  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. voxl2 upgrading to sdk 1.0 problem
voxl2sdk1.0sda8
12 Posts 2 Posters 3.9k Views 2 Watching
  • E Offline
    E Offline
    ErezI
    We have a problem in one of our voxl2 board (sentinel type)
    after burning sdk version 1.0 (1.6.2) on it.
    (/data/voxl2_SDK_1.0.0$ sudo ./install.sh -n --sku MRB-D0006-4-V1-C11)
    The voxl-px4 can not run because of /data (sda8) does not idenified as ext4 fs type.
    Trying to revive it and return to version 0.9.5, had the same resaults.
    I attached a dmesg log.
    Can you check it, and help us revive the voxl-px4 on this board?
    Erez
    boot dmesg -Hkw log:
    [ +0.015588] zram0: detected capacity change from 0 to 4021985280
    [ +0.001568] f_cdev_alloc: port_name:at_usb1 (fffffffcd1399400) portno:(1)
    [ +0.012045] Adding 3927716k swap on /dev/zram0. Priority:10 extents:1 across:3927716k SS
    [ +0.014851] gsi_set_inst_name: prot_id = 2, prev inst do not freed yet
    [ +0.003920] gsi_set_inst_name: failed to find prot id for gps instance
    [ +0.001958] subsys-pil-tz 8300000.qcom,turing: cdsp: Brought out of reset
    [ +0.009401] subsys-pil-tz 8300000.qcom,turing: Subsystem error monitoring/handling services are up
    [ +0.000056] subsys-pil-tz 8300000.qcom,turing: cdsp: Power/Clock ready interrupt received
    [ +0.001711] -200258072:Entered
    [ +0.000077] adsprpc: fastrpc_restart_notifier_cb: cdsp subsystem is up
    [ +0.002126] -200258072:SMD QRTR driver probed
    [ +0.004846] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for cdsp
    [ +0.002018] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and cdsp's SSCTL service
    [ +0.000206] coresight-remote-etm soc:turing_etm0: Connection established between QMI handle and 13 service
    [ +0.005799] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ +0.000159] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 5
    [ +0.082869] configfs-gadget a600000.dwc3: failed to start g1: -19
    [ +0.020699] subsys-restart: __subsystem_get(): Changing subsys fw_name to slpi
    [ +0.001029] servloc: service_locator_new_server: Connection established with the Service locator
    [ +0.000015] servloc: init_service_locator: Service locator initialized
    [ +0.000567] adsprpc: fastrpc_get_service_location_notify: PDR notifier for adsp registered for msm/adsp/audio_pd (audio_pdr_adsprpc)
    [ +0.000001] adsprpc: fastrpc_get_service_location_notify: audio_pdr_adsprpc (msm/adsp/audio_pd) PDR service for adsp is uninitialized
    [ +0.000012] audio_notifer_reg_service: service PDR_ADSP is in use
    [ +0.002284] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
    [ +0.014853] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
    [ +0.010065] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ +0.000002] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ +0.000034] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
    [ +0.009388] read descriptors
    [ +0.000027] read strings
    [ +0.000238] android_work: did not send uevent (0 0 0000000000000000)
    [ +0.084157] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
    [ +0.005845] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
    [ +0.000032] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
    [ +0.017746] QSEECOM: qseecom_load_app: App (haventkn) does'nt exist, loading apps for first time
    [ +0.005494] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base: pK-error, M0_Q1 NACK ERROR: 0x10000000
    [ +0.000040] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0xc0:
    [ +0.000007] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [ +0.000004] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [ +0.000005] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
    [ +0.000096] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
    [ +0.004147] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
    [ +0.006671] QSEECOM: qseecom_load_app: App with id 4 (haventkn) now loaded
    [ +0.001901] IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ +0.012852] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
    [ +0.000026] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
    [ +0.005672] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
    [ +0.001570] -200258072:Entered
    [ +0.000371] -200258072:SMD QRTR driver probed
    [ +0.000625] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
    [ +0.000367] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
    [ +0.000062] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
    [ +0.006694] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
    [ +0.000060] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
    [ +0.001772] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
    [ +0.014729] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 731 [Applying Alternative Address] : Sensor Index : 3612688564
    [ +0.000005] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 732 [Applying Alternative Address] : Slave Address : 0xE2
    [ +0.000002] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 733 [Applying Alternative Address] : Slave sensor id: 0x7750
    [ +0.000002] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 734 [Applying Alternative Address] : cci_client sid : 0x71
    [ +0.000146] CAM_ERR: CAM-CCI: cam_cci_irq: 232 Base: pK-error, M0_Q0 NACK ERROR: 0x8000000
    [ +0.000021] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
    [ +0.000003] CAM_ERR: CAM-CCI: cam_cci_transfer_end: 345 failed rc -22
    [ +0.000003] CAM_ERR: CAM-CCI: cam_cci_data_queue: 870 Slave: 0xe0 failed rc -22
    [ +0.000002] CAM_ERR: CAM-CCI: cam_cci_i2c_write: 1450 failed rc: -22
    [ +0.000004] CAM_ERR: CAM-SENSOR: cam_cci_i2c_write_table_cmd: 123 Failed rc = -22
    [ +0.000002] CAM_ERR: CAM-SENSOR: cam_sensor_set_alt_id: 768 [Applying Alternative Address] : Probe : camera_io_dev_write failed: rc=-22
    [ +0.000130] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base: pK-error, M0_Q1 NACK ERROR: 0x10000000
    [ +0.000070] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0xe0:
    [ +0.000004] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [ +0.000002] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [ +0.000002] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
    [ +0.000056] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
    [ +0.004101] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
    [ +0.031002] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
    [ +0.000075] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
    [ +0.022008] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 731 [Applying Alternative Address] : Sensor Index : 3612672180
    [ +0.000005] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 732 [Applying Alternative Address] : Slave Address : 0xE4
    [ +0.000002] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 734 [Applying Alternative Address] : cci_client sid : 0x72
    [ +0.000147] CAM_ERR: CAM-CCI: cam_cci_irq: 258 Base: pK-error, M1_Q0 NACK ERROR: 0x20000000
    [ +0.000025] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
    [ +0.000004] CAM_ERR: CAM-CCI: cam_cci_transfer_end: 345 failed rc -22
    [ +0.000003] CAM_ERR: CAM-CCI: cam_cci_i2c_write: 1450 failed rc: -22
    [ +0.000003] CAM_ERR: CAM-SENSOR: cam_cci_i2c_write_table_cmd: 123 Failed rc = -22
    [ +0.000003] CAM_ERR: CAM-SENSOR: cam_sensor_set_alt_id: 768 [Applying Alternative Address] : Probe : camera_io_dev_write failed: rc=-22
    [ +0.000130] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base: pK-error, M1_Q1 NACK ERROR: 0x40000000
    [ +0.000031] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0xe0:
    [ +0.000004] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
    [ +0.000082] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
    [ +0.003500] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
    [ +0.000014] CAM_INFO: CAM: cam_res_mgr_shared_pinctrl_put: 270 Need hold put this pinctrl
    [ +0.018390] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000657] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.007537] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [ +0.000197] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [ +0.000053] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [ +0.009259] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001178] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.004875] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000541] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000298] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base: pK-error, M1_Q1 NACK ERROR: 0x40000000
    [ +0.000027] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x20:
    [ +0.000003] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [ +0.000003] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [ +0.000003] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x214:
    [ +0.000080] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [ +0.000014] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001018] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000210] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000780] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002084] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [ +0.000061] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [ +0.000273] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.007527] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002220] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000497] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000329] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000043] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002493] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000205] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001700] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002792] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000784] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002053] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001394] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.005989] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000031] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000709] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000699] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001063] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.60
    [ +0.000012] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000058] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.79
    [ +0.000340] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000765] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000912] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000111] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000127] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000387] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000125] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000021] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001907] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000110] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000706] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001608] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001225] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000075] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001025] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002104] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001236] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000317] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000594] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000016] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000015] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000958] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000154] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000670] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000559] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000052] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000514] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000447] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000999] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000439] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000030] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.001282] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.000164] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ +0.002412] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 731 [Applying Alternative Address] : Sensor Index : 3612995764
    [ +0.000004] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 732 [Applying Alternative Address] : Slave Address : 0xE2
    [ +0.000016] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
    [ +0.000004] CAM_ERR: CAM-CCI: cam_cci_data_queue: 870 Slave: 0xe0 failed rc -22
    [ +0.000038] CAM_ERR: CAM-CCI: cam_cci_read: 1340 read_words = 0, exp words = 1
    [ +0.000080] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.79
    [ +0.000006] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base: pK-error, M1_Q1 NACK ERROR: 0x40000000
    [ +0.003381] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.60
    [ +0.031941] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.60
    [ +0.000212] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.79
    [ +0.024944] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 731 [Applying Alternative Address] : Sensor Index : 3612983476
    [ +0.000017] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 732 [Applying Alternative Address] : Slave Address : 0xE4
    [ +0.000014] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 733 [Applying Alternative Address] : Slave sensor id: 0x7750
    [ +0.000012] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 734 [Applying Alternative Address] : cci_client sid : 0x72
    [ +0.000191] CAM_ERR: CAM-CCI: cam_cci_irq: 258 Base: pK-error, M1_Q0 NACK ERROR: 0x20000000
    [ +0.000074] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
    [ +0.000014] CAM_ERR: CAM-CCI: cam_cci_transfer_end: 345 failed rc -22
    [ +0.000014] CAM_ERR: CAM-CCI: cam_cci_data_queue: 870 Slave: 0xe0 failed rc -22
    [ +0.000012] CAM_ERR: CAM-CCI: cam_cci_i2c_write: 1450 failed rc: -22
    [ +0.000015] CAM_ERR: CAM-SENSOR: cam_cci_i2c_write_table_cmd: 123 Failed rc = -22
    [ +0.000013] CAM_ERR: CAM-SENSOR: cam_sensor_set_alt_id: 768 [Applying Alternative Address] : Probe : camera_io_dev_write failed: rc=-22
    [ +0.000131] CAM_ERR: CAM-CCI: cam_cci_read: 1340 read_words = 0, exp words = 1
    [ +0.000057] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base: pK-error, M1_Q1 NACK ERROR: 0x40000000
    [ +0.000020] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [ +0.000019] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [ +0.000024] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
    [ +0.000157] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.79
    [ +0.003854] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.60
    [ +0.000058] CAM_INFO: CAM: cam_res_mgr_shared_pinctrl_put: 270 Need hold put this pinctrl
    [ +0.057101] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
    [ +0.294586] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ +0.003952] r8152 1-1.2:1.0 eth0: carrier on
    [ +0.143434] spi_geni 98c000.spi: tx_fifo 16 rx_fifo 16 tx_width 32
    [ +10.306510] usb 1-1.1: new high-speed USB device number 4 using xhci-hcd
    [ +0.108414] usb 1-1.1: config 1 has an invalid interface number: 8 but max is 5
    [ +0.000021] usb 1-1.1: config 1 has an invalid interface number: 19 but max is 5
    [ +0.000018] usb 1-1.1: config 1 has an invalid interface number: 20 but max is 5
    [ +0.000016] usb 1-1.1: config 1 has an invalid interface number: 20 but max is 5
    [ +0.000017] usb 1-1.1: config 1 has no interface number 1
    [ +0.000015] usb 1-1.1: config 1 has no interface number 4
    [ +0.000013] usb 1-1.1: config 1 has no interface number 5
    [ +0.008274] usb 1-1.1: New USB device found, idVendor=1199, idProduct=68c0, bcdDevice= 3.18
    [ +0.000022] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ +0.000016] usb 1-1.1: Product: Sierra Wireless WP7607
    [ +0.000016] usb 1-1.1: Manufacturer: Sierra Wireless, Incorporated
    [ +0.000015] usb 1-1.1: SerialNumber: V320223141111020
    [ +0.168977] qcserial 1-1.1:1.0: Qualcomm USB modem converter detected
    [ +0.000877] usb 1-1.1: Qualcomm USB modem converter now attached to ttyUSB0
    [ +0.056523] qcserial 1-1.1:1.2: Qualcomm USB modem converter detected
    [ +0.002561] usb 1-1.1: Qualcomm USB modem converter now attached to ttyUSB1
    [ +0.061434] qcserial 1-1.1:1.3: Qualcomm USB modem converter detected
    [ +0.001875] usb 1-1.1: Qualcomm USB modem converter now attached to ttyUSB2
    [ +0.071546] qmi_wwan 1-1.1:1.8: cdc-wdm0: USB WDM device
    [ +0.013495] qmi_wwan 1-1.1:1.8 wwan0: register 'qmi_wwan' at usb-xhci-hcd.0.auto-1.1, WWAN/QMI device, 5a:bf:8d:37:bf:0d
    [ +0.006921] cdc_ether 1-1.1:1.19 usb0: register 'cdc_ether' at usb-xhci-hcd.0.auto-1.1, CDC Ethernet Device, 9e:23:ad:49:ef:1c
    [ +1.289421] devfreq-qcom-fw 18590000.qcom,devfreq-l3:qcom,cdsp-cdsp-l3-lat: Successfully started CDSP L3 governor
    [ +15.046765] usb30_prim_gdsc: disabling
    [ +0.000125] vdd_tof: disabling
    [ +0.000004] vdd_hap_boost: disabling
    • E ErezI
      Erez
      @ErezI said in voxl2 upgrading to sdk 1.0 problem:
      Where are you seeing that error?
