  3. Pre-arm Check Failure: Compass Sensor 0 Missing
voxl-2-io
2 Posts 2 Posters 1.8k Views 1 Watching
  • W Offline
    W Offline
    Will
    Dear ModalAI team,
    We have encountered an issue with the pre-arm check on our setup, and we would appreciate your assistance in resolving it.
    Our configuration consists of an IO board connected to VOXL2, along with a DSMX RC receiver connected to the IO board using the MCBL-00005 cable. We have successfully bound the RC receiver using the following commands:
    px4-qshell px4io safety_on
    px4-qshell px4io bind dsmx8
    However, when using QGroundControl (QGC), we receive an error indicating the absence of Compass Sensor 0. In an attempt to mitigate the issue, we have made the following adjustments:
    1. We set SYS_HAS_MAG to 0 to disable the requirement for an electronic compass.
    2. We set COM_ARM_WO_GPS to 1 to allow arming without a GPS connected to VOXL2's J19 port.
    Despite these modifications, the pre-arm check continues to fail. We kindly request your advice on how we can successfully pass the pre-arm check in a scenario where there is no u-blox GPS connected to VOXL2's J19 port.
    Thank you for your attention to this matter, and we look forward to your guidance.
    Best regards,
    Will
    • W Will
      Dear ModalAI team,
      Best regards,
      Will
      @Will Can you also try setting EKF2_MAG_TYPE to 5?
