  3. VOXL2 SDK 1.0.0-beta6 voxl-px4 couldn't arm UAV (GPS LED always RED blinking)
33 Posts 2 Posters 6.4k Views 1 Watching
    @Aaky What is the contents of /data/modalai/sku.txt?
    @Eric-Katzfey Perhaps run voxl-configure-mpa -f sentinel to reconfigure the system and then reboot and try again
    A 1 Reply Last reply
      Aaky
      @Eric-Katzfey I didn't had any file on /data/modalai/sku.txt. I ran "voxl-configure-sku -f sentinel" and this file was generated. Now contents in this file are "MRB-D0006-4-V1-C11".
      I tried running voxl-configure-mpa -f sentinel after configuring sku but it fails with following error "Invalid arg: -f, exiting". So I just ran voxl-configure-mpa and below are logs of ths same.
      voxl2:/$ voxl-configure-mpa -d
      enabling debug mode
                     Welcome to voxl-configure-mpa!
      VOXL is currently thinks it is in the following hardware:
      family code:   MRB-D0006 (sentinel)
      compute board: 4 (voxl2)
      hw version:    1
      cam config:    11
      SKU:           MRB-D0006-4-V1-C11
      If this doesn't look right, quit and run voxl-configure-sku to
      set it correctly. Then run voxl-configure-mpa again.
      Continue? y/n: y
      Continuing
      About to Execute:
      voxl-configure-extrinsics sentinel_v1
      voxl-configure-cameras 11
      voxl-configure-cpu-monitor factory_enable
      voxl-configure-qvio factory_enable_imu_apps
      voxl-configure-dfs factory_disable
      voxl-configure-tag-detector factory_disable
      voxl-configure-tflite factory_disable
      voxl-configure-vision-hub factory_enable
      voxl-configure-mavlink-server factory_enable
      voxl-configure-portal enable
      voxl-configure-lepton disable
      voxl-configure-uvc disable
      voxl-configure-streamer factory_enable
      voxl-configure-modem disable
      voxl-configure-mavcam factory_enable
      voxl-configure-px4-imu-server factory_disable
      voxl-configure-imu factory_enable
      voxl-configure-flow-server disable
      voxl-configure-feature-tracker disable
      voxl-esc setup_sentinel_v1
      voxl-configure-px4 sentinel_v1
      voxl-configure-px4-params -np MRB-D0006
      Continue? y/n: y
      Continuing
      enabling voxl-wait-for-fs service
      executing: voxl-configure-extrinsics sentinel_v1
      wiping old extrinsics config file
      copying /usr/share/modalai/extrinsic_configs/sentinel_v1.conf to /etc/modalai/extrinsics.conf
      loading and updating file with voxl-inspect-extrinsics -q
      done configuring extrinsics
      Success!
      executing: voxl-configure-cameras 11
      Camera Configuration: 11
      calling camera-server-config-helper tracking:ov7251:2 hires:imx214:3 stereo_front:ov7251:0:1 stereo_rear:ov7251:5:4
      successfully wrote this camera config to disk:
      configuration for 4 cameras:
      cam #0
          sensor type:         ov7251
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          small_video_width:   -1
          small_video_height:  -1
          en_large_video:      0
          large_video_width:   -1
          large_video_height:  -1
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
          independent_exposure:0
      cam #1
          sensor type:         imx214
          isEnabled:           1
          camId:               3
          camId2:              -1
          fps:                 30
          en_preview:          0
          pre_width:           640
          pre_height:          480
          pre_format:          nv21
          en_small_video:      1
          small_video_width:   1024
          small_video_height:  768
          en_large_video:      1
          large_video_width:   4096
          large_video_height:  2160
          en_snapshot:         1
          snap_width:          4160
          snap_height:         3120
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ov7251
          isEnabled:           1
          camId:               0
          camId2:              1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      cam #3
          sensor type:         ov7251
          isEnabled:           1
          camId:               5
          camId2:              4
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      camera_server_config_helper is done
      copying required camera drivers in place
      /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin
      /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_0.bin
      /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_1.bin
      /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_3.bin
      /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_4.bin
      /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_5.bin
      enabling voxl-camera-server
      Done Configuring Cameras
      Please power cycle VOXL to load new drivers
      camera server will start on next reboot
      Success!