      E 1 Reply Last reply
        E Offline
        E Offline
        ErezI
        @tom
        Hi Tom
        I notice this issue on the journalctl -f log,
        and by using systemctl status voxl-px4
        Erez
        • E ErezI
          @tom
          Hi Tom
          Erez
          @ErezI Could you post the output of journalctl -u voxl-px4 when it crashes?
            E Offline
            E Offline
            ErezI
            1st part
            Booting Linux on physical CPU 0x0000000000 [0x51df805e]
            Linux version 4.19.125 (oe-user@oe-host) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04), GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023
            Machine model: Qualcomm Technologies, Inc. kona v2.1 IOT RB5
            Memory limit set/overridden to 6072MB
            OF: reserved mem: OVERLAP DETECTED!
            disp_rdump_region@9c000000 (0x000000009c000000--0x000000009c800000) overlaps with cont_splash_region@9c000000 (0x000000009c000000--0x000000009e300000)
            Reserved memory: created CMA memory pool at 0x00000000fe800000, size 20 MiB
            OF: reserved mem: initialized node qseecom_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000fc000000, size 40 MiB
            OF: reserved mem: initialized node mem_dump_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000f1c00000, size 164 MiB
            OF: reserved mem: initialized node secure_display_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000f0800000, size 20 MiB
            OF: reserved mem: initialized node cnss_wlan_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000efc00000, size 12 MiB
            OF: reserved mem: initialized node adsp_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000edc00000, size 32 MiB
            OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
            Reserved memory: created DMA memory pool at 0x00000000ffc00000, size 0 MiB
            OF: reserved mem: initialized node mailbox_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000ecc00000, size 16 MiB
            OF: reserved mem: initialized node user_contig_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000ebc00000, size 16 MiB
            OF: reserved mem: initialized node qseecom_ta_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000eb800000, size 4 MiB
            OF: reserved mem: initialized node cdsp_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000ea800000, size 16 MiB
            OF: reserved mem: initialized node sp_region, compatible id shared-dma-pool
            Reserved memory: created CMA memory pool at 0x00000000ea000000, size 8 MiB
            OF: reserved mem: initialized node sdsp_region, compatible id shared-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086200000, size 5 MiB
            OF: reserved mem: initialized node pil_camera_region@86200000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086700000, size 1 MiB
            OF: reserved mem: initialized node pil_wlan_fw_region@86700000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086800000, size 0 MiB
            OF: reserved mem: initialized node pil_ipa_fw_region@86800000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086810000, size 0 MiB
            OF: reserved mem: initialized node pil_ipa_gsi_region@86810000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x000000008681a000, size 0 MiB
            OF: reserved mem: initialized node pil_gpu_region@8681a000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086900000, size 5 MiB
            OF: reserved mem: initialized node pil_npu_region@86900000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000086e00000, size 5 MiB
            OF: reserved mem: initialized node pil_video_region@86e00000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000087300000, size 5 MiB
            OF: reserved mem: initialized node pil_cvp_region@87300000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000087800000, size 20 MiB
            OF: reserved mem: initialized node pil_cdsp_region@87800000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x0000000088c00000, size 26 MiB
            OF: reserved mem: initialized node pil_slpi_region@88c00000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x000000008a600000, size 24 MiB
            OF: reserved mem: initialized node pil_adsp_region@8a600000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x000000008be00000, size 1 MiB
            OF: reserved mem: initialized node pil_spss_region@8be00000, compatible id removed-dma-pool
            Removed memory: created DMA memory pool at 0x000000008bf00000, size 70 MiB
            OF: reserved mem: initialized node cdsp_secure_heap@8bf00000, compatible id removed-dma-pool
            On node 0 totalpages: 1489220
            Normal zone: 24552 pages used for memmap
            Normal zone: 0 pages reserved
            Normal zone: 1489220 pages, LIFO batch:63
            psci: probing for conduit method from DT.
            psci: PSCIv1.1 detected in firmware.
            psci: Using standard PSCI v0.2 function IDs
            psci: MIGRATE_INFO_TYPE not supported.
            psci: SMC Calling Convention v1.1
            random: fast init done
            percpu: Embedded 24 pages/cpu s61336 r8192 d28776 u98304
            pcpu-alloc: s61336 r8192 d28776 u98304 alloc=24*4096
            pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
            Detected VIPT I-cache on CPU0
            CPU features: kernel page table isolation disabled by kernel configuration
            CPU features: detected: Speculative Store Bypassing Safe (SSBS)
            Built 1 zonelists, mobility grouping on. Total pages: 1464668
            Kernel command line: rcupdate.rcu_expedited=1 rcu_nocbs=0-7 kpti=off noinitrd earlycon=msm_geni_serial,0xa90000 androidboot.hardware=qcom androidboot.console=ttyMSM0 androidboot.memcg=1 lpm_levels.sleep_disabled=1 video=vfb:640x400,bpp=32,memsize=3072000 msm_rtb.filter=0x237 service_locator.enable=1 androidboot.usbcontroller=a600000.dwc3 swiotlb=2048 loop.max_part=7 cgroup.memory=nokmem,nosocket reboot=panic_warm net.ifnames=0 apparmor=1 security=apparmor root=/dev/sda9 androidboot.bootdevice=1d84000.ufshc androidboot.serialno=ef9d140b androidboot.baseband=apq msm_drm.dsi_display0=qcom,mdss_dsi_ext_bridge_4k_video: systemd.setenv="SLOT_SUFFIX=_a" skip_initramfs rootwait rw init=/sbin/init
            log_buf_len individual max cpu contribution: 131072 bytes
            log_buf_len total cpu_extra contributions: 917504 bytes
            log_buf_len min size: 131072 bytes
            log_buf_len: 1048576 bytes
            early log buf free: 123612(94%)
            Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
            Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
            mem auto-init: stack:off, heap alloc:off, heap free:off
            Memory: 5396816K/5956880K available (22014K kernel code, 2132K rwdata, 10504K rodata, 4096K init, 7919K bss, 203712K reserved, 356352K cma-reserved)
            random: random: get_random_u64 called from __kmem_cache_create+0x34/0x470 with crng_init=1
            SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
            rcu: Preemptible hierarchical RCU implementation.
            rcu: RCU dyntick-idle grace-period acceleration is enabled.
            All grace periods are expedited (rcu_expedited).
            Tasks RCU enabled.
            NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
            GICv3: Distributor has no Range Selector support
            GICv3: no VLPI support, no direct LPI support
            ITS: No ITS available, not enabling LPIs
            rcu: Offload RCU callbacks from CPUs: 0-7.
            Successfully registered dummy reset controller for cpucc_clocks
            Successfully registered dummy clock controller for cpucc_clocks
            arch_timer: CPU0: Trapping CNTVCT access
            arch_timer: cp15 and mmio timer(s) running at 19.20MHz (virt/virt).
            clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
            sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
            clocksource: Switched to clocksource arch_sys_counter
            Console: colour dummy device 80x25
            console [tty0] enabled
            Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
            pid_max: default: 32768 minimum: 301
            Security Framework initialized
            AppArmor: AppArmor initialized
            Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
            Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
            ASID allocator initialised with 65536 entries
            rcu: Hierarchical SRCU implementation.
            scm_mem_protection_init: SCM call failed
            shmbridge is enabled
            smp: Bringing up secondary CPUs ...
            Detected VIPT I-cache on CPU1
            arch_timer: CPU1: Trapping CNTVCT access
            CPU1: Booted secondary processor 0x0000000100 [0x51df805e]
            Detected VIPT I-cache on CPU2
            arch_timer: CPU2: Trapping CNTVCT access
            CPU2: Booted secondary processor 0x0000000200 [0x51df805e]
            Detected VIPT I-cache on CPU3
            arch_timer: CPU3: Trapping CNTVCT access
            CPU3: Booted secondary processor 0x0000000300 [0x51df805e]
            CPU features: enabling workaround for Mismatched cache type
            CPU features: enabling workaround for ARM erratum 1542418
            CPU features: detected: Hardware dirty bit management
            Detected PIPT I-cache on CPU4
            CPU features: Unsupported CPU feature variation detected.
            arch_timer: CPU4: Trapping CNTVCT access
            CPU4: Booted secondary processor 0x0000000400 [0x411fd0d0]
            Detected PIPT I-cache on CPU5
            arch_timer: CPU5: Trapping CNTVCT access
            CPU5: Booted secondary processor 0x0000000500 [0x411fd0d0]
            Detected PIPT I-cache on CPU6
            arch_timer: CPU6: Trapping CNTVCT access
            CPU6: Booted secondary processor 0x0000000600 [0x411fd0d0]
            Detected PIPT I-cache on CPU7
            arch_timer: CPU7: Trapping CNTVCT access
            CPU7: Booted secondary processor 0x0000000700 [0x411fd0d0]
            smp: Brought up 1 node, 8 CPUs
            SMP: Total of 8 processors activated.
            CPU features: detected: GIC system register CPU interface
            CPU features: detected: Privileged Access Never
            CPU features: detected: LSE atomic instructions
            CPU features: detected: User Access Override
            CPU features: detected: 32-bit EL0 Support
            CPU features: detected: RAS Extension Support
            CPU: All CPU(s) started at EL1
            alternatives: patching kernel code
            devtmpfs: initialized
            Registered cp15_barrier emulation handler
            Registered setend emulation handler
            clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
            futex hash table entries: 2048 (order: 5, 131072 bytes)
            xor: measuring software checksum speed
            8regs : 4204.000 MB/sec
            8regs_prefetch: 3838.000 MB/sec
            32regs : 5414.000 MB/sec
            32regs_prefetch: 4909.000 MB/sec
            xor: using function: 32regs (5414.000 MB/sec)
            pinctrl core: initialized pinctrl subsystem
            ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
            ** IOMMU DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
            ** This means that this kernel is built to expose internal **
            ** IOMMU data structures, which may compromise security on **
            ** your system. **
            ** If you see this message and you are not debugging the **
            ** kernel, report this immediately to your vendor! **
            NET: Registered protocol family 16
            schedtune: configured to support 6 boost groups
            audit: initializing netlink subsys (disabled)
            audit: type=2000 audit(0.303:1): state=initialized audit_enabled=0 res=1
            cpuidle: using governor menu
            cpuidle: using governor qcom
            NET: Registered protocol family 42
            hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
            DMA: preallocated 256 KiB pool for atomic allocations
            msm_watchdog 17c10000.qcom,wdt: wdog absent resource not present
            msm_watchdog 17c10000.qcom,wdt: MSM Watchdog Initialized
            Unable to find DT property: qcom,msm-imem-download_mode
            Unable to find DT property: qcom,msm-imem-emergency_download_mode
            msm-dcc 1023000.dcc_v2: DCC list passed 3
            msm-dcc 1023000.dcc_v2: All values written to enable.
            msm-dcc 1023000.dcc_v2: DCC list passed 6
            msm-dcc 1023000.dcc_v2: DCC list passed 7
            msm-dcc 1023000.dcc_v2: Failed to add DCC data in Minidump
            platform 82400000.qseecom: assigned reserved memory node qseecom_region
            sps:sps is ready.
