  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. How to compile and deploy a custom voxl- script to Sentinel
8 Posts 2 Posters 1.1k Views 1 Watching
  • Hersch NathanH Offline
    Hersch Nathan
    Hey all,
    I have written a voxl-record-battery script to record battery information to a csv file. I have based it off of VOXL Inspect Battery. How do I compile and deploy this code to a Sentinel?
    The code is written in C++ and I have the voxl-docker installed.
    Thank you for you help.
    • Hersch NathanH Hersch Nathan
      Hey all,
      @Hersch-Nathan See here: https://docs.modalai.com/build-environments/#voxl-cross-for-cross-compiling-applications
      Binaries built in voxl-cross will be able to be executed on VOXL2
      Hersch NathanH 1 Reply Last reply
        Hersch Nathan
        @tom
        Thank you so much for your help. I was able to build, make, and deploy my package with Voxl-Cross. However, I can not seem to get it to run from the command line.
        I wrote it similar to voxl-logger and voxl-inspect-battery. Do you have any advice?
          @tom
          @Hersch-Nathan Do you have any error messages or info to provide so we can determine what the issue is?
            Hersch Nathan
            @tom The only error I get is when I try to call the code from the terminal on the Sentinel. See below:
            voxl2:~$ voxl-recorder-battery
            -bash: voxl-recorder-battery: command not found
            Would it be useful for me to post my code?
              Hersch Nathan
              edit - here is the output from running the following clear && ./clean.sh && ./install_build_deps.sh qrb5165 dev && ./build.sh qrb5165 && ./make_package.sh deb && ./deploy_to_voxl.sh ssh 10.3.141.30
              using qrb5165 dev debian repo
              Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ InRelease
              Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Release
              Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages [98.6 kB]
              Fetched 98.6 kB in 1s (108 kB/s)
              Reading package lists... Done
              installing:
              libmodal-json
              libmodal-pipe
              libvoxl-cutils
              voxl-mavlink
              Building dependency tree
              The following NEW packages will be installed:
              libmodal-json:arm64 libmodal-pipe:arm64 libvoxl-cutils:arm64
              voxl-mavlink:arm64
              0 upgraded, 4 newly installed, 0 to remove and 69 not upgraded.
              Need to get 675 kB of archives.
              After this operation, 0 B of additional disk space will be used.
              Get:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-json 0.4.3-202209281920 [43.8 kB]
              Get:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-pipe 2.8.5-202306211619 [84.5 kB]
              Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libvoxl-cutils 0.1.1-202210072352 [6228 B]
              Get:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ voxl-mavlink 0.1.1-202305011701 [541 kB]
              Fetched 675 kB in 1s (704 kB/s)
              debconf: unable to initialize frontend: Dialog
              debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 4.)
              debconf: falling back to frontend: Readline
              Selecting previously unselected package libmodal-json:arm64.
              (Reading database ... 30768 files and directories currently installed.)
              Preparing to unpack .../libmodal-json_0.4.3-202209281920_arm64.deb ...
              Unpacking libmodal-json:arm64 (0.4.3-202209281920) ...
              Selecting previously unselected package libmodal-pipe:arm64.
              Preparing to unpack .../libmodal-pipe_2.8.5-202306211619_arm64.deb ...
              Unpacking libmodal-pipe:arm64 (2.8.5-202306211619) ...
              Selecting previously unselected package libvoxl-cutils:arm64.
              Preparing to unpack .../libvoxl-cutils_0.1.1-202210072352_arm64.deb ...
              Unpacking libvoxl-cutils:arm64 (0.1.1-202210072352) ...
              Selecting previously unselected package voxl-mavlink:arm64.
              Preparing to unpack .../voxl-mavlink_0.1.1-202305011701_arm64.deb ...
              Unpacking voxl-mavlink:arm64 (0.1.1-202305011701) ...
              Setting up voxl-mavlink:arm64 (0.1.1-202305011701) ...
              Setting up libvoxl-cutils:arm64 (0.1.1-202210072352) ...
