  3. Unable to setup compass
6 Posts 3 Posters 904 Views 1 Watching
  • R Offline
    R Offline
    RiveraDn
    Hello there!
    I tried to configure my VOXL2 (1.0.0) with a custom airframe using QGC. However, I encountered an error message when attempting to calibrate the compass:
    "Start the individual calibration steps by clicking one of the buttons to the left.
    [cal] calibration started: 2 mag
    No mags found
    [cal] calibration failed: mag"
    Any information or assistance would be greatly appreciated!
    Cheers.
    • R RiveraDn
      Hello there!
      No mags found
      Cheers.
      @RiveraDn What magnetometer are you using? It appears that your magnetometer driver is not working properly.
      R 1 Reply Last reply
        R Offline
        R Offline
        RiveraDn
        Hey @Eric-Katzfey, I'm using the GPS included with the VOXL2 Flight Deck (https://www.modalai.com/products/voxl-2-gps-mag-rc-assembly?variant=40673762836531).
        Do you have any tips on how to update/fix the driver? Just a side note, it was working perfectly fine before I updated to 1.0.0 (previous suite was 0.9.4).
        Thanks in advance!
        • R RiveraDn
          Thanks in advance!
          @RiveraDn What about the GPS, is that working fine? And the big LED on top of the unit, is it illuminating?
            R Offline
            R Offline
            RiveraDn
            @Eric-Katzfey As for now, it is blinking with a red color. I was able to do a compass calibration, but it does not show the location in the map. I'll try to investigate on the matter. Thank you for your responses.
            K 1 Reply Last reply
            • R RiveraDn
              K Offline
              K Offline
              kailyGen
              I have the same problem before — turns out the compass setup finally worked after I did a full sensor recalibration in QGroundControl and made sure the GPS/compass was facing the right direction. Worth a try if you haven’t done that yet!
              You can also try this tool for free. https://123compass.org/