            spmi spmi-0: PMIC arbiter version v5 (0x50010000)
            pm8150a_s3_mmcx_sup_level: regulator get failed, ret=-517
            pm8150_s3_level: supplied by pm8150a_s3_level
            pm8150_s3_level_ao: supplied by pm8150a_s3_level_ao
            pm8150a_s3_mmcx_sup_level: supplied by pm8150_s3_mmcx_sup_level
            oledb: Bringing 0uV into 4925000-4925000uV
            ab: Bringing 0uV into 4600000-4600000uV
            ibb: Bringing 0uV into 800000-800000uV
            pm8150a_s4_level: supplied by pm8150a_s3_mmcx_sup_level
            spmi spmi-0: pmic_arb_wait_for_done: transaction failed (0x3)
            pm8150a_s4_level_ao: supplied by pm8150a_s3_level_ao
            platform soc:qcom,ipa_fws: assigned reserved memory node pil_ipa_gsi_region@86810000
            platform soc:qcom,ipa_uc: assigned reserved memory node pil_ipa_fw_region@86800000
            platform 17300000.qcom,lpass: assigned reserved memory node pil_adsp_region@8a600000
            platform 8300000.qcom,turing: assigned reserved memory node pil_cdsp_region@87800000
            platform aab0000.qcom,venus: assigned reserved memory node pil_video_region@86e00000
            platform 188101c.qcom,spss: assigned reserved memory node pil_spss_region@8be00000
            platform abb0000.qcom,cvpss: assigned reserved memory node pil_cvp_region@87300000
            platform 9800000.qcom,npu: assigned reserved memory node pil_npu_region@86900000
            platform soc:qcom,msm-adsprpc-mem: assigned reserved memory node adsp_region
            platform soc:mem_dump: assigned reserved memory node mem_dump_region
            MSM Memory Dump base table set up
            MSM Memory Dump apps data table set up
            platform 5c00000.qcom,ssc: assigned reserved memory node pil_slpi_region@88c00000
            platform 88a7000.msm_tspp: assigned reserved memory node qseecom_region
            cryptd: max_cpu_qlen set to 1000
            raid6: int64x1 gen() 987 MB/s
            raid6: int64x1 xor() 541 MB/s
            raid6: int64x2 gen() 1539 MB/s
            raid6: int64x2 xor() 858 MB/s
            raid6: int64x4 gen() 1999 MB/s
            raid6: int64x4 xor() 1090 MB/s
            raid6: int64x8 gen() 2057 MB/s
            raid6: int64x8 xor() 1163 MB/s
            raid6: neonx1 gen() 2333 MB/s
            raid6: neonx1 xor() 2258 MB/s
            raid6: neonx2 gen() 2935 MB/s
            raid6: neonx2 xor() 2616 MB/s
            raid6: neonx4 gen() 3330 MB/s
            raid6: neonx4 xor() 2889 MB/s
            raid6: neonx8 gen() 3341 MB/s
            raid6: neonx8 xor() 2794 MB/s
            raid6: using algorithm neonx8 gen() 3341 MB/s
            raid6: .... xor() 2794 MB/s, rmw enabled
            raid6: using neon recovery algorithm
            vServices Framework 1.0
            gdsc ad07004.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad07004.qcom,gdsc: Dropping the link to regulator.34
            gdsc ad0a004.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad0a004.qcom,gdsc: Dropping the link to regulator.34
            gdsc ad0b004.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad0b004.qcom,gdsc: Dropping the link to regulator.34
            gdsc ad08004.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad08004.qcom,gdsc: Dropping the link to regulator.34
            gdsc ad09004.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad09004.qcom,gdsc: Dropping the link to regulator.34
            gdsc ad0c144.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc ad0c144.qcom,gdsc: Dropping the link to regulator.34
            gdsc af03000.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc af03000.qcom,gdsc: Dropping the link to regulator.34
            gdsc 3d9106c.qcom,gdsc: Linked as a consumer to regulator.4
            gpu_cx_gdsc: supplied by pm8150_s3_level
            gdsc 3d9100c.qcom,gdsc: Linked as a consumer to regulator.33
            gpu_gx_gdsc: supplied by pm8150a_s1_level
            gdsc abf0d18.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc abf0d18.qcom,gdsc: Dropping the link to regulator.34
            gdsc abf0bf8.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc abf0bf8.qcom,gdsc: Dropping the link to regulator.34
            gdsc abf0d98.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc abf0d98.qcom,gdsc: Dropping the link to regulator.34
            gdsc abf0c98.qcom,gdsc: Linked as a consumer to regulator.34
            gdsc abf0c98.qcom,gdsc: Dropping the link to regulator.34
            qmp-aop-clk soc:qcom,aopclk: Registered clocks with AOP
            gcc-kona 100000.qcom,gcc: Linked as a consumer to regulator.34
            gcc-kona 100000.qcom,gcc: Linked as a consumer to regulator.4
            gcc-kona 100000.qcom,gcc: Linked as a consumer to regulator.5
            gcc-kona 100000.qcom,gcc: Registered GCC clocks
            gpu_cc-kona 3d90000.qcom,gpucc: Linked as a consumer to regulator.4
            gpu_cc-kona 3d90000.qcom,gpucc: Linked as a consumer to regulator.1
            gpu_cc-kona 3d90000.qcom,gpucc: Registered GPU CC clocks
            npu_cc-kona 9980000.qcom,npucc: Linked as a consumer to regulator.4
            npu_cc-kona 9980000.qcom,npucc: Registered NPU_CC clocks
            video_cc-kona abf0000.qcom,videocc: Linked as a consumer to regulator.1
            video_cc-kona abf0000.qcom,videocc: Linked as a consumer to regulator.34
            AXI: msm_bus_scale_register_client(): msm_bus_scale_register_client: Bus driver not ready.
            video_cc-kona abf0000.qcom,videocc: Unable to register for bw voting
            video_cc-kona abf0000.qcom,videocc: Dropping the link to regulator.34
            video_cc-kona abf0000.qcom,videocc: Dropping the link to regulator.1
            Minidump: Enabled with max number of regions 200
            KPI: Bootloader start count = 82071
            KPI: Bootloader end count = 100195
            KPI: Bootloader display count = 2012446719
            KPI: Bootloader load kernel count = 606
            KPI: Kernel MPM timestamp = 160349
            KPI: Kernel MPM Clock frequency = 32768
            socinfo_print: v0.15, id=455, ver=2.1, raw_id=346, raw_ver=0, hw_plat=11, hw_plat_ver=65536
            accessory_chip=0, hw_plat_subtype=3, pmic_model=65566, pmic_die_revision=196608 foundry_id=1 serial_number=1868363642 num_pmics=5 chip_family=0x5d raw_device_family=0x6 raw_device_number=0x8 nproduct_id=0x412 num_clusters=0x1 ncluster_array_offset=0xb0 num_defective_parts=0xc ndefective_parts_array_offset=0xb4 nmodem_supported=0x0
            msm_bus_fabric_rpmh_init_driver
            msm_bus: Probe started
            msm_bus_device 16e0000.ad-hoc-bus: Bus type is missing
            msm_bus: DT Parsing complete
            msm_bus_fab_init_noc_ops: Invalid Bus type
            Built 1 zonelists, mobility grouping on. Total pages: 1433271
            mem-offline: Added memory blocks ranging from mem16 - mem19
            arm-smmu 3da0000.kgsl-smmu: Linked as a consumer to regulator.72
            arm-smmu 3da0000.kgsl-smmu: non-coherent table walk
            arm-smmu 3da0000.kgsl-smmu: (IDR0.CTTW overridden by FW configuration)
            arm-smmu 3da0000.kgsl-smmu: stream matching with 6 register groups
            register_client_adhoc:find path.src 161 dest 627
            register_client_adhoc:Client handle 1 apps_smmu
            arm-smmu 15000000.apps-smmu: non-coherent table walk
            arm-smmu 15000000.apps-smmu: (IDR0.CTTW overridden by FW configuration)
            arm-smmu 15000000.apps-smmu: stream matching with 87 register groups
            register_client_adhoc:Client handle 2 apps_smmu
            register_client_adhoc:Client handle 3 apps_smmu
            qsmmuv500-tbu 1518d000.mnoc_hf_0_tbu: Linked as a consumer to regulator.68
            register_client_adhoc:find path.src 22 dest 773
            register_client_adhoc:Client handle 4 mnoc_hf_0_tbu
            qsmmuv500-tbu 15191000.mnoc_hf_1_tbu: Linked as a consumer to regulator.69
            register_client_adhoc:Client handle 5 mnoc_hf_1_tbu
            register_client_adhoc:find path.src 154 dest 10070
            register_client_adhoc:Client handle 6 apps_smmu
            register_client_adhoc:Client handle 7 apps_smmu
            register_client_adhoc:Client handle 8 apps_smmu
            register_client_adhoc:Client handle 9 apps_smmu
            qsmmuv500-tbu 151a5000.mnoc_sf_0_tbu: Linked as a consumer to regulator.70
            register_client_adhoc:find path.src 137 dest 772
            register_client_adhoc:Client handle 10 mnoc_sf_0_tbu
            qsmmuv500-tbu 151a9000.mnoc_sf_1_tbu: Linked as a consumer to regulator.71
            register_client_adhoc:Client handle 11 mnoc_sf_1_tbu
            Error: Driver 'arm-smmu' is already registered, aborting...
            vgaarb: loaded
            SCSI subsystem initialized
            usbcore: registered new interface driver usbfs
            usbcore: registered new interface driver hub
            usbcore: registered new device driver usb
            usb_phy_generic soc:usb_nop_phy: soc:usb_nop_phy supply vcc not found, using dummy regulator
            usb_phy_generic soc:usb_nop_phy: Linked as a consumer to regulator.0
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150@0:qcom,power-on@800: PMIC@SID0 Power-on reason: Triggered from CBL (External Power Supply) and 'cold' boot
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150@0:qcom,power-on@800: PMIC@SID0: Unknown power-off reason
            input: qpnp_pon as /devices/platform/soc/c440000.qcom,spmi/spmi-0/spmi0-00/c440000.qcom,spmi:qcom,pm8150@0:qcom,power-on@800/input/input0
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150b@2:qcom,power-on@800: PMIC@SID2 Power-on reason: Triggered from CBL (External Power Supply) and 'cold' boot
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150b@2:qcom,power-on@800: PMIC@SID2: Unknown power-off reason
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150l@4:qcom,power-on@800: PMIC@SID4 Power-on reason: Triggered from PON1 (Secondary PMIC) and 'cold' boot
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8150l@4:qcom,power-on@800: PMIC@SID4: Unknown power-off reason
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pm8009@a:qcom,power-on@800: Invalid PON_PERPH_SUBTYPE 0x07
            qcom,qpnp-power-on: probe of c440000.qcom,spmi:qcom,pm8009@a:qcom,power-on@800 failed with error -22
            qcom,qpnp-power-on c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800: Register read failed, addr=0x0805, rc=-5
            qcom,qpnp-power-on: probe of c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800 failed with error -5
            media: Linux media interface: v0.10
            videodev: Linux video capture interface: v2.00
            pps_core: LinuxPPS API ver. 1 registered
            pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
            PTP clock support registered
            virt zone: sensor[gpuss-1-usr] read error:-22
            thermal thermal_zone25: failed to read out thermal zone (-22)
            virt zone: sensor[skin-msm-therm-usr] read error:-22
            thermal thermal_zone68: failed to read out thermal zone (-22)
            EDAC MC: Ver: 3.0.0
            cpufreq: driver qcom-cpufreq-hw up and running
            platform soc:qcom,ion:qcom,ion-heap@22: assigned reserved memory node sdsp_region
            platform soc:qcom,ion:qcom,ion-heap@26: assigned reserved memory node user_contig_region
            platform soc:qcom,ion:qcom,ion-heap@27: assigned reserved memory node qseecom_region
            platform soc:qcom,ion:qcom,ion-heap@19: assigned reserved memory node qseecom_ta_region
            platform soc:qcom,ion:qcom,ion-heap@13: assigned reserved memory node sp_region
            platform soc:qcom,ion:qcom,ion-heap@10: assigned reserved memory node secure_display_region
            ION heap system created
            ION heap adsp created at 0x00000000ea000000 with size 800000
            ION heap secure_heap created
            ION heap user_contig created at 0x00000000ecc00000 with size 1000000
            ION heap qsecom created at 0x00000000fe800000 with size 1400000
            ION heap qsecom_ta created at 0x00000000ebc00000 with size 1000000
            ION heap spss created at 0x00000000ea800000 with size 1000000
            ION heap secure_display created at 0x00000000f1c00000 with size a400000
            platform soc:qcom,ion:qcom,ion-heap@14: ion_secure_carveout: creating heap@0x8bf00000, size 0x4600000
            ION heap secure_carveout created
            PMIC@SID2: PM8150B v2.0 options: 0, 0, 0, 0
            PMIC@SID4: (null) v2.0 options: 0, 0, 0, 0
            PMIC@SID10: (null) v2.0 options: 0, 0, 0, 0
            devfreq-qcom-fw 18590000.qcom,devfreq-l3:qcom,cpu0-cpu-l3-lat: Devfreq QCOM Firmware dev registered.
            devfreq-qcom-fw 18590000.qcom,devfreq-l3:qcom,cpu4-cpu-l3-lat: Devfreq QCOM Firmware dev registered.
            devfreq-qcom-fw 18590000.qcom,devfreq-l3:qcom,cpu7-cpu-l3-lat: Devfreq QCOM Firmware dev registered.
            devfreq-qcom-fw 18590000.qcom,devfreq-l3:qcom,cdsp-cdsp-l3-lat: Devfreq QCOM Firmware dev registered.
            devfreq-qcom-fw 18590000.qcom,devfreq-l3: Devfreq QCOM Firmware parent dev inited.
            SDAM base=0xb100 size=128 registered successfully
            Advanced Linux Sound Architecture Driver Initialized.