      executing: voxl-configure-cpu-monitor factory_enable
      wiping old config file
      Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
      enabling  voxl-cpu-monitor systemd service
      Done configuring voxl-cpu-monitor
      Success!
      executing: voxl-configure-qvio factory_enable_imu_apps
      loading config file
      Creating new config file: /etc/modalai/voxl-qvio-server.conf
      enabling  voxl-qvio-server systemd service
      Done configuring voxl-qvio-server
      Success!
      executing: voxl-configure-dfs factory_disable
      Creating new config file: /etc/modalai/voxl-dfs-server.conf
      disabling voxl-dfs-server systemd service
      stopping voxl-dfs-server systemd service
      Done configuring voxl-dfs-server
      Success!
      executing: voxl-configure-tag-detector factory_disable
      Creating new config file: /etc/modalai/voxl-tag-detector.conf
      disabling voxl-tag-detector systemd service
      stopping voxl-tag-detector systemd service
      Done configuring voxl-tag-detector
      Success!
      executing: voxl-configure-tflite factory_disable
      Creating new config file: /etc/modalai/voxl-tflite-server.conf
      The config file was modified during parsing, saving the changes to disk
      disabling voxl-tflite-server systemd service
      stopping voxl-tflite-server systemd service
      Done configuring voxl-tflite-server
      Success!
      executing: voxl-configure-vision-hub factory_enable
      Created new json file: /etc/modalai/voxl-vision-hub.conf
      The JSON config file data was modified during parsing, saving the changes to disk
      enabling  voxl-vision-hub systemd service
      Done configuring voxl-vision-hub
      service will start on next reboot
      Success!
      executing: voxl-configure-mavlink-server factory_enable
      Created new json file: /etc/modalai/voxl-mavlink-server.conf
      enabling  voxl-mavlink-server systemd service
      Done configuring voxl-mavlink-server
      Success!
      executing: voxl-configure-portal enable
      enabling  voxl-portal systemd service
      Done configuring voxl-portal
      Success!
      executing: voxl-configure-lepton disable
      disabling voxl-lepton-server systemd service
      stopping voxl-lepton-server systemd service
      Done configuring voxl-lepton-server
      Success!
      executing: voxl-configure-uvc disable
      disabling voxl-uvc-server systemd service
      stopping voxl-uvc-server systemd service
      Done configuring voxl-uvc-server
      Success!
      executing: voxl-configure-streamer factory_enable
      Creating new config file: /etc/modalai/voxl-streamer.conf
      writing /etc/modalai/voxl-streamer.conf to disk
      parsed config file
      enabling  voxl-streamer systemd service
      Done configuring voxl-streamer, it will start on next reboot
      Success!
      executing: voxl-configure-modem disable
      disabling voxl-modem systemd service
      stopping voxl-modem systemd service
      Done configuring voxl-modem
      Success!
      executing: voxl-configure-mavcam factory_enable
      Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
      writing /etc/modalai/voxl-mavcam-manager.conf to disk
      enabling  voxl-mavcam-manager systemd service
      Done configuring voxl-mavcam-manager
      It will start automatically on the next reboot
      Success!
      executing: voxl-configure-px4-imu-server factory_disable
      disabling voxl-px4-imu-server systemd service
      stopping voxl-px4-imu-server systemd service
      Done configuring voxl-px4-imu-server
      Success!
      executing: voxl-configure-imu factory_enable
      Creating new config file: /etc/modalai/voxl-imu-server.conf
      voxl-imu-server currently has no calibration file
      enabling  voxl-imu-server systemd service
      Done configuring voxl-imu-server
      Success!
