  2. ESCs
  3. ESC Mini 4 in 1 - params crc
Scheduled Pinned Locked Moved ESCs
6 Posts 2 Posters 897 Views 1 Watching
  • 0 Offline
    0 Offline
    0x45
    I'm currently working setting up the VOXL ESC Mini 4-in-1 with Built-in Power Module (M0129).
    Following the steps on this link:
    https://docs.modalai.com/modal-esc-v2-manual/
    I've updated the firmware using the binary found in:
    /voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC4_c0bf9200.bin
    I've verified that worked with the voxl-esc-scan.py file
    Problem:
    I uploaded the esc_params_generic_m0129.xml using voxl-esc-upload-params.py. Then I run a voxl-esc-verify-params.py and get the following output
    I haven't modified the parameters file and would like to know if the generic params is missing a parameter that needs to be updated? Also is there a source where the developers can see the necessary parameters needed to configure this esc board?
    Let me know if there is other information you need from me to help troubleshoot.
    • 0 Offline
      0 Offline
      0x45
      Just wanted to follow up if anyone was able to recreate this issue or can see something that might be off with my setup steps?
      • 0 0x45
        @0x45 ,
        Sorry about that. you caught a bug in our release candidate firmware. Please downgrade to firmware version 38, which you can find here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/v1.2.3/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_38_83faccfa.bin
        You can just used voxl-esc-upload-firmware-all.sh script and point it to the v0_38 firmware.
        The issue is only in the firmware sending back the params for verification, there should not be any other issue. There is no issue in the param file itself. we will fix ASAP.
        Thank you
          @0x45 ,
          Thank you
          The issue should be fixed now in the firmware version 39_RC5 : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev/voxl-esc-tools/firmware/
          You can either use the stable v38 firmware i mentioned before or update to 39_RC5
          0 1 Reply Last reply
            0 Offline
            0 Offline
            0x45
            @Alex-Kushleyev
            Appreciate all the help! I can confirm the new firmware verifies the parameters successfully.
            • 0 0x45
              @Alex-Kushleyev
              @0x45, Great to hear! Sorry again about the bug and thank you for reporting it.