            Bluetooth: Core ver 2.22
            NET: Registered protocol family 31
            Bluetooth: HCI device and connection manager initialized
            Bluetooth: HCI socket layer initialized
            Bluetooth: L2CAP socket layer initialized
            Bluetooth: SCO socket layer initialized
            NetLabel: Initializing
            NetLabel: domain hash size = 128
            NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
            NetLabel: unlabeled traffic allowed by default
            pcie:pcie_init.
            register_client_adhoc:find path.src 45 dest 512
            register_client_adhoc:Client handle 12 pcie0
            pci-msm 1c00000.qcom,pcie: 1c00000.qcom,pcie supply vreg-3p3 not found, using dummy regulator
            pci-msm 1c00000.qcom,pcie: Linked as a consumer to regulator.0
            pci-msm 1c00000.qcom,pcie: Linked as a consumer to regulator.18
            pci-msm 1c00000.qcom,pcie: Linked as a consumer to regulator.13
            pci-msm 1c00000.qcom,pcie: Linked as a consumer to regulator.4
            pci-msm 1c00000.qcom,pcie: Linked as a consumer to regulator.62
            msm_pcie_get_reg: PCIe: RC0: no tcsr resource found.
            msm_pcie_get_reg: PCIe: RC0: no rumi resource found.
            register_client_adhoc:find path.src 108 dest 512
            register_client_adhoc:Client handle 13 pcie2
            pci-msm 1c10000.qcom,pcie: 1c10000.qcom,pcie supply vreg-3p3 not found, using dummy regulator
            pci-msm 1c10000.qcom,pcie: Linked as a consumer to regulator.0
            pci-msm 1c10000.qcom,pcie: Linked as a consumer to regulator.18
            pci-msm 1c10000.qcom,pcie: Linked as a consumer to regulator.13
            pci-msm 1c10000.qcom,pcie: Linked as a consumer to regulator.4
            pci-msm 1c10000.qcom,pcie: Linked as a consumer to regulator.64
            msm_pcie_get_reg: PCIe: RC2: no tcsr resource found.
            msm_pcie_get_reg: PCIe: RC2: no rumi resource found.
            msm_pcie_probe: PCIe: RC2 could not get pinctrl sleep state
            genirq: irq_chip msmgpio did not update eff. affinity mask of irq 433
            msm_pcie_enable: PCIe: Assert the reset of endpoint of RC2.
            msm_pcie_enable: PCIe: RC2: PCIE20_PARF_INT_ALL_MASK: 0x7f80c202
            pcie_phy_init: PCIe RC2 PHY is ready!
            msm_pcie_enable: PCIe: Release the reset of endpoint of RC2.
            msm_pcie_link_train: PCIe: Assert the reset of endpoint of RC2.
            msm_pcie_link_train: PCIe RC2 link initialization failed
            msm_pcie_enumerate: PCIe: RC2: failed to enable
            msm_pcie_probe: PCIe: RC2 is not enabled during bootup; it will be enumerated upon client request.
            register_client_adhoc:find path.src 22 dest 512
            register_client_adhoc:find path.src 23 dest 512
            register_client_adhoc:Client handle 14 bus-proxy-client
            qupv3_geni_se 9c0000.qcom,qupv3_0_geni_se: Linked as a consumer to 15000000.apps-smmu
            iommu: Adding device 9c0000.qcom,qupv3_0_geni_se to group 0
            qupv3_geni_se 8c0000.qcom,qupv3_2_geni_se: Linked as a consumer to 15000000.apps-smmu
            iommu: Adding device 8c0000.qcom,qupv3_2_geni_se to group 1
            qupv3_geni_se ac0000.qcom,qupv3_1_geni_se: Linked as a consumer to 15000000.apps-smmu
            iommu: Adding device ac0000.qcom,qupv3_1_geni_se to group 2
            register_client_adhoc:find path.src 1 dest 589
            register_client_adhoc:Client handle 15 bps_gdsc_ahb
            msm-bus-type slv-qhs-camera-cfg: Linked as a consumer to regulator.34
            bps_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 16 ife_0_gdsc_ahb
            ife_0_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 17 ife_1_gdsc_ahb
            ife_1_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 18 ipe_0_gdsc_ahb
            ipe_0_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 19 sbi_gdsc_ahb
            sbi_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 20 titan_top_gdsc_ahb
            titan_top_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:find path.src 1 dest 590
            register_client_adhoc:Client handle 21 mdss_core_gdsc_ahb
            msm-bus-type slv-qhs-display-cfg: Linked as a consumer to regulator.34
            mdss_core_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:find path.src 1 dest 596
            register_client_adhoc:Client handle 22 mvs0_gdsc_ahb
            msm-bus-type slv-qhs-venus-cfg: Linked as a consumer to regulator.34
            mvs0_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 23 mvs0c_gdsc_ahb
            mvs0c_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 24 mvs1_gdsc_ahb
            mvs1_gdsc: supplied by pm8150a_s4_level
            register_client_adhoc:Client handle 25 mvs1c_gdsc_ahb
            mvs1c_gdsc: supplied by pm8150a_s4_level
            cam_cc-kona ad00000.qcom,camcc: Linked as a consumer to regulator.1
            cam_cc-kona ad00000.qcom,camcc: Linked as a consumer to regulator.34
            register_client_adhoc:Client handle 26 clk_camcc_debugfs
            cam_cc-kona ad00000.qcom,camcc: Registered CAM CC clocks
            disp_cc-kona af00000.qcom,dispcc: Linked as a consumer to regulator.34
            register_client_adhoc:Client handle 27 clk_dispcc_debugfs
            disp_cc-kona af00000.qcom,dispcc: Registered Display CC clocks
            register_client_adhoc:Client handle 28 clk_videocc_debugfs
            video_cc-kona abf0000.qcom,videocc: Registered Video CC clocks
            VFS: Disk quotas dquot_6.6.0
            VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
            • E Offline
              E Offline
              ErezI
              2nd part
              AppArmor: AppArmor Filesystem Enabled
              register_client_adhoc:Client handle 29 clk_measure
              mdss_pll_probe: MDSS pll label = MDSS DSI 0 PLL
              mdss_pll ae94900.qcom,mdss_dsi_pll: Failed to create ae94900.qcom,mdss_dsi_pll debugfs directory
              dsi_pll_clock_register_7nm: Registered DSI PLL ndx=0, clocks successfully
              mdss_pll_probe: MDSS pll label = MDSS DSI 1 PLL
              mdss_pll ae96900.qcom,mdss_dsi_pll: Failed to create ae96900.qcom,mdss_dsi_pll debugfs directory
              dsi_pll_clock_register_7nm: Registered DSI PLL ndx=1, clocks successfully
              mdss_pll_probe: MDSS pll label = MDSS DP PLL
              NET: Registered protocol family 2
              tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
              TCP established hash table entries: 65536 (order: 7, 524288 bytes)
              TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
              TCP: Hash tables configured (established 65536 bind 65536)
              UDP hash table entries: 4096 (order: 5, 131072 bytes)
              UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
              PCI: CLS 0 bytes, default 64
              hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
              Initialise system trusted keyrings
              workingset: timestamp_bits=45 max_order=21 bucket_order=0
              Registering sdcardfs 0.1
              fuse init (API version 7.27)
              Key type asymmetric registered
              Asymmetric key parser 'x509' registered
              Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
              io scheduler noop registered
              io scheduler deadline registered
              io scheduler cfq registered (default)
              io scheduler mq-deadline registered
              io scheduler kyber registered
              io scheduler bfq registered
              Virtual Services transport driver for OKL4 Axons
              gpi_dma 900000.qcom,gpi-dma: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 900000.qcom,gpi-dma to group 3
              gpi_dma a00000.qcom,gpi-dma: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device a00000.qcom,gpi-dma to group 4
              gpi_dma 800000.qcom,gpi-dma: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 800000.qcom,gpi-dma to group 5
              kona-llcc 9200000.cache-controller: Failed to create 9200000.cache-controller debugfs directory
              register_client_adhoc:find path.src 125 dest 512
              register_client_adhoc:Client handle 30 scm_pas
              minidump-id not found for ipa_fws
              subsys-pil-tz soc:qcom,ipa_fws: for ipa_fws segments only will be dumped.
              subsys-pil-tz soc:qcom,ipa_fws: for md_ipa_fws segments only will be dumped.
              minidump-id not found for ipa_uc
              subsys-pil-tz soc:qcom,ipa_uc: for ipa_uc segments only will be dumped.
              subsys-pil-tz soc:qcom,ipa_uc: for md_ipa_uc segments only will be dumped.
              subsys-pil-tz 17300000.qcom,lpass: Linked as a consumer to regulator.20
              subsys-pil-tz 17300000.qcom,lpass: Linked as a consumer to regulator.12
              minidump-id not found for adsp
              subsys-pil-tz 8300000.qcom,turing: Linked as a consumer to regulator.4
              register_client_adhoc:Client handle 31 pil-cdsp
              minidump-id not found for cdsp
              subsys-pil-tz aab0000.qcom,venus: Linked as a consumer to regulator.83
              register_client_adhoc:find path.src 63 dest 512
              register_client_adhoc:Client handle 32 pil-venus
              minidump-id not found for venus
              subsys-pil-tz 188101c.qcom,spss: Linked as a consumer to regulator.4
              minidump-id not found for spss
              minidump-id not found for cvpss
              subsys-pil-tz abb0000.qcom,cvpss: for cvpss segments only will be dumped.
              subsys-pil-tz abb0000.qcom,cvpss: for md_cvpss segments only will be dumped.
              minidump-id not found for npu
              subsys-pil-tz 9800000.qcom,npu: for npu segments only will be dumped.
              subsys-pil-tz 9800000.qcom,npu: for md_npu segments only will be dumped.
              subsys-restart: __get_smem_state(): Could not get smem-states qcom,force-stop
              subsys-pil-tz 5c00000.qcom,ssc: Linked as a consumer to regulator.20
              subsys-pil-tz 5c00000.qcom,ssc: Linked as a consumer to regulator.12
              minidump-id not found for slpi
              minidump-id not found for a650_zap
              subsys-pil-tz soc:qcom,kgsl-hyp: for a650_zap segments only will be dumped.
              subsys-pil-tz soc:qcom,kgsl-hyp: for md_a650_zap segments only will be dumped.
              msm_geni_serial 994000.qcom,qup_uart: Wakeup byte 0xfd
              msm_geni_serial 994000.qcom,qup_uart: Serial port0 added.FifoSize 64 is_console0
              994000.qcom,qup_uart: ttyHS0 at MMIO 0x994000 (irq = 394, base_baud = 0) is a MSM
              msm_geni_serial 99c000.qcom,qup_uart: Wakeup byte 0xfd
              msm_geni_serial 99c000.qcom,qup_uart: Serial port1 added.FifoSize 64 is_console0
              99c000.qcom,qup_uart: ttyHS1 at MMIO 0x99c000 (irq = 396, base_baud = 0) is a MSM
              msm_geni_serial 894000.qcom,qup_uart: Wakeup byte 0xfd
              msm_geni_serial 894000.qcom,qup_uart: Serial port2 added.FifoSize 64 is_console0
              894000.qcom,qup_uart: ttyHS2 at MMIO 0x894000 (irq = 398, base_baud = 0) is a MSM
              msm_geni_serial a94000.qcom,qup_uart: Wakeup byte 0xfd
              msm_geni_serial a94000.qcom,qup_uart: Serial port3 added.FifoSize 64 is_console0
              a94000.qcom,qup_uart: ttyHS3 at MMIO 0xa94000 (irq = 400, base_baud = 0) is a MSM
              msm_geni_serial_init: Driver initialized
              register_client_adhoc:find path.src 1 dest 618
              register_client_adhoc:Client handle 33 msm-rng-noc
              random: crng init done
              voxl_b2b init
              voxl_b2b probe
              voxl_b2b probe complete
              voxl_b2b probe
              sysfs: cannot create duplicate filename '/class/voxl_b2b'
              CPU: 6 PID: 1 Comm: swapper/0 Tainted: G S 4.19.125 #1
              Hardware name: Qualcomm Technologies, Inc. kona v2.1 IOT RB5 (DT)
              Call trace:
              dump_backtrace+0x0/0x1c0
              show_stack+0x14/0x20
              dump_stack+0x98/0xbc
              sysfs_warn_dup+0x64/0x80
              sysfs_create_dir_ns+0xd4/0xe8
              kobject_add_internal+0xb0/0x2e8
              kset_register+0x54/0x98
              __class_register+0xc0/0x170
              __class_create+0x58/0x88
              voxl_b2b_probe+0x60/0xf8
              platform_drv_probe+0x50/0xa0
              really_probe+0x1f8/0x2c0
              driver_probe_device+0x58/0x100
              __driver_attach+0xe0/0xe8
              bus_for_each_dev+0x74/0xc8
              driver_attach+0x20/0x28
              bus_add_driver+0x1b0/0x220
              driver_register+0x60/0x110
              __platform_driver_register+0x40/0x48
              voxl_b2b_init+0x24/0x2c
              do_one_initcall+0x5c/0x250
              kernel_init_freeable+0x2d0/0x37c
              kernel_init+0x10/0x100
              ret_from_fork+0x10/0x18
              kobject_add_internal failed for voxl_b2b with -EEXIST, don't try to register things with the same name in the same directory.
              voxl_b2b: probe of soc:hs_b2b_conn_gpio_init failed with error -17
              voxl_rc_in init
              voxl_rc_in probe
              voxl_rc_in probe complete
              iommu-debug soc:kgsl_iommu_test_device: Linked as a consumer to 3da0000.kgsl-smmu
              iommu: Adding device soc:kgsl_iommu_test_device to group 6
              iommu-debug soc:apps_iommu_test_device: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device soc:apps_iommu_test_device to group 7
              iommu-debug soc:apps_iommu_coherent_test_device: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device soc:apps_iommu_coherent_test_device to group 8
              brd: module loaded
              loop: module loaded
              zram: Added device: zram0
              QSEECOM: qseecom_init_control: qseecom.qsee_version = 0x1402000
              QSEECOM: qseecom_retrieve_ce_data: Device does not support PFE
              qce 1de0000.qcedev: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 1de0000.qcedev to group 9
              register_client_adhoc:Client handle 34 qcedev-noc
              QCE50: __qce_get_device_tree_data: CE operating frequency is not defined, setting to default 100MHZ
              qce 1de0000.qcedev: QTI Crypto 5.5.0 device found @0x1de0000
              sps:BAM 0x0000000001dc4000 is registered.