      executing: voxl-configure-flow-server disable
      disabling voxl-flow-server systemd service
      stopping voxl-flow-server systemd service
      Done configuring voxl-flow-server
      Success!
      executing: voxl-configure-feature-tracker disable
      disabling voxl-feature-tracker systemd service
      stopping voxl-feature-tracker systemd service
      Done configuring voxl-feature-tracker
      Success!
      executing: voxl-esc setup_sentinel_v1
      enabling bridge
      detected voxl-px4 is enabled
      Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
      detected voxl-px4 is running, stopping it now
      bridge enabled
      [INFO] Scanning for ESC...
      [INFO] M0117-1 detected
      [INFO] has for most recent firmware: 83faccfa
      [INFO] Expected ESC firmware info:
      	Firmware: modalai_esc_firmware_m0117_1_v0_38_83faccfa.bin
      	Firmware hash: 83faccfa
      [INFO] Number of ESCs with correct FW: 4
      [INFO] All of the ESCs have the correct firmware loaded
      uploading params file ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
      [GCC 8.4.0]
      Found voxl-esc tools bin version: 1.2
      VOXL Platform: M0054
      Detected VOXL2 M0054 or M0104!
      Found previous connection information in .voxl_esc_cache ..
      Prioritizing /dev/slpi-uart-2 @ 2000000
      Sending library name request: libslpi_uart_bridge_slpi.so
      INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
      INFO: Detected protocol: firmware
      INFO: Additional Information:
      INFO: ---------------------
      	Board      : version 34: ModalAi 4-in-1 ESC (M0117-1)
      	UID        : 0x203034305743570C00270034
      	Firmware   : version   38, hash 83faccfa
      	Bootloader : version  183, hash 25317f42
      	UID        : 0x203034305743570C003A0054
      	UID        : 0x203034305743570C00210050
      	UID        : 0x203034305743570C00280028
      successfully pinged ESCs
      [GCC 8.4.0]
      INFO: Params file name : ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
      INFO: Params file size : 7591 bytes
      INFO: ESCs detected:
      ID: 0, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
      ID: 1, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
      ID: 2, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
      ID: 3, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
      INFO: Loading XML config file...
      INFO: Uploading params...
      -- board config
      -- id config
      -- uart config
      -- tune config
          DONE
      INFO: Resetting ESCs...
          DONE
      disabling bridge
      re-enabling voxl-px4
      Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
      restarting voxl-px4
      bridge disabled
      Success!
      executing: voxl-configure-px4 sentinel_v1
      enabling  voxl-px4 systemd service
      Success!
      executing: voxl-configure-px4-params -np MRB-D0006
      [INFO] Voxl-px4 service found and active.
      [INFO] about to load the following param files:
      ('platforms/Sentinel_V1.params', 'EKF2_helpers/outdoor_gps_baro.params')
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Sentinel_V1.params
      [INFO] Scanning currently loaded parameters...
