  3. Error with VOXL Suite Offline Packages
3 Posts 1 Posters 375 Views
  • S Offline
    S Offline
    SMRazaRizvi
    wrote on last edited by SMRazaRizvi
    The following error shows up when I apt update inside my Sentinel drone.
    Get:3 file:/data/voxl-suite-offline-packages ./ Packages
    Ign:3 file:/data/voxl-suite-offline-packages ./ Packages
    Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en
    Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en
    Err:3 file:/data/voxl-suite-offline-packages ./ Packages
      File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    Hit:5 https://download.docker.com/linux/ubuntu bionic InRelease
    Ign:6 http://voxl-packages.modalai.com qrb5165 InRelease
    Hit:7 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
    Hit:8 http://packages.ros.org/ros/ubuntu bionic InRelease
    Hit:9 http://voxl-packages.modalai.com qrb5165 Release
    Hit:10 http://packages.ros.org/ros2/ubuntu bionic InRelease
    Hit:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
    Ign:12 http://voxl-packages.modalai.com qrb5165 Release.gpg
    Hit:13 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
    Hit:14 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
    Reading package lists... Done
    N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
    W: Skipping acquire of configured file 'stable/binary-arm64/Packages' as repository 'http://voxl-packages.modalai.com qrb5165 InRelease' doesn't have the component 'stable' (component misspelt in sources.list?)
    W: Skipping acquire of configured file 'stable/i18n/Translation-en' as repository 'http://voxl-packages.modalai.com qrb5165 InRelease' doesn't have the component 'stable' (component misspelt in sources.list?)
    E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages  File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    I also tried flashing the recent VOXL SDK but it gives the same error and fails to install the voxl-suite
    Please help
    • S Offline
      S Offline
      SMRazaRizvi
      @Moderator Please respond as it's urgent. I am unable to install the VOXL SDK on my Sentinel drone.
      • S Offline
        S Offline
        SMRazaRizvi
        There were some issues with the System, causing this problem.
        Solved by a fresh flash of the system image as well as the VOXL SDK.