              sps:BAM 0x0000000001dc4000 (va:0x00000000fae97f7e) enabled: ver:0x27, number of pipes:16
              QCE50: qce_sps_init: QTI MSM CE-BAM at 0x0000000001dc4000 irq 100
              qce 1de0000.qcedev:qcom_cedev_ns_cb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 1de0000.qcedev:qcom_cedev_ns_cb to group 10
              qce 1de0000.qcedev:qcom_cedev_s_cb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 1de0000.qcedev:qcom_cedev_s_cb to group 11
              qcrypto 1de0000.qcrypto: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 1de0000.qcrypto to group 12
              register_client_adhoc:Client handle 35 qcrypto-noc
              qcrypto 1de0000.qcrypto: QTI Crypto 5.5.0 device found @0x1de0000
              qcrypto 1de0000.qcrypto: qcrypto-ecb-aes
              qcrypto 1de0000.qcrypto: qcrypto-cbc-aes
              qcrypto 1de0000.qcrypto: qcrypto-ctr-aes
              qcrypto 1de0000.qcrypto: qcrypto-ecb-des
              qcrypto 1de0000.qcrypto: qcrypto-cbc-des
              qcrypto 1de0000.qcrypto: qcrypto-ecb-3des
              qcrypto 1de0000.qcrypto: qcrypto-cbc-3des
              qcrypto 1de0000.qcrypto: qcrypto-xts-aes
              qcrypto 1de0000.qcrypto: qcrypto-sha1
              qcrypto 1de0000.qcrypto: qcrypto-sha256
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha1-cbc-aes
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha1-cbc-des
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha1-cbc-3des
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha256-cbc-aes
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha256-cbc-des
              qcrypto 1de0000.qcrypto: qcrypto-aead-hmac-sha256-cbc-3des
              qcrypto 1de0000.qcrypto: qcrypto-hmac-sha1
              qcrypto 1de0000.qcrypto: qcrypto-hmac-sha256
              qcrypto 1de0000.qcrypto: qcrypto-aes-ccm
              qcrypto 1de0000.qcrypto: qcrypto-rfc4309-aes-ccm
              ufshcd-qcom 1d84000.ufshc: no vccq2-voltage-level property.
              ufshcd-qcom 1d84000.ufshc: Linked as a consumer to regulator.65
              ufshcd-qcom 1d84000.ufshc: Linked as a consumer to regulator.31
              ufshcd-qcom 1d84000.ufshc: Linked as a consumer to regulator.16
              ufshcd-qcom 1d84000.ufshc: Linked as a consumer to regulator.7
              register_client_adhoc:find path.src 123 dest 512
              register_client_adhoc:find path.src 1 dest 757
              register_client_adhoc:Client handle 36 ufshc_mem
              ufs_qcom_phy_qmp_v4 1d87000.ufsphy_mem: Linked as a consumer to regulator.18
              ufs_qcom_phy_qmp_v4 1d87000.ufsphy_mem: Linked as a consumer to regulator.13
              ufshcd-qcom 1d84000.ufshc: Linked as a consumer to regulator.39
              scsi host0: ufshcd
              SCSI Media Changer driver v0.25
              ------------[ cut here ]------------
              /soc/spi@980000/spidev@0: buggy DT: spidev listed directly in DT
              WARNING: CPU: 6 PID: 1 at /home/user/build_mount/lu.um.1.2.1/apps_proc/build-qti-distro-ubuntu-fullstack-perf/tmp-glibc/work-shared/m0054/kernel-source/drivers/spi/spidev.c:732 spidev_probe+0x100/0x1e8
              Modules linked in:
              pstate: 40c00005 (nZcv daif +PAN +UAO)
              pc : spidev_probe+0x100/0x1e8
              lr : spidev_probe+0x100/0x1e8
              sp : ffffff800805b870
              x29: ffffff800805b870 x28: ffffff9bf4cf03e0
              x27: ffffff9bf4cf04c0 x26: ffffff9bf4cf03e0
              x25: ffffff9bf4cf04c0 x24: 0000000000000015
              x23: ffffff9bf4d02f40 x22: 0000000000000000
              x21: fffffffcd8fd6000 x20: fffffffcd8fd6000
              x19: 0000000000000000 x18: ffffffffffffffff
              x17: 00000000bf17f8c1 x16: 0000000047951e33
              x15: ffffff9bf4c0e288 x14: 0720075407440720
              x13: 076e076907200779 x12: 076c077407630765
              x11: 0772076907640720 x10: 0764076507740773
              x9 : 0769076c07200776 x8 : 0765076407690770
              x7 : 07730720073a0754 x6 : 00000000000002cb
              x5 : 0000000000000000 x4 : 0000000000000000
              x3 : ffffffffffffffff x2 : ffffff9bf4c357f8
              x1 : 5b4d455e934ee100 x0 : 0000000000000000
              Call trace:
              spi_drv_probe+0x7c/0xd8
              __device_attach_driver+0x90/0xd0
              bus_for_each_drv+0x64/0xc8
              __device_attach+0xd8/0x130
              device_initial_probe+0x10/0x18
              bus_probe_device+0x90/0x98
              device_add+0x60c/0x730
              spi_add_device+0xf4/0x160
              spi_register_controller+0x49c/0x980
              spi_geni_probe+0x6a0/0x770
              spi_geni_driver_init+0x18/0x20
              ---[ end trace f493a9cf494307d7 ]---
              /soc/spi@98c000/spidev@0: buggy DT: spidev listed directly in DT
              Modules linked in:
              CPU: 6 PID: 1 Comm: swapper/0 Tainted: G S W 4.19.125 #1
              x21: fffffffcd8fd4800 x20: fffffffcd8fd4800
              x17: ffffff9bf4e1d960 x16: ffffff9bf4c0e4a4
              x7 : 07730720073a0754 x6 : 0000000000000301
              Call trace:
              ---[ end trace f493a9cf494307d8 ]---
              /soc/spi@a8c000/spidev@0: buggy DT: spidev listed directly in DT
              Modules linked in:
              x21: fffffffcd8fd7800 x20: fffffffcd8fd7800
              x17: 00000000c1662590 x16: 00000000a355e30e
              x7 : 07730720073a0754 x6 : 0000000000000337
              Call trace:
              ---[ end trace f493a9cf494307d9 ]---
              /soc/spi@880000/spidev@0: buggy DT: spidev listed directly in DT
              Modules linked in:
              x21: fffffffcd8fd2000 x20: fffffffcd8fd2000
              x7 : 07730720073a0754 x6 : 000000000000036d
              Call trace:
              ---[ end trace f493a9cf494307da ]---
              spmi spmi-1: pmic_arb_debug_wait_for_done: transaction failed (0x3)
              spmi spmi-1: SPMI PMIC arbiter debug bus controller added
              Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
              libphy: Fixed MDIO Bus: probed
              tun: Universal TUN/TAP device driver, 1.6
              sky2: driver version 1.30
              PPP generic driver version 2.4.2
              PPP BSD Compression module registered
              PPP Deflate Compression module registered
              PPP MPPE Compression module registered
              NET: Registered protocol family 24
              PPTP driver version 0.8.5
              usbcore: registered new interface driver r8152
              usbcore: registered new interface driver lan78xx
              usbcore: registered new interface driver asix
              usbcore: registered new interface driver ax88179_178a
              usbcore: registered new interface driver cdc_ether
              usbcore: registered new interface driver cdc_eem
              usbcore: registered new interface driver smsc75xx
              usbcore: registered new interface driver smsc95xx
              usbcore: registered new interface driver net1080
              usbcore: registered new interface driver rndis_host
              usbcore: registered new interface driver cdc_subset
              usbcore: registered new interface driver zaurus
              usbcore: registered new interface driver sierra_net
              usbcore: registered new interface driver cdc_ncm
              usbcore: registered new interface driver qmi_wwan
              msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32
              msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
              msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp
              msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
              msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
              msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.32
              msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.18
              msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.13
              msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.10
              msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.21
              msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.13
              msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.10
              msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.21
              msm-dwc3 a600000.ssusb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device a600000.ssusb to group 13
              msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66
              dwc3 a600000.dwc3: Failed to get clk 'ref': -2
              dwc3 a600000.dwc3: changing max_speed on rev 00000000
              msm-dwc3 a600000.ssusb: unable to get ssphy device
              msm-dwc3 a600000.ssusb: Dropping the link to regulator.66
              msm-dwc3 a800000.ssusb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device a800000.ssusb to group 14
              msm-dwc3 a800000.ssusb: Linked as a consumer to regulator.67
              dwc3 a800000.dwc3: Failed to get clk 'ref': -2
              register_client_adhoc:find path.src 101 dest 512
              register_client_adhoc:find path.src 101 dest 676
              register_client_adhoc:find path.src 1 dest 751
              register_client_adhoc:Client handle 37 usb1
              ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
              ehci-pci: EHCI PCI platform driver
              ehci-platform: EHCI generic platform driver
              ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
              ohci-pci: OHCI PCI platform driver
              ohci-platform: OHCI generic platform driver
              usbcore: registered new interface driver cdc_acm
              cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
              usbcore: registered new interface driver cdc_wdm
              usbcore: registered new interface driver usb-storage
              usbcore: registered new interface driver cp210x
              usbserial: USB Serial support registered for cp210x
              usbcore: registered new interface driver ftdi_sio
              usbserial: USB Serial support registered for FTDI USB Serial Device
              usbcore: registered new interface driver option
              usbserial: USB Serial support registered for GSM modem (1-port)
              usbcore: registered new interface driver qcserial
              usbserial: USB Serial support registered for Qualcomm USB modem
              usbserial: USB Serial support registered for Sierra USB modem
              usbcore: registered new interface driver usb_ehset_test
              usbcore: registered new interface driver lvs
              qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10
              qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: usbpd_create failed: -517
              qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Dropping the link to regulator.10
              usbcore: registered new interface driver xpad
              usbcore: registered new interface driver usb_acecad
              usbcore: registered new interface driver aiptek
              usbcore: registered new interface driver gtco
              usbcore: registered new interface driver hanwang
              usbcore: registered new interface driver kbtab
              qcom,haptics c440000.qcom,spmi:qcom,pm8150b@3:qcom,haptics@c000: parse device-tree failed, rc=-517
              rtc-pm8xxx c440000.qcom,spmi:qcom,pm8150@0:qcom,pm8150_rtc: rtc core: registered pm8xxx_rtc as rtc0
              rtc-pm8xxx c440000.qcom,spmi:qcom,pm8150@0:qcom,pm8150_rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
              i2c /dev entries driver
              i2c_geni 988000.i2c: Bus frequency is set to 400000Hz
              i2c_geni a84000.i2c: Bus frequency is set to 400000Hz
              i2c_geni a88000.i2c: Bus frequency is set to 400000Hz
              i2c_geni 884000.i2c: Bus frequency is set to 400000Hz
              ssusb redriver 3-001c: Could not get usb power_supply
              ssusb redriver 3-001c: failed to get phandle for redriver
              i2c_geni 884000.i2c: i2c error :-107
              I2C PMIC: i2c_pmic_read: i2c_pmic_read failed for 3 retries, rc = -107
              I2C PMIC: i2c_pmic_determine_initial_status: Couldn't read irq data rc=-107
              I2C PMIC: i2c_pmic_probe: Couldn't determine initial status rc=-107
              i2c_pmic: probe of 3-0010 failed with error -107
              ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
              I2C PMIC: i2c_pmic_probe: I2C PMIC probe successful
              i2c_geni 984000.i2c: Bus frequency is set to 400000Hz
              msm_cvp_v4l2 ab00000.qcom,cvp:cvp_non_secure_cb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device ab00000.qcom,cvp:cvp_non_secure_cb to group 15
              msm_cvp_v4l2 ab00000.qcom,cvp:cvp_secure_nonpixel_cb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device ab00000.qcom,cvp:cvp_secure_nonpixel_cb to group 16
              msm_cvp_v4l2 ab00000.qcom,cvp:cvp_secure_pixel_cb: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device ab00000.qcom,cvp:cvp_secure_pixel_cb to group 17
              platform ab00000.qcom,cvp:qcom,msm-cvp,mem_cdsp: assigned reserved memory node cdsp_region
              msm_npu 9900000.qcom,msm_npu: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 9900000.qcom,msm_npu to group 18
              NPU_INFO: npu_probe: 2550 unable to get qfprom_physical resource
              msm_npu 9900000.qcom,msm_npu: Linked as a consumer to regulator.81
              msm_npu 9900000.qcom,msm_npu: Linked as a consumer to regulator.4
              register_client_adhoc:find path.src 154 dest 512
              register_client_adhoc:find path.src 154 dest 620
              register_client_adhoc:Client handle 38 9900000.qcom,msm_npu
              NPU_INFO: npu_parse_dt_bw: 1877 NPU BW client sets up successfully
              synx: synx device init start
              synx: synx device init success
              usbcore: registered new interface driver uvcvideo
              USB Video Class driver (1.1.1)
              Couldn't parse device tree rc=-517
              FG: fg_gen4_probe: battery SOC:51 voltage: 3828847uV temp: 242 id: 10000 ohms
              of_batterydata_get_best_profile: No battery data found
              FG: fg_gen4_get_batt_profile: couldn't find profile handle
              FG: profile_load_work: profile for batt_id=10KOhms not found..using OTP, rc:-61
              msm_lmh_dcvs 18591000.qcom,cpufreq-hw:qcom,limits-dcvs: Linked as a consumer to regulator.22
              msm_lmh_dcvs 18591000.qcom,cpufreq-hw:qcom,limits-dcvs: Linked as a consumer to regulator.14
              device-mapper: uevent: version 1.0.3
              device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
              bt_dt_parse_vreg_info: qca,bt-vdd-core: is not provided in device tree
              bt_dt_parse_vreg_info: qca,bt-vdd-io: is not provided in device tree
              bt_dt_parse_vreg_info: qca,bt-vdd-xtal: is not provided in device tree
              bt_dt_parse_vreg_info: qca,bt-vdd-pa: is not provided in device tree
              bt_dt_parse_vreg_info: qca,bt-vdd-ldo: is not provided in device tree
              bt_dt_parse_vreg_info: qca,bt-chip-pwd: is not provided in device tree
              bt_dt_parse_clk_info: clocks is not provided in device tree
              EDAC DEVICE0: Giving out device to module soc:kryo-erp controller cache: DEV soc:kryo-erp (INTERRUPT)
              sdhci: Secure Digital Host Controller Interface driver
              sdhci: Copyright(c) Pierre Ossman
              sdhci-pltfm: SDHCI platform and OF driver helper
              usbcore: registered new interface driver usbhid
              usbhid: USB HID core driver
              sdhci_msm 8804000.sdhci: No vreg data found for vdd-io-bias
              ashmem: initialized
              bimc-bwmon 90b6400.qcom,cpu-cpu-llcc-bwmon: BW HWmon governor registered.
