  3. Voxl 2 mini USB external drive mounting in syslog but not showing up for df or apps.
voxl-2-mini
2 Posts 2 Posters 890 Views 1 Watching
  • B Offline
    B Offline
    Brendon
    Here is the output from Syslog:
    Mar  2 12:59:59 m0104 kernel: [  120.224638] usbpd usbpd0: Type-C Sink connected
    Mar  2 12:59:59 m0104 kernel: [  120.225257] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.90
    Mar  2 13:00:00 m0104 kernel: [  120.300716] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
    Mar  2 13:00:00 m0104 kernel: [  120.303802] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    Mar  2 13:00:00 m0104 kernel: [  120.303816] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Mar  2 13:00:00 m0104 kernel: [  120.303826] usb usb3: Product: xHCI Host Controller
    Mar  2 13:00:00 m0104 kernel: [  120.303834] usb usb3: Manufacturer: Linux 4.19.125 xhci-hcd
    Mar  2 13:00:00 m0104 kernel: [  120.303843] usb usb3: SerialNumber: xhci-hcd.1.auto
    Mar  2 13:00:00 m0104 kernel: [  120.310048] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    Mar  2 13:00:00 m0104 kernel: [  120.310519] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    Mar  2 13:00:00 m0104 kernel: [  120.310531] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Mar  2 13:00:00 m0104 kernel: [  120.310540] usb usb4: Product: xHCI Host Controller
    Mar  2 13:00:00 m0104 kernel: [  120.310549] usb usb4: Manufacturer: Linux 4.19.125 xhci-hcd
    Mar  2 13:00:00 m0104 kernel: [  120.310557] usb usb4: SerialNumber: xhci-hcd.1.auto
    Mar  2 13:00:00 m0104 kernel: [  120.311521] hub 4-0:1.0: USB hub found
    Mar  2 13:00:00 m0104 kernel: [  120.311673] hub 4-0:1.0: 1 port detected
    Mar  2 13:00:00 m0104 kernel: [  120.628570] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
    Mar  2 13:00:00 m0104 kernel: [  120.646650] usb 4-1: New USB device found, idVendor=105d, idProduct=0009, bcdDevice= 1.00
    Mar  2 13:00:00 m0104 kernel: [  120.646664] usb 4-1: New USB device strings: Mfr=1, Product=3, SerialNumber=2
    Mar  2 13:00:00 m0104 kernel: [  120.646674] usb 4-1: Product: U432TNJGR-XN000-D
    Mar  2 13:00:00 m0104 kernel: [  120.646683] usb 4-1: Manufacturer: Delkin Devices
    Mar  2 13:00:00 m0104 kernel: [  120.646692] usb 4-1: SerialNumber: 29910500000000000065
    Mar  2 13:00:00 m0104 kernel: [  120.649173] usb-storage 4-1:1.0: USB Mass Storage device detected
    Mar  2 13:00:00 m0104 kernel: [  120.650176] scsi host1: usb-storage 4-1:1.0
    Mar  2 13:00:01 m0104 kernel: [  121.665628] scsi 1:0:0:0: Direct-Access     DDINC    USB DISK 3.1     1809 PQ: 0 ANSI: 6
    Mar  2 13:00:01 m0104 usbmount[2351]: loaded usbmount configurations
    Mar  2 13:00:01 m0104 usbmount[2351]: creating /var/run/usbmount directory
    Mar  2 13:00:01 m0104 usbmount[2351]: trying to acquire lock /var/run/usbmount/.mount.lock
    Mar  2 13:00:01 m0104 usbmount[2351]: acquired lock /var/run/usbmount/.mount.lock
    Mar  2 13:00:01 m0104 usbmount[2351]: /dev/sdg contains filesystem type ext4
    Mar  2 13:00:01 m0104 usbmount[2351]: mountpoint /Storage is available for /dev/sdg
    Mar  2 13:00:01 m0104 usbmount[2351]: executing command: mount -text4 -osync,noexec,nodev,noatime,nodiratime /dev/sdg /Storage
    Mar  2 13:00:01 m0104 kernel: [  121.883601] EXT4-fs (sdg): recovery complete
    Mar  2 13:00:01 m0104 kernel: [  121.883626] EXT4-fs (sdg): mounted filesystem with ordered data mode. Opts: (null)
    Mar  2 13:00:01 m0104 usbmount[2351]: executing command: run-parts /etc/usbmount/mount.d
    Mar  2 13:00:01 m0104 usbmount[2351]: usbmount execution finished
    But after this completes, the drive is not mounted on /Storage is not mounted and /dev/sdg doesn't appear under df
    Thanks for any insight.
    • B Brendon
      @Brendon Does your device show up with sudo fdisk -l?
      On my setup, I tested with a random SanDisk drive:
      The last device in the list is
      Device     Boot Start      End  Sectors  Size Id Type
      /dev/sdg1        2048 60088319 60086272 28.7G 83 Linux
      I can then create a dir to mount to, i.e.:
      sudo mkdir /media/USB-Drive
      and mount the drive:
      sudo mount /dev/sdg1 /media/USB-Drive/
      and then see the file on my drive:
      voxl2:~$ ls /media/USB-Drive/
      hello