              Setting up libmodal-json:arm64 (0.4.3-202209281920) ...
              Setting up libmodal-pipe:arm64 (2.8.5-202306211619) ...
              Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
              Done installing dependencies
              -- The C compiler identification is GNU 7.5.0
              -- The CXX compiler identification is GNU 7.5.0
              -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-7 - skipped
              -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-7 - skipped
              -- processor: aarch64
              -- librc_math: LIBRC_MATH_SO-NOTFOUND
              -- libmodal_pipe: /usr/lib64/libmodal_pipe.so
              -- libmodal_json: /usr/lib64/libmodal_json.so
              -- libturbojpeg.so: LIBJPEG_TURBO_SO-NOTFOUND
              -- Configuring done
              -- Generating done
              -- Build files have been written to: /home/root/cross-workspace/voxl-recorder-battery/build
              [ 25%] Building CXX object tools/CMakeFiles/voxl-record-battery.dir/voxl-record-battery.cpp.o
              [ 50%] Building C object lib/CMakeFiles/voxl_common_config.dir/voxl_common_config.c.o
              [ 75%] Linking C shared library libvoxl_common_config.so
              [ 75%] Built target voxl_common_config
              In file included from /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:52:0:
              /home/root/cross-workspace/voxl-recorder-battery/tools/log_defs.h: In function 'void _rotation_to_tait_bryan_xyz_intrinsic(float ()[3], float, float*, float*)':
              /home/root/cross-workspace/voxl-recorder-battery/tools/log_defs.h:158:19: warning: implicit conversion from 'float' to 'double' to match other operand of binary expression [-Wdouble-promotion]
              if(fabs(R[0][2]) < 0.9999999){
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: In function 'int _start_csv(int)':
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:227:66: warning: unknown conversion type character ')' in format [-Wformat=]
              fprintf(fd, "i,timestamp(ns),,Voltage(V),Charge(%),Current(A)\n");
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:205:6: warning: unused variable 'i' [-Wunused-variable]
              int i;
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:209:7: warning: unused variable 'raw_path' [-Wunused-variable]
              char raw_path[512];
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: In function 'int _parse_opts(int, char**)':
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:201:1: warning: control reaches end of non-void function [-Wreturn-type]
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: At global scope:
              /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:82:13: warning: 'note' defined but not used [-Wunused-variable]
              static char note[MAX_NOTE_LEN] = "na";
              [100%] Linking CXX executable voxl-record-battery
              [100%] Built target voxl-record-battery
              Package Name: voxl-recorder-battery
              version Number: 0.0.2
              Consolidate compiler generated dependencies of target voxl-record-battery
              [ 50%] Built target voxl-record-battery
              Consolidate compiler generated dependencies of target voxl_common_config
              [100%] Built target voxl_common_config
              Install the project...
              -- Install configuration: ""
              -- Installing: ../pkg/data/usr/bin/voxl-record-battery
              -- Installing: ../pkg/data/usr/lib64/libvoxl_common_config.so
              -- Installing: ../pkg/data/usr/include/voxl_common_config.h
              starting building Debian Package
              dpkg-deb: building package 'voxl-recorder-battery' in 'voxl-recorder-battery_0.0.2_arm64.deb'.
              DONE
              searching for ssh device
              checking VOXL for dpkg/opkg
              dpkg detected
              (Reading database ... 121951 files and directories currently installed.)
              Preparing to unpack .../voxl-recorder-battery_0.0.2_arm64.deb ...
              Unpacking voxl-recorder-battery (0.0.2) over (0.0.1) ...
                installing:
                libmodal-json
                libmodal-pipe
                libvoxl-cutils
                voxl-mavlink
                voxl-mavlink:arm64
                -- Configuring done
                -- Generating done
                int i;
                char raw_path[512];
                DONE
                dpkg detected
                @Hersch-Nathan Looks like you called the binary voxl-record-battery based on
                whereas you're calling voxl-recorder-battery
                  Hersch Nathan
                  @tom Thank you so much for you help! I got my code to deploy to the voxl! Now on to bug fixing!