              bimc-bwmon 9091000.qcom,cpu-llcc-ddr-bwmon: BW HWmon governor registered.
              sdhci_msm 8804000.sdhci: core_reset unavailable,err = -2
              sdhci_msm 8804000.sdhci: Reset data parsing error
              bimc-bwmon 60400.qcom,npu-npu-llcc-bwmon: BW HWmon governor registered.
              bimc-bwmon 9093000.qcom,npu-llcc-ddr-bwmon: BW HWmon governor registered.
              bimc-bwmon 70300.qcom,npudsp-npu-ddr-bwmon: BW HWmon governor registered.
              register_client_adhoc:find path.src 81 dest 512
              arm-memlat-mon soc:qcom,cpu0-cpugrp:qcom,cpu0-cpu-l3-latmon: Memory Latency governor registered.
              ufshcd-qcom 1d84000.ufshc: ufshcd_needs_reinit: Re-init UFS host to use proper PHY settings for the UFS device. This can be avoided by setting the force-g4 in DT
              arm-memlat-mon soc:qcom,cpu0-cpugrp:qcom,cpu0-cpu-llcc-latmon: Memory Latency governor registered.
              arm-memlat-mon soc:qcom,cpu0-cpugrp:qcom,cpu0-llcc-ddr-latmon: Memory Latency governor registered.
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu4-cpu-l3-latmon: Memory Latency governor registered.
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu7-cpu-l3-latmon: Memory Latency governor registered.
              register_client_adhoc:find path.src 1 dest 608
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu4-cpu-llcc-latmon: Memory Latency governor registered.
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu4-llcc-ddr-latmon: Memory Latency governor registered.
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu4-computemon: Compute governor registered.
              arm-memlat-mon soc:qcom,cpu4-cpugrp:qcom,cpu4-qoslatmon: Memory Latency governor registered.
              register_client_adhoc:Client handle 39 sdhc2
              register_client_adhoc:find path.src 1 dest 627
              sdhci_msm 8804000.sdhci: Linked as a consumer to regulator.48
              register_client_adhoc:Client handle 40 soc:qcom,snoc_cnoc_keepalive
              sdhci_msm 8804000.sdhci: Linked as a consumer to regulator.45
              register_client_adhoc:find path.src 1 dest 770
              register_client_adhoc:Client handle 41 soc:qcom,cpu-cpu-llcc-bw
              register_client_adhoc:find path.src 129 dest 512
              register_client_adhoc:Client handle 42 soc:qcom,cpu-llcc-ddr-bw
              register_client_adhoc:find path.src 154 dest 770
              register_client_adhoc:Client handle 43 soc:qcom,npu-npu-llcc-bw
              register_client_adhoc:find path.src 770 dest 512
              register_client_adhoc:Client handle 44 soc:qcom,npu-llcc-ddr-bw
              register_client_adhoc:Client handle 45 soc:qcom,npudsp-npu-ddr-bw
              register_client_adhoc:Client handle 46 soc:qcom,npu-npu-ddr-latfloor
              register_client_adhoc:Client handle 47 soc:qcom,cpu0-cpu-llcc-lat
              register_client_adhoc:Client handle 48 soc:qcom,cpu4-cpu-llcc-lat
              register_client_adhoc:Client handle 49 soc:qcom,cpu0-llcc-ddr-lat
              register_client_adhoc:Client handle 51 soc:qcom,cpu4-llcc-ddr-lat
              register_client_adhoc:Client handle 50 soc:qcom,cpu4-cpu-ddr-latfloor
              register_client_adhoc:find path.src 26 dest 512
              register_client_adhoc:Client handle 52 soc:qcom,gpubw
              qcom-llcc-pmu 9095000.llcc-pmu: Registered llcc_pmu, type: 9
              coresight-tmc 6048000.tmc: Linked as a consumer to 15000000.apps-smmu
              iommu: Adding device 6048000.tmc to group 19
              • E Offline
                E Offline
                ErezI
                3rd part
                FG: fg_psy_get_property: unsupported property 4
                coresight-dynamic-funnel 6902000.funnel: Linked as a consumer to regulator.72
                coresight-dynamic-funnel 6902000.funnel: Linked as a consumer to regulator.73
                coresight-dynamic-funnel 6c44000.funnel: Linked as a consumer to regulator.81
                coresight-dynamic-funnel 6c44000.funnel: Linked as a consumer to regulator.4
                coresight-stm 6002000.stm: stm_register_device failed, probing deffered
                OF: graph: no port node found in /soc/cti@78e0000
                OF: graph: no port node found in /soc/cti@78f0000
                OF: graph: no port node found in /soc/cti@7900000
                OF: graph: no port node found in /soc/cti@6e01000
                OF: graph: no port node found in /soc/cti@6e02000
                OF: graph: no port node found in /soc/cti@6e03000
                OF: graph: no port node found in /soc/cti@6e0c000
                OF: graph: no port node found in /soc/cti@6e0d000
                OF: graph: no port node found in /soc/cti@6e0e000
                OF: graph: no port node found in /soc/cti@6e11000
                OF: graph: no port node found in /soc/cti@6e21000
                OF: graph: no port node found in /soc/cti@6c09000
                OF: graph: no port node found in /soc/cti@6c0a000
                OF: graph: no port node found in /soc/cti@6c2a000
                OF: graph: no port node found in /soc/cti@6c2b000
                OF: graph: no port node found in /soc/cti@6c2c000
                OF: graph: no port node found in /soc/cti@6010000
                OF: graph: no port node found in /soc/cti@6011000
                OF: graph: no port node found in /soc/cti@6012000
                OF: graph: no port node found in /soc/cti@6013000
                OF: graph: no port node found in /soc/cti@6014000
                OF: graph: no port node found in /soc/cti@6015000
                OF: graph: no port node found in /soc/cti@6016000
                OF: graph: no port node found in /soc/cti@6017000
                OF: graph: no port node found in /soc/cti@6018000
                OF: graph: no port node found in /soc/cti@6019000
                OF: graph: no port node found in /soc/cti@601a000
                OF: graph: no port node found in /soc/cti@601b000
                OF: graph: no port node found in /soc/cti@601c000
                OF: graph: no port node found in /soc/cti@601d000
                OF: graph: no port node found in /soc/cti@601e000
                OF: graph: no port node found in /soc/cti@601f000
                OF: graph: no port node found in /soc/cti@7020000
                OF: graph: no port node found in /soc/cti@7120000
                OF: graph: no port node found in /soc/cti@7220000
                OF: graph: no port node found in /soc/cti@7320000
                OF: graph: no port node found in /soc/cti@7420000
                OF: graph: no port node found in /soc/cti@7520000
                OF: graph: no port node found in /soc/cti@7620000
                OF: graph: no port node found in /soc/cti@7720000
                OF: graph: no port node found in /soc/cti@6831000
                OF: graph: no port node found in /soc/cti@6845000
                OF: graph: no port node found in /soc/cti@6c61000
                OF: graph: no port node found in /soc/cti@6c42000
                OF: graph: no port node found in /soc/cti@6c43000
                OF: graph: no port node found in /soc/cti@6c4b000
                OF: graph: no port node found in /soc/cti@6b00000
                OF: graph: no port node found in /soc/cti@6b01000
                OF: graph: no port node found in /soc/cti@6b02000
                OF: graph: no port node found in /soc/cti@6b03000
                OF: graph: no port node found in /soc/cti@6982000
                OF: graph: no port node found in /soc/cti@698b000
                OF: graph: no port node found in /soc/cti@6c38000
                coresight-tpdm 6900000.tpdm: Linked as a consumer to regulator.72
                coresight-tpdm 6900000.tpdm: Linked as a consumer to regulator.73
                coresight-tpdm 6c47000.tpdm: Linked as a consumer to regulator.81
                coresight-tpdm 6c47000.tpdm: Linked as a consumer to regulator.4
                coresight-tpdm 6c40000.tpdm: Linked as a consumer to regulator.81
                coresight-tpdm 6c40000.tpdm: Linked as a consumer to regulator.4
                coresight-tpdm 6c41000.tpdm: Linked as a consumer to regulator.81
                coresight-tpdm 6c41000.tpdm: Linked as a consumer to regulator.4
                mmc0: SDHCI controller on 8804000.sdhci [8804000.sdhci] using 64-bit ADMA in legacy mode
                OF: graph: no port node found in /soc/csr@6001000
                coresight-csr 6001000.csr: CSR initialized: coresight-csr
                OF: graph: no port node found in /soc/csr@6b0c000
                coresight-csr 6b0c000.csr: CSR initialized: coresight-swao-csr
                OF: graph: no port node found in /soc/hwevent
                coresight-hwevent soc:hwevent: Hardware Event driver initialized
                coresight-dummy soc:dummy_sink: Dummy device initialized
                coresight-dummy soc:tpdm@6b26000: Dummy device initialized
                coresight-remote-etm soc:turing_etm0: Remote ETM initialized
                coresight-remote-etm soc:audio_etm0: Remote ETM initialized
                coresight-remote-etm soc:ssc_etm0: Remote ETM initialized
                coresight-remote-etm soc:npu_etm0: Remote ETM initialized
                OF: graph: no port node found in /soc/tgu@6b0b000
                usbcore: registered new interface driver snd-usb-audio
                uaudio-qmi soc:usb_audio_qmi_dev: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:usb_audio_qmi_dev to group 20
                msm_vidc: err : ffffffff: .....: no device Registered
                msm_vidc_v4l2 aa00000.qcom,vidc:non_secure_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device aa00000.qcom,vidc:non_secure_cb to group 21
                msm_vidc_v4l2 aa00000.qcom,vidc:secure_non_pixel_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device aa00000.qcom,vidc:secure_non_pixel_cb to group 22
                msm_vidc_v4l2 aa00000.qcom,vidc:secure_bitstream_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device aa00000.qcom,vidc:secure_bitstream_cb to group 23
                msm_vidc_v4l2 aa00000.qcom,vidc:secure_pixel_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device aa00000.qcom,vidc:secure_pixel_cb to group 24
                register_client_adhoc:Client handle 53 disp_rsc_reg
                register_client_adhoc:find path.src 20003 dest 20513
                register_client_adhoc:find path.src 20004 dest 20513
                register_client_adhoc:Client handle 54 disp_rsc_mnoc_llcc
                register_client_adhoc:find path.src 20000 dest 20512
                register_client_adhoc:Client handle 55 disp_rsc_ebi
                sde_rsc af20000.qcom,sde_rscc: Linked as a consumer to regulator.80
                [sde_rsc_hw:rsc_hw_init_v3:537]: sde rsc init successfully done
                [sde_rsc:sde_rsc_probe:1594]: sde rsc index:0 probed successfully
                dsi_phy ae94400.qcom,mdss_dsi_phy0: ae94400.qcom,mdss_dsi_phy0 supply gdsc not found, using dummy regulator
                dsi_phy ae94400.qcom,mdss_dsi_phy0: Linked as a consumer to regulator.0
                dsi_phy ae94400.qcom,mdss_dsi_phy0: Linked as a consumer to regulator.13
                [drm:dsi_phy_driver_probe] [msm-dsi-info]: DSI_0: Probe successful
                dsi_phy ae96400.qcom,mdss_dsi_phy1: ae96400.qcom,mdss_dsi_phy1 supply gdsc not found, using dummy regulator
                dsi_phy ae96400.qcom,mdss_dsi_phy1: Linked as a consumer to regulator.0
                dsi_phy ae96400.qcom,mdss_dsi_phy1: Linked as a consumer to regulator.13
                [drm:dsi_phy_driver_probe] [msm-dsi-info]: DSI_1: Probe successful
                drm_dsi_ctrl ae94000.qcom,mdss_dsi_ctrl0: Linked as a consumer to regulator.61
                drm_dsi_ctrl ae94000.qcom,mdss_dsi_ctrl0: Linked as a consumer to regulator.18
                AXI: get_pdata(): Error: Client name not found
                AXI: msm_bus_cl_get_pdata(): client has to provide missing entry for successful registration
                [drm:dsi_ctrl_dev_probe] [msm-dsi-info]: dsi-ctrl-0: Probe successful
                drm_dsi_ctrl ae96000.qcom,mdss_dsi_ctrl1: Linked as a consumer to regulator.61
                drm_dsi_ctrl ae96000.qcom,mdss_dsi_ctrl1: Linked as a consumer to regulator.18
                [drm:dsi_ctrl_dev_probe] [msm-dsi-info]: dsi-ctrl-1: Probe successful
                msm_drm ae00000.qcom,mdss_mdp: Linked as a consumer to regulator.34
                register_client_adhoc:Client handle 56 mdss_reg
                register_client_adhoc:Client handle 57 mdss_sde
                [drm:sde_dbg_init:4676] evtlog_status: enable:11, panic:1, dump:2
                msm_drm ae00000.qcom,mdss_mdp: bound af20000.qcom,sde_rscc (ops sde_rsc_comp_ops)
                [drm] mapped mdp address space @000000003204f114
                [drm:_sde_kms_hw_init_blocks:3603] sde hardware revision:0x60000000
                msmdrm_smmu ae00000.qcom,mdss_mdp:qcom,smmu_sde_unsec_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device ae00000.qcom,mdss_mdp:qcom,smmu_sde_unsec_cb to group 25
                [drm] probing device qcom,smmu_sde_unsec
                [drm] Created domain mdp_ns, secure=0
                msmdrm_smmu ae00000.qcom,mdss_mdp:qcom,smmu_sde_sec_cb: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device ae00000.qcom,mdss_mdp:qcom,smmu_sde_sec_cb to group 26
                [drm] probing device qcom,smmu_sde_sec
                [drm] Created domain mdp_s, secure=1
                [drm:sde_wb_drm_init:692] [sde error]invalid params
                [drm:_sde_kms_setup_displays:1550] [sde error]wb bridge 0 init failed, -22
                [drm:sde_encoder_destroy:765] [sde error]enc29 expected 0 num_phys_encs not 1
                [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                [drm] No driver support for vblank timestamp query.
