    4-in-1 ESC mini with VOXL2 - Current is 0
    ESCs
    • Aidan DempsterA
      Aidan Dempster
      We are testing the 4-in-1 esc (mini) with the VOXL2 (not mini). After connecting the J18 port to the ESC with the described pinouts we are able to spin our motors and interact with them through PX4. All metadata expected is available. The only problem is that the current measurement is always 0.
      I have included some output of the voxl-esc spin command
      Found voxl-esc tools bin version: 1.2
      VOXL Platform: M0054
      Detected VOXL2 M0054 or M0104!
      Found previous connection information in .voxl_esc_cache ..
      Prioritizing /dev/slpi-uart-2 @ 2000000
      Sending library name request: libslpi_uart_bridge_slpi.so
      INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
      INFO: Detected protocol: firmware
      INFO: Additional Information:
      INFO: ---------------------
      	Board      : version 40: ModalAi 4-in-1 ESC (M0129-3)
      	UID        : 0x2039333557555304003D001F
      	Firmware   : version   38, hash 83faccfa
      	Bootloader : version  184, hash 10bf24c8
      	UID        : 0x2039333557555304003D001A
      	UID        : 0x2039333557555304003D001C
      	UID        : 0x2039333557555304003D0021
      [GCC 8.4.0]
      Output when testing ESC 1 (which has a motor attached)
      [2.665] (1) RPM: 2830, PWR: 5, VOLTAGE: 12.384V, TEMPERATURE: 37.71C, CURRENT: 0.000A
      [2.676] (1) RPM: 2830, PWR: 5, VOLTAGE: 12.384V, TEMPERATURE: 37.71C, CURRENT: 0.000A
      [2.684] (1) RPM: 2835, PWR: 5, VOLTAGE: 12.385V, TEMPERATURE: 37.72C, CURRENT: 0.000A
      [2.695] (1) RPM: 2836, PWR: 5, VOLTAGE: 12.381V, TEMPERATURE: 37.74C, CURRENT: 0.000A
      [2.707] (1) RPM: 2836, PWR: 5, VOLTAGE: 12.381V, TEMPERATURE: 37.74C, CURRENT: 0.000A
      [2.714] (1) RPM: 2866, PWR: 5, VOLTAGE: 12.391V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.725] (1) RPM: 2834, PWR: 5, VOLTAGE: 12.373V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.736] (1) RPM: 2834, PWR: 5, VOLTAGE: 12.373V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.744] (1) RPM: 2834, PWR: 5, VOLTAGE: 12.376V, TEMPERATURE: 37.75C, CURRENT: 0.000A
      [2.755] (1) RPM: 2831, PWR: 5, VOLTAGE: 12.378V, TEMPERATURE: 37.77C, CURRENT: 0.000A
      [2.767] (1) RPM: 2831, PWR: 5, VOLTAGE: 12.378V, TEMPERATURE: 37.77C, CURRENT: 0.000A
      [2.774] (1) RPM: 2826, PWR: 5, VOLTAGE: 12.369V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.786] (1) RPM: 2828, PWR: 5, VOLTAGE: 12.375V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.796] (1) RPM: 2828, PWR: 5, VOLTAGE: 12.375V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.804] (1) RPM: 2838, PWR: 5, VOLTAGE: 12.376V, TEMPERATURE: 37.76C, CURRENT: 0.000A
      [2.814] (1) RPM: 2832, PWR: 5, VOLTAGE: 12.377V, TEMPERATURE: 37.77C, CURRENT: 0.000A
      We only have a motor connected to ESC 1, but I do see some logging for non-zero current on ESC 3. The RPM values are obviously bunk because there is nothing attached, but I do wonder if something went wrong in the hardware for logging current with ESCs 0-2.