      The following parameters about to be loaded differ from those currently loaded:
      	NAME    		CURRENT    	NEW
      [1]	CBRK_IO_SAFETY    	N/A		22027
      [2]	CBRK_SUPPLY_CHK    	N/A		894281
      [3]	COM_CPU_MAX    		N/A		-1
      [4]	COM_OF_LOSS_T    	N/A		3.0
      [5]	NAV_ACC_RAD    		N/A		2.0
      [6]	GPS_UBX_DYNMODEL    	N/A		6
      [7]	RTL_RETURN_ALT    	N/A		30
      [8]	RTL_DESCEND_ALT    	N/A		10
      [9]	IMU_GYRO_RATEMAX    	N/A		800
      [10]	SYS_AUTOSTART    	N/A		4001
      [11]	MAV_TYPE    		N/A		2
      [12]	SENS_BOARD_ROT    	N/A		0
      [13]	BAT1_N_CELLS    	N/A		3
      [14]	BAT1_R_INTERNAL    	N/A		0.003
      [15]	BAT1_CAPACITY    	N/A		4700
      [16]	BAT1_V_CHARGED    	N/A		4.15
      [17]	BAT1_V_EMPTY    	N/A		3.50
      [18]	BAT_LOW_THR    		N/A		0.15
      [19]	BAT_CRIT_THR    	N/A		0.10
      [20]	BAT_EMERGEN_THR    	N/A		0.05
      [21]	MPC_THR_HOVER    	N/A		0.41
      [22]	THR_MDL_FAC    		N/A		0.80
      [23]	MODAL_IO_RPM_MAX    	N/A		7000
      [24]	MODAL_IO_RPM_MIN    	N/A		1000
      [25]	MODAL_IO_FUNC1    	N/A		103
      [26]	MODAL_IO_FUNC2    	N/A		102
      [27]	MODAL_IO_FUNC3    	N/A		104
      [28]	MODAL_IO_FUNC4    	N/A		101
      [29]	MODAL_IO_SDIR1    	N/A		0
      [30]	MODAL_IO_SDIR2    	N/A		0
      [31]	MODAL_IO_SDIR3    	N/A		0
      [32]	MODAL_IO_SDIR4    	N/A		0
      [33]	MODAL_IO_BAUD    	N/A		2000000
      [34]	MODAL_IO_CONFIG    	N/A		1
      [35]	MODAL_IO_MODE    	N/A		0
      [36]	MODAL_IO_REV    	N/A		0
      [37]	MODAL_IO_T_COSP    	N/A		0.990000009536743164
      [38]	MODAL_IO_T_DEAD    	N/A		20
      [39]	MODAL_IO_T_EXPO    	N/A		35
      [40]	MODAL_IO_T_MINF    	N/A		0.150000005960464478
      [41]	MODAL_IO_T_PERC    	N/A		90
      [42]	MODAL_IO_VLOG    	N/A		1
      [43]	MC_BAT_SCALE_EN    	N/A		0
      [44]	EKF2_IMU_POS_X    	N/A		0.033
      [45]	EKF2_IMU_POS_Y    	N/A		0.008
      [46]	EKF2_IMU_POS_Z    	N/A		-0.036
      [47]	EKF2_EV_POS_X    	N/A		0.0
      [48]	EKF2_EV_POS_Y    	N/A		0.0
      [49]	EKF2_EV_POS_Z    	N/A		0.0
      [50]	CA_AIRFRAME    		N/A		0
      [51]	CA_ROTOR_COUNT    	N/A		4
      [52]	CA_ROTOR0_PX    	N/A		0.17
      [53]	CA_ROTOR0_PY    	N/A		0.17
      [54]	CA_ROTOR1_PX    	N/A		-0.17
      [55]	CA_ROTOR1_PY    	N/A		-0.17
      [56]	CA_ROTOR2_PX    	N/A		0.17
      [57]	CA_ROTOR2_PY    	N/A		-0.17
      [58]	CA_ROTOR3_PX    	N/A		-0.17
      [59]	CA_ROTOR3_PY    	N/A		0.17
      [60]	CA_ROTOR0_AX    	N/A		0.0
      [61]	CA_ROTOR0_AY    	N/A		0.0
      [62]	CA_ROTOR1_AX    	N/A		0.0
      [63]	CA_ROTOR1_AY    	N/A		0.0
      [64]	CA_ROTOR2_AX    	N/A		0.0