                [drm] Initialized msm_drm 1.3.0 20130625 for ae00000.qcom,mdss_mdp on minor 0
                [drm] cont_splash feature not enabled
                msm_drm ae00000.qcom,mdss_mdp: could not init fbdev: ret=-22
                synx: registered bind ops for cam_sync
                msm_cam_smmu soc:qcom,cam_smmu:msm_cam_smmu_ife: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,cam_smmu:msm_cam_smmu_ife to group 27
                msm_cam_smmu soc:qcom,cam_smmu:msm_cam_smmu_jpeg: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,cam_smmu:msm_cam_smmu_jpeg to group 28
                platform soc:qcom,cam_smmu:msm_cam_icp_fw: assigned reserved memory node pil_camera_region@86200000
                msm_cam_smmu soc:qcom,cam_smmu:msm_cam_smmu_icp: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,cam_smmu:msm_cam_smmu_icp to group 29
                CAM_INFO: CAM-SMMU: cam_smmu_get_memory_regions_info: 3730 [icp] : Discard region specified [0xdff00000 0xe0200000] in [0x10c00000 0xfef00000]
                msm_cam_smmu soc:qcom,cam_smmu:msm_cam_smmu_cpas_cdm: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,cam_smmu:msm_cam_smmu_cpas_cdm to group 30
                msm_cam_smmu soc:qcom,cam_smmu:msm_cam_smmu_fd: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,cam_smmu:msm_cam_smmu_fd to group 31
                cam-cpas ac40000.qcom,cam-cpas: Linked as a consumer to regulator.79
                register_client_adhoc:Client handle 58 cam_ahb
                register_client_adhoc:find path.src 170 dest 512
                register_client_adhoc:Client handle 59 cam_hf_0_mnoc
                register_client_adhoc:find path.src 137 dest 512
                register_client_adhoc:Client handle 60 cam_sf_0_mnoc
                register_client_adhoc:find path.src 171 dest 512
                register_client_adhoc:Client handle 61 cam_sf_icp_mnoc
                msm-dwc3 a800000.ssusb: DWC3 exited from low power mode
                msm_cam_cdm ac4d000.qcom,cpas-cdm0: Linked as a consumer to regulator.79
                xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
                xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
                xhci-hcd xhci-hcd.0.auto: hcc params 0x0230ffe5 hci version 0x110 quirks 0x0000000000010810
                xhci-hcd xhci-hcd.0.auto: irq 450, io mem 0x0a800000
                usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
                usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                usb usb1: Product: xHCI Host Controller
                usb usb1: Manufacturer: Linux 4.19.125 xhci-hcd
                usb usb1: SerialNumber: xhci-hcd.0.auto
                csid_17x acb5200.qcom,csid0: Linked as a consumer to regulator.79
                csid_17x acb5200.qcom,csid0: Linked as a consumer to regulator.75
                csid_17x acc4200.qcom,csid1: Linked as a consumer to regulator.79
                csid_17x acc4200.qcom,csid1: Linked as a consumer to regulator.76
                hub 1-0:1.0: USB hub found
                hub 1-0:1.0: 1 port detected
                csid_lite acd9200.qcom,csid-lite0: Linked as a consumer to regulator.79
                csid_lite acdb400.qcom,csid-lite1: Linked as a consumer to regulator.79
                csid_lite acdd600.qcom,csid-lite2: Linked as a consumer to regulator.79
                xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
                csid_lite acdf800.qcom,csid-lite3: Linked as a consumer to regulator.79
                xhci-hcd xhci-hcd.0.auto: Host supports USB 3.1 Enhanced SuperSpeed
                csid_lite ace1a00.qcom,csid-lite4: Linked as a consumer to regulator.79
                cam_vfe acb4000.qcom,ife0: Linked as a consumer to regulator.79
                cam_vfe acb4000.qcom,ife0: Linked as a consumer to regulator.75
                usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
                usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                usb usb2: Product: xHCI Host Controller
                usb usb2: Manufacturer: Linux 4.19.125 xhci-hcd
                usb usb2: SerialNumber: xhci-hcd.0.auto
                hub 2-0:1.0: USB hub found
                hub 2-0:1.0: 1 port detected
                CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
                CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
                cam_vfe acc3000.qcom,ife1: Linked as a consumer to regulator.79
                cam_vfe acc3000.qcom,ife1: Linked as a consumer to regulator.76
                CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
                CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
                cam_vfe acd9000.qcom,ife-lite0: Linked as a consumer to regulator.79
                cam_vfe acdb200.qcom,ife-lite1: Linked as a consumer to regulator.79
                cam_vfe acdd400.qcom,ife-lite2: Linked as a consumer to regulator.79
                cam_vfe acdf600.qcom,ife-lite3: Linked as a consumer to regulator.79
                cam_vfe ace1800.qcom,ife-lite4: Linked as a consumer to regulator.79
                CAM_ERR: CAM-ISP: cam_ife_hw_mgr_init: 8806 Offline IFE thresholds max 720000000 nom 560000000 min360000000
                CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
                CAM_INFO: CAM-ISP: cam_isp_dev_probe: 163 Camera ISP probe complete
                CAM_INFO: CAM: cam_res_mgr_probe: 685 Enable shared gpio support.
                cam-cci-driver ac4f000.qcom,cci: Linked as a consumer to regulator.79
                CAM_INFO: CAM-CCI: cam_cci_platform_probe: 454 Device Type :0
                cam-cci-driver ac50000.qcom,cci: Linked as a consumer to regulator.79
                CAM_INFO: CAM-CCI: cam_cci_platform_probe: 454 Device Type :1
                cam-csiphy-driver ac6a000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac6a000.qcom,csiphy: Linked as a consumer to regulator.61
                cam-csiphy-driver ac6c000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac6c000.qcom,csiphy: Linked as a consumer to regulator.61
                cam-csiphy-driver ac6e000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac6e000.qcom,csiphy: Linked as a consumer to regulator.61
                cam-csiphy-driver ac70000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac70000.qcom,csiphy: Linked as a consumer to regulator.61
                cam-csiphy-driver ac72000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac72000.qcom,csiphy: Linked as a consumer to regulator.61
                cam-csiphy-driver ac74000.qcom,csiphy: Linked as a consumer to regulator.79
                cam-csiphy-driver ac74000.qcom,csiphy: Linked as a consumer to regulator.61
                CAM_WARN: CAM-ICP: cam_a5_get_dt_properties: 46 QoS need not be set
                cam-a5 ac00000.qcom,a5: Linked as a consumer to regulator.79
                cam-ipe ac9a000.qcom,ipe0: Linked as a consumer to regulator.77
                cam-bps ac7a000.qcom,bps: Linked as a consumer to regulator.74
                cam-jpeg-enc ac53000.qcom,jpegenc: Linked as a consumer to regulator.79
                cam-jpeg-dma ac57000.qcom,jpegdma: Linked as a consumer to regulator.79
                CAM_INFO: CAM-JPEG: cam_jpeg_dev_probe: 162 Camera JPEG probe complete
                cam_fd_hw ac5f000.qcom,fd: Linked as a consumer to regulator.79
                GACT probability NOT on
                Mirror/redirect action on
                netem: version 1.3
                u32 classifier
                Actions configured
                xt_time: kernel timezone is -0000
                IPVS: Registered protocols ()
                IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
                IPVS: ipvs loaded.
                gre: GRE over IPv4 demultiplexor driver
                IPv4 over IPsec tunneling driver
                Initializing XFRM netlink socket
                IPsec XFRM device driver
                NET: Registered protocol family 10
                Segment Routing with IPv6
                mip6: Mobile IPv6
                sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
                NET: Registered protocol family 17
                NET: Registered protocol family 15
                Bridge firewalling registered
                l2tp_core: L2TP core driver, V2.0
                l2tp_ppp: PPPoL2TP kernel driver, V2.0
                l2tp_ip: L2TP IP encapsulation support (L2TPv3)
                l2tp_netlink: L2TP netlink interface
                l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
                l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
                sctp: Hash tables configured (bind 256/256)
                NPU_WARN: npu_bridge_mbox_work: 1180 NPU fw is not loaded
                platform 3d6a000.qcom,gmu: Linked as a consumer to regulator.72
                platform 3d6a000.qcom,gmu: Linked as a consumer to regulator.73
                platform 3d6a000.qcom,gmu:gmu_user: Linked as a consumer to 3da0000.kgsl-smmu
                iommu: Adding device 3d6a000.qcom,gmu:gmu_user to group 32
                platform 3d6a000.qcom,gmu:gmu_kernel: Linked as a consumer to 3da0000.kgsl-smmu
                iommu: Adding device 3d6a000.qcom,gmu:gmu_kernel to group 33
                register_client_adhoc:Client handle 62 grp3d
                register_client_adhoc:find path.src 26 dest 10036
                register_client_adhoc:Client handle 63 cnoc
                query_client_usecase_all: query_start
                kgsl-3d 3d00000.qcom,kgsl-3d0: Linked as a consumer to regulator.72
                kgsl-3d 3d00000.qcom,kgsl-3d0: Linked as a consumer to regulator.73
                platform 3da0000.qcom,kgsl-iommu:gfx3d_user: Linked as a consumer to 3da0000.kgsl-smmu
                iommu: Adding device 3da0000.qcom,kgsl-iommu:gfx3d_user to group 34
                platform 3da0000.qcom,kgsl-iommu:gfx3d_secure: Linked as a consumer to 3da0000.kgsl-smmu
                iommu: Adding device 3da0000.qcom,kgsl-iommu:gfx3d_secure to group 35
                ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[4, 4], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 1
                ufshcd-qcom 1d84000.ufshc: ufshcd_wb_config: Write Booster Configured
                scsi 0:0:0:49488: Well-known LUN KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:49476: Well-known LUN KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:49456: Well-known LUN KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:0: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:1: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:2: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:3: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:4: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                scsi 0:0:0:5: Direct-Access KIOXIA THGJFAT0T44BAILB 1001 PQ: 0 ANSI: 6
                sd 0:0:0:0: Power-on or device reset occurred
                sd 0:0:0:1: Power-on or device reset occurred
                sd 0:0:0:0: [sda] Write Protect is off
                sd 0:0:0:0: [sda] Mode Sense: 00 32 00 10
                sd 0:0:0:2: Power-on or device reset occurred
                sd 0:0:0:0: [sda] Optimal transfer size 524288 bytes
                sd 0:0:0:3: Power-on or device reset occurred
                sd 0:0:0:1: [sdb] Write Protect is off
                sd 0:0:0:1: [sdb] Mode Sense: 00 32 00 10
                sd 0:0:0:1: [sdb] Optimal transfer size 524288 bytes
                sd 0:0:0:2: [sdc] Write Protect is off
                sd 0:0:0:2: [sdc] Mode Sense: 00 32 00 10
                sd 0:0:0:2: [sdc] Optimal transfer size 524288 bytes
                sd 0:0:0:3: [sdd] Write Protect is off
                sd 0:0:0:3: [sdd] Mode Sense: 00 32 00 10
                sd 0:0:0:3: [sdd] Optimal transfer size 524288 bytes
                sd 0:0:0:4: Power-on or device reset occurred
                sd 0:0:0:5: Power-on or device reset occurred
                usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
                sps:BAM 0x000000000a704000 is registered.
                sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9
                qcom,haptics c440000.qcom,spmi:qcom,pm8150b@3:qcom,haptics@c000: Linked as a consumer to regulator.89
                sdb: sdb1 sdb2
                sd 0:0:0:4: [sde] Write Protect is off
                sd 0:0:0:4: [sde] Mode Sense: 00 32 00 10
                sd 0:0:0:5: [sdf] Write Protect is off
                sd 0:0:0:5: [sdf] Mode Sense: 00 32 00 10
                sd 0:0:0:4: [sde] Optimal transfer size 524288 bytes
                input: qti-haptics as /devices/platform/soc/c440000.qcom,spmi/spmi-0/spmi0-03/c440000.qcom,spmi:qcom,pm8150b@3:qcom,haptics@c000/input/input2
                sd 0:0:0:5: [sdf] Optimal transfer size 524288 bytes
                sdc: sdc1 sdc2
                sdd: sdd1 sdd2 sdd3 sdd4
                sdf: sdf1 sdf2 sdf3 sdf4 sdf5 sdf6 sdf7 sdf8 sdf9
                sde: sde1 sde2 sde3 sde4 sde5 sde6 sde7 sde8 sde9 sde10 sde11 sde12 sde13 sde14 sde15 sde16 sde17 sde18 sde19 sde20 sde21 sde22 sde23 sde24 sde25 sde26 sde27 sde28 sde29 sde30 sde31 sde32 sde33 sde34 sde35 sde36 sde37 sde38 sde39 sde40 sde41 sde42 sde43 sde44 sde45 sde46 sde47 sde48 sde49 sde50 sde51 sde52 sde53 sde54 sde55 sde56 sde57 sde58 sde59 sde60
                qcom,qpnp-smb5 c440000.qcom,spmi:qcom,pm8150b@2:qcom,qpnp-smb5: Linked as a consumer to regulator.86
                pm8150b_charger: jeita_update_work: Incorrect fastchg-current-ma or max-voltage-uv
                SMB5 status - usb:present=1 type=0 batt:present = 1 health = 1 charge = 1
                QPNP SMB5 probed successfully
                Error registering TZ zone:-19 for dt_ch:77
                tmc_etr_bam_init: setting SPS_BAM_SMMU_EN flag with (6048000.tmc)
                sps:BAM 0x0000000006064000 is registered.
                coresight-stm 6002000.stm: STM32 initialized
                msm-usb-ssphy-qmp 88e8000.ssphy: No separate ID extcon device
                register_client_adhoc:find path.src 61 dest 512
                register_client_adhoc:find path.src 61 dest 676
                register_client_adhoc:find path.src 1 dest 583
                register_client_adhoc:Client handle 64 usb0
                msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.86
                core_ctl: Creating CPU group 0
                core_ctl: Init CPU0 state
                core_ctl: Init CPU1 state
                core_ctl: Init CPU2 state
                core_ctl: Init CPU3 state
                core_ctl: Creating CPU group 4
                core_ctl: Init CPU4 state
                core_ctl: Init CPU5 state
                core_ctl: Init CPU6 state
                core_ctl: Creating CPU group 7
                core_ctl: Init CPU7 state
                registered taskstats version 1
                Loading compiled-in X.509 certificates
                Key type ._fscrypt registered
                Key type .fscrypt registered
                Key type fscrypt-provisioning registered
                Btrfs loaded, crc32c=crc32c-generic
                AppArmor: AppArmor sha1 policy hashing enabled
                spss_utils [spss_parse_dt]: iar_buf_addr [0x8bef0000].
                spss_utils [spss_probe]: Initialization completed ok, firmware_name [spss2p].
                adsprpc: init_secure_vmid_list: secure VMID = 22
                adsprpc: init_secure_vmid_list: secure VMID = 37
                adsprpc: fastrpc_probe: service location enabled for avs/audio (audio_pdr_adsprpc)
                adsprpc: fastrpc_probe: service location enabled for tms/servreg (sensors_pdr_adsprpc)
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb1: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb1 to group 36
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb2: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb2 to group 37
                Error: swapper/0: fastrpc_cb_probe: failed to create debugfs global file
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb3: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb3 to group 38
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb4: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb4 to group 39
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb5: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb5 to group 40
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb6: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb6 to group 41
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb7: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb7 to group 42
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb8: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb8 to group 43
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb9: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb9 to group 44
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb10: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb10 to group 45
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb11: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb11 to group 46
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb12: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb12 to group 47
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb13: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb13 to group 48
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb14: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb14 to group 49
                fastrpc soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb15: Linked as a consumer to 15000000.apps-smmu
                iommu: Adding device soc:qcom,msm_fastrpc:qcom,msm_fastrpc_compute_cb15 to group 50
                • E Offline
                  E Offline
                  ErezI
                  4th part
                  adsprpc: fastrpc_device_init: SSR notifier registered for adsp
                  adsprpc: fastrpc_device_init: SSR notifier registered for modem
                  adsprpc: fastrpc_device_init: SSR notifier registered for slpi
                  adsprpc: fastrpc_device_init: SSR notifier registered for cdsp
                  ngd_msm_ctrl 3ac0000.slim: Linked as a consumer to 15000000.apps-smmu
                  iommu: Adding device 3ac0000.slim to group 51
                  input: gpio-keys as /devices/platform/soc/soc:gpio_keys/input/input3
                  msm notifier probed successfully
                  CAM_ERR: CAM-CCI: cam_cci_assign_fops: 528 Invalid dev node:000000002b35a95b offset: 0
                  cfg80211: Loading compiled-in X.509 certificates for regulatory database
                  cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                  cam_cc_sleep_clk_src: CXO configuration failed
                  msm_bus_late_init: Remove handoff bw requests
                  regulator_proxy_consumer_remove_all: removing regulator proxy consumer requests
                  ALSA device list:
                  No soundcards found.
                  usb 1-1: new high-speed USB device number 2 using xhci-hcd
                  EXT4-fs (sda9): recovery complete
                  EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: (null)
                  VFS: Mounted root (ext4 filesystem) on device 8:9.
                  devtmpfs: mounted
                  Freeing unused kernel memory: 4096K
                  Run /sbin/init as init process
                  ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
                  usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
                  usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                  hub 1-1:1.0: USB hub found
                  hub 1-1:1.0: 3 ports detected
                  8188eu: loading out-of-tree module taints kernel.
                  usbcore: registered new interface driver 8188eu
                  RTW: module init start
                  RTW: rtl8821cu v5.12.0.4-1-g9241a6516.20210916_COEX20200730-5151
                  RTW: rtl8821cu BT-Coex version = COEX20200730-5151
                  usbcore: registered new interface driver rtl8821cu
                  RTW: module init ret=0
                  usbcore: registered new interface driver rtl88XXau
                  ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
                  ** trace_printk() being used. Allocating extra memory. **
                  ** This means that this is a DEBUG kernel and it is **
                  ** unsafe for production use. **
                  ** If you see this message and you are not debugging **
                  ** the kernel, report this immediately to your vendor! **
                  kona-pinctrl f000000.pinctrl: pin GPIO_130 already requested by a88000.i2c; cannot claim for soc:wsa_spkr_en2_pinctrl
                  kona-pinctrl f000000.pinctrl: pin-130 (soc:wsa_spkr_en2_pinctrl) status -22
                  kona-pinctrl f000000.pinctrl: could not request pin 130 (GPIO_130) from group gpio130 on device f000000.pinctrl
                  msm-cdc-pinctrl soc:wsa_spkr_en2_pinctrl: Error applying setting, reverse things back
                  msm-cdc-pinctrl soc:wsa_spkr_en2_pinctrl: msm_cdc_pinctrl_probe: set cdc gpio sleep state fail: -22
                  kona-pinctrl f000000.pinctrl: invalid function func2 in map table
                  usb 1-1.2: new high-speed USB device number 3 using xhci-hcd
                  usb 1-1.2: New USB device found, idVendor=13b1, idProduct=0041, bcdDevice=30.00
                  usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
                  usb 1-1.2: Product: Linksys USB3GIGV1
                  usb 1-1.2: Manufacturer: Linksys
                  usb 1-1.2: SerialNumber: 000001000000
                  usb 1-1.2: reset high-speed USB device number 3 using xhci-hcd
                  r8152 1-1.2:1.0 eth0: v1.09.9
                  QCOM-STEPCHG: get_step_chg_jeita_setting_from_profile: Couldn't find profile
                  EXT4-fs (sde9): mounted filesystem with ordered data mode. Opts: data=ordered,noauto_da_alloc,discard
                  EXT4-fs (sda7): VFS: Can't find ext4 filesystem
                  EXT4-fs (sda8): VFS: Can't find ext4 filesystem
                  audit: type=1400 audit(1693915631.812:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1244 comm="apparmor_parser"
                  audit: type=1400 audit(1693915631.812:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1244 comm="apparmor_parser"
                  audit: type=1400 audit(1693915631.812:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1244 comm="apparmor_parser"
                  EXT4-fs (sda2): VFS: Can't find ext4 filesystem
                  Mass Storage Function, version: 2009/09/11
                  LUN: removable file: (no medium)
                  file system registered
                  f_cdev_alloc: port_name:at_usb0 (fffffffcd02e5c00) portno:(0)
                  subsys-pil-tz 8300000.qcom,turing: cdsp: loading from 0x0000000087800000 to 0x0000000088c00000
                  binder: 1251:1251 transaction failed 29189/-22, size 0-0 line 3091
                  zram0: detected capacity change from 0 to 4021985280
                  f_cdev_alloc: port_name:at_usb1 (fffffffcd1399400) portno:(1)
                  Adding 3927716k swap on /dev/zram0. Priority:10 extents:1 across:3927716k SS
                  gsi_set_inst_name: prot_id = 2, prev inst do not freed yet
                  gsi_set_inst_name: failed to find prot id for gps instance
                  subsys-pil-tz 8300000.qcom,turing: cdsp: Brought out of reset
                  subsys-pil-tz 8300000.qcom,turing: Subsystem error monitoring/handling services are up
                  subsys-pil-tz 8300000.qcom,turing: cdsp: Power/Clock ready interrupt received
                  -200258072:Entered
                  adsprpc: fastrpc_restart_notifier_cb: cdsp subsystem is up
                  -200258072:SMD QRTR driver probed
                  adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for cdsp
                  sysmon-qmi: ssctl_new_server: Connection established between QMI handle and cdsp's SSCTL service
                  coresight-remote-etm soc:turing_etm0: Connection established between QMI handle and 13 service
                  IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                  diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 5
                  configfs-gadget a600000.dwc3: failed to start g1: -19
                  subsys-restart: __subsystem_get(): Changing subsys fw_name to slpi
                  servloc: service_locator_new_server: Connection established with the Service locator
                  servloc: init_service_locator: Service locator initialized
                  adsprpc: fastrpc_get_service_location_notify: PDR notifier for adsp registered for msm/adsp/audio_pd (audio_pdr_adsprpc)
                  adsprpc: fastrpc_get_service_location_notify: audio_pdr_adsprpc (msm/adsp/audio_pd) PDR service for adsp is uninitialized
                  audio_notifer_reg_service: service PDR_ADSP is in use
                  subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                  CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                  CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                  CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
                  read descriptors
                  read strings
                  android_work: did not send uevent (0 0 0000000000000000)
                  subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
                  qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
                  QSEECOM: qseecom_load_app: App (haventkn) does'nt exist, loading apps for first time
                  CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base: pK-error, M0_Q1 NACK ERROR: 0x10000000
                  CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0xc0:
                  CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                  CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                  CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
                  • E ErezI
                    4th part
                    ALSA device list:
                    devtmpfs: mounted
                    -200258072:Entered
                    read descriptors
                    read strings
                    @ErezI Is that from journalctl -u voxl-px4 or the whole dmesg log?
                    E 1 Reply Last reply
                      E Offline
                      E Offline
                      ErezI
                      @tom
                      whole dmesg log
                      Till your answer and a full solution,
                      I used make.ext4 in order to revive the ext4 on sda8 and succeed in loading the data.mount
                      process with enabling some Ubuntus' disabled processes.
                      After these actions, the PX4 process load & works (voxl-px4).
                      Now I am getting the same problem & errors with mounting /data/modalai & /etc/modalai , and trying, meanwhile, to revive these volumes in the same manner.
                      Does the full SDK flash/burning, also burn the Ubuntu?
                      If not, do you have a full board revive/unbrick process & images?
                      Erez
                      tomT E 2 Replies Last reply
                      • E ErezI
                        @tom
                        whole dmesg log
                        Erez
                        wrote on last edited by tom
                        #11
                        @ErezI I need the output of journalctl -u voxl-px4 when it crashes, not the dmesg log.
                        A factory flash of SDK 1.0 would likely fix the issue as it would overwrite all of the partitions
                        cd voxl2_SDK_1.0.0
                        cd system-image
                        ./flash-system-image.sh -f
                        cd ..
                        cd voxl-suite
                        ./offline-install.sh
                        The "-f" flag in flash-system-image is what re-flashes the partitions that aren't normally flashed otherwise
                        • E ErezI
                          @tom
                          whole dmesg log
                          Erez
                          E Offline
                          E Offline
                          ErezI
                          @ErezI
                          I think we did it, but i'll try again.