      Logging for the test of ESC 3 (with no motor attached):
      [4.930] (3) RPM: 991, PWR: 0, VOLTAGE: 12.343V, TEMPERATURE: 44.29C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.343V, BOARD_CURRENT: 0.024A
      [4.935] (3) RPM: 991, PWR: 0, VOLTAGE: 12.343V, TEMPERATURE: 44.29C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.343V, BOARD_CURRENT: 0.024A
      [4.951] (3) RPM: 1021, PWR: 0, VOLTAGE: 12.350V, TEMPERATURE: 44.31C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.350V, BOARD_CURRENT: 0.008A
      [4.955] (3) RPM: 1021, PWR: 0, VOLTAGE: 12.350V, TEMPERATURE: 44.31C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.350V, BOARD_CURRENT: 0.008A
      [4.971] (3) RPM: 1051, PWR: 0, VOLTAGE: 12.341V, TEMPERATURE: 44.32C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.341V, BOARD_CURRENT: -0.024A
      [4.975] (3) RPM: 1051, PWR: 0, VOLTAGE: 12.341V, TEMPERATURE: 44.32C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.341V, BOARD_CURRENT: -0.024A
      [4.991] (3) RPM: 1081, PWR: 0, VOLTAGE: 12.350V, TEMPERATURE: 44.30C, CURRENT: 0.000A, BOARD_VOLTAGE: 12.350V, BOARD_CURRENT: -0.016A
      Is there a most likely reason for us to be seeing this behavior?
        Alex Kushleyev ModalAI Team @Aidan Dempster
        @Aidan-Dempster
        The Mini ESC has one current measurement (total current going into the board) and it is measured by the ESC ID3.
        I understand it is a little confusing, we can improve the test script.
        Are you just trying to spin one motor (ESC 1) and see the total current?
        Aidan DempsterA 1 Reply Last reply Reply Quote 0
        • Aidan DempsterA
          Aidan Dempster @Alex Kushleyev
          @Alex-Kushleyev
          Ah, thank you. That makes sense. We are currently using 2 of the ESCs and want to record the total current. I see how we could do that now through the testing script, but I am still running into trouble. We would like to be able to monitor our usage in flight through PX4, but looking through the message definitions I don't see anything that would supply the board current And all currents are reported as 0 as I would now expect.
          Has the ability to get this total board current been implemented in ModalIO?
          struct esc_status_s {
          	uint64_t timestamp;
          	uint16_t counter;
          	uint8_t esc_count;
          	uint8_t esc_connectiontype;
          	uint8_t esc_online_flags;
          	uint8_t esc_armed_flags;
          	uint8_t _padding0[2]; // required for logger
          	struct esc_report_s esc[8];
          struct esc_report_s {
          	uint64_t timestamp;
          	uint32_t esc_errorcount;
          	int32_t esc_rpm;
          	float esc_voltage;
          	float esc_current;
          	float esc_temperature;
          	uint16_t failures;
          	uint8_t esc_address;
          	uint8_t esc_cmdcount;
          	uint8_t esc_state;
          	uint8_t actuator_function;
          	int8_t esc_power;
          	uint8_t _padding0[5]; // required for logger
            @Aidan-Dempster ,
            Good question.
            As you may already know, the 4 ESCs normally only send their feedback status packet when the host (flight controller) queries them. The feedback query bit is set for one ESC at a time when sending out the control packet to the 4 ESCs. The Flight controller requests the feedback from one ESC at a time in round robin fashion in order to avoid collisions on UART line. This is true for all ModalAI ESCs.
            Now, the mini ESC M0129 has a special setup in terms of current sensing. IDs 0-2 do not have any current measurement, but ID3 measures the total current. In order to avoid confusion with individual current measurement, we have added a new Power Status message, which ID3 sends out in addition to the standard feedback. So when the Flight Controller asks ID3 to send feedback, the ID3 will send back the normal feedback packet and the power status packet. Here is a link in PX4 for your reference:
            parsing of standard packet:
            https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/actuators/modal_io/modal_io.cpp#L303
            parsing of power status and sending out battery status to PX4:
            https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/actuators/modal_io/modal_io.cpp#L393
            It looks like the power status feature is only in voxl-dev branch of PX4 code at the moment.
            Hopefully that helps! Let me know if you have any other questions.
