I had the same problem.
          You can try to transfer to the normal operation (& ADB)
          by:
          fastboot continue
          and disconnect-connect the USB cable in order to enable
          the USB change to ADB.
          Erez
