  3. Random PX4 Mavlink Disconnected
3 Posts 2 Posters 695 Views 2 Watching
  • TjarkT Offline
    TjarkT Offline
    Tjark
    We have an issue where sometimes the drone drops out of the air. Looking at the journalctl logging we see a WARNING: PX4 Mavlink Disconnected message at the time when it drops. Also, a few seconds before it has disconnected we see the message kernel: ==> rtl8188e_iol_efuse_patch. Has anyone else experienced this or has an idea what could be causing this?
    Also, I saw that there are two ways to get the WARNING: PX4 Mavlink Disconnect. One with a disconnect callback and one with a timeout. Would it be an idea to tell in the logging message of the timeout that the disconnect is caused by a timeout?
    This is the software we have running:
    system-image: 1.5.2-M0054-14.1a-perf-nightly-20221219
    kernel:       #1 SMP PREEMPT Mon Dec 19 02:17:54 UTC 2022 4.19.125
    hw version:   M0054
    voxl-suite:   0.9.5
    PHIL:~$ voxl-inspect-services -v
     Service Name         |  Version  |  Enabled  |   Running   |  CPU Usage
     docker-autorun       |    1.2.4  | Disabled  | Not Running |
     docker-daemon        |    1.2.4  | Disabled  | Not Running |
     modallink-relink     |   0.16.1  | Disabled  | Not Running |
     voxl-camera-server   |    1.3.7  |  Enabled  |   Running   |     0.0
     voxl-cpu-monitor     |    0.3.0  |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |    0.1.0  | Disabled  | Not Running |
     voxl-imu-server      |    0.5.0  |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |    0.3.0  |  Enabled  |   Running   |     0.0
     voxl-modem           |   0.16.1  | Disabled  | Not Running |
     voxl-portal          |    0.5.0  | Disabled  | Not Running |
     voxl-px4-imu-server  |    0.1.2  | Disabled  | Not Running |
     voxl-px4             |  1.12.31  |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |    0.8.2  |  Enabled  |   Running   |     0.0
     voxl-remote-id       |    0.0.5  | Disabled  | Not Running |
     voxl-softap          |    0.1.5  | Disabled  | Not Running |
     voxl-static-ip       |    0.1.5  | Disabled  | Not Running |
     voxl-streamer        |    0.4.1  | Disabled  | Not Running |
     voxl-tag-detector    |    0.0.4  | Disabled  | Not Running |
     voxl-tflite-server   |    0.3.1  | Disabled  | Not Running |
     voxl-time-sync       |    1.2.2  | Disabled  | Not Running |
     voxl-vision-px4      |    1.4.0  |  Enabled  |   Running   |     0.0
     voxl-wait-for-fs     |    1.2.2  |  Enabled  |  Completed  |
    • TjarkT Tjark
      hw version:   M0054
      voxl-suite:   0.9.5
      @Tjark The only obvious thing I notice from your version info is that your system image is a bit out of date for that voxl-suite version, I would expect it to be version 1.5.5. I'd recommend re-flashing to the 0.9.5 release
      TjarkT 1 Reply Last reply
        TjarkT Offline
        TjarkT Offline
        Tjark
        @tom Yes, thanks! That is a good idea. I will do that.
        I was looking at the release page of the system image and saw this line with 1.5.3 internal release:
        HLOS
            Added service file that changes SLPI restart level to avoid board crash when SLPI crashes
        What is SLPI and could you describe a little bit more what kind of issues you saw when SLPI crashed?
        I also sometimes saw px4io io_reg_get(4,0,15): data error -5 in the logging so maybe that could be related?