      [65]	CA_ROTOR2_AY    	N/A		0.0
      [66]	CA_ROTOR3_AX    	N/A		0.0
      [67]	CA_ROTOR3_AY    	N/A		0.0
      [68]	CA_ROTOR0_KM    	N/A		0.05
      [69]	CA_ROTOR1_KM    	N/A		0.05
      [70]	CA_ROTOR2_KM    	N/A		-0.05
      [71]	CA_ROTOR3_KM    	N/A		-0.05
      [72]	MOT_SLEW_MAX    	N/A		0.0
      [73]	IMU_DGYRO_CUTOFF    	N/A		40.0
      [74]	IMU_ACCEL_CUTOFF    	N/A		40.0
      [75]	IMU_GYRO_CUTOFF    	N/A		40.0
      [76]	IMU_GYRO_DNF_EN    	N/A		1
      [77]	IMU_GYRO_DNF_HMC    	N/A		3
      [78]	IMU_GYRO_DNF_BW    	N/A		15
      [79]	MC_AIRMODE    		N/A		0
      [80]	MC_PITCH_P    		N/A		5.5
      [81]	MC_PITCHRATE_P    	N/A		0.080
      [82]	MC_PITCHRATE_I    	N/A		0.400
      [83]	MC_PITCHRATE_D    	N/A		0.00
      [84]	MC_PITCHRATE_K    	N/A		1.0
      [85]	MC_ROLL_P    		N/A		5.5
      [86]	MC_ROLLRATE_P    	N/A		0.080
      [87]	MC_ROLLRATE_I    	N/A		0.400
      [88]	MC_ROLLRATE_D    	N/A		0.00
      [89]	MC_ROLLRATE_K    	N/A		1.0
      [90]	MC_YAW_P    		N/A		2.0
      [91]	MC_YAWRATE_P    	N/A		0.13
      [92]	MC_YAWRATE_I    	N/A		0.30
      [93]	MC_YAWRATE_D    	N/A		0.0
      [94]	MC_YAWRATE_K    	N/A		1.0
      [95]	MC_ROLLRATE_MAX    	N/A		150.0
      [96]	MC_PITCHRATE_MAX    	N/A		150.0
      [97]	MC_YAWRATE_MAX    	N/A		150.0
      [98]	MPC_POS_MODE    	N/A		4
      [99]	MPC_YAW_EXPO    	N/A		0.30
      [100]	MPC_XY_MAN_EXPO    	N/A		0.45
      [101]	MPC_Z_MAN_EXPO    	N/A		0.10
      [102]	MPC_ACC_HOR    		N/A		3.0
      [103]	MPC_JERK_MAX    	N/A		40.0
      [104]	MPC_TILTMAX_AIR    	N/A		30.0
      [105]	MPC_ACC_HOR_MAX    	N/A		6.0
      [106]	MPC_ACC_UP_MAX    	N/A		3.0
      [107]	MPC_ACC_DOWN_MAX    	N/A		3.0
      [108]	MPC_VEL_MANUAL    	N/A		5.0
      [109]	MPC_XY_VEL_MAX    	N/A		5.0
      [110]	MPC_XY_CRUISE    	N/A		5.0
      [111]	MPC_Z_VEL_MAX_DN    	N/A		1.5
      [112]	MPC_Z_VEL_MAX_UP    	N/A		4.0
      [113]	MPC_LAND_SPEED    	N/A		1.0
      [114]	MPC_THR_MAX    		N/A		0.75
      [115]	MPC_THR_MIN    		N/A		0.12
      [116]	MPC_MANTHR_MIN    	N/A		0.12
      [117]	MPC_XY_P    		N/A		0.95
      [118]	MPC_XY_VEL_P_ACC    	N/A		3.00
      [119]	MPC_XY_VEL_I_ACC    	N/A		0.10
      [120]	MPC_XY_VEL_D_ACC    	N/A		0.00
      [121]	MPC_Z_P    		N/A		1.0
      [122]	MPC_Z_VEL_P_ACC    	N/A		8.0
      [123]	MPC_Z_VEL_I_ACC    	N/A		2.0
      [124]	MPC_Z_VEL_D_ACC    	N/A		0.0
      [125]	MPC_TKO_RAMP_T    	N/A		2.00
      [126]	MPC_TKO_SPEED    	N/A		1.50
      [127]	COM_SPOOLUP_TIME    	N/A		1.0
      [128]	LNDMC_ROT_MAX    	N/A		30.0
      [129]	COM_DISARM_LAND    	N/A		0.1
      [130]	COM_DISARM_PRFLT    	N/A		20
      [INFO] Setting params...
      [ERROR] Failed to set px4-parameters. Check voxl-px4 status for details.
      FAILED TO EXECUTE: voxl-configure-px4-params -np MRB-D0006
      This is likely because voxl-px4 on the SDSP failed to restart.
      Please try running voxl-configure-mpa again.
      If that doesn't work, power cycle and try again.
      checking /data/modalai/voxl-imu-server.cal
      checking /data/modalai/opencv_tracking_intrinsics.yml
      checking /data/modalai/opencv_stereo_front_intrinsics.yml
      checking /data/modalai/opencv_stereo_front_extrinsics.yml
      checking /data/modalai/opencv_stereo_rear_intrinsics.yml
      checking /data/modalai/opencv_stereo_rear_extrinsics.yml
               FAILED TO EXECUTE the following steps:
            Encountered Problems Configuring MPA Services :-/
              Some Services may not start up on next reboot
      Calibration File Status:
      Missing /data/modalai/voxl-imu-server.cal
      Missing /data/modalai/opencv_tracking_intrinsics.yml
      Missing /data/modalai/opencv_stereo_front_intrinsics.yml
      Missing /data/modalai/opencv_stereo_front_extrinsics.yml
      Missing /data/modalai/opencv_stereo_rear_intrinsics.yml
      Missing /data/modalai/opencv_stereo_rear_extrinsics.yml
      Present /data/px4/param/parameters_gyro.cal
      Present /data/px4/param/parameters_acc.cal
      Present /data/px4/param/parameters_mag.cal
      Present /data/px4/param/parameters_level.cal
      Detected Missing Calibration Files
      please run the required cals
      https://docs.modalai.com/calibration/
                      PLEASE POWER CYCLE YOUR VOXL
      I power cycled VOXL2 after this message but still no luck. I still see some preflight check failing and couldn't arm the uav in manual mode. Even in indoor my GPS data is ok with HDOP of 0.9.
      Do you see any problem with execution of voxl-configure-mpa?
      • A Aaky
        enabling debug mode
        hw version:    1
        cam config:    11
        Continue? y/n: y
        Continuing
        About to Execute:
        Continue? y/n: y
        Continuing
        Success!
        cam #0
            sensor type:         ov7251
            isEnabled:           1
            camId:               2
            camId2:              -1
            fps:                 30
            en_preview:          1
            pre_width:           640
            pre_height:          480
            pre_format:          raw8
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            standby_enabled:     0
            decimator:           1
        cam #1
            sensor type:         imx214
            isEnabled:           1
            camId:               3
            camId2:              -1
            fps:                 30
            en_preview:          0
            pre_width:           640
            pre_height:          480
            pre_format:          nv21
            en_small_video:      1
            en_large_video:      1
            en_snapshot:         1
            snap_width:          4160
            snap_height:         3120
            ae_mode:             isp
            standby_enabled:     0
            decimator:           1
        cam #2
            sensor type:         ov7251
            isEnabled:           1
            camId:               0
            camId2:              1
            fps:                 30
            en_preview:          1
            pre_width:           640
            pre_height:          480
            pre_format:          raw8
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            standby_enabled:     0
            decimator:           1
        cam #3
            sensor type:         ov7251
            isEnabled:           1
            camId:               5
            camId2:              4
            fps:                 30
            en_preview:          1
            pre_width:           640
            pre_height:          480
            pre_format:          raw8
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            standby_enabled:     0
            decimator:           1
        Success!
        Success!
        loading config file
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        parsed config file
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        Success!
        enabling bridge
        bridge enabled
        [GCC 8.4.0]
        [GCC 8.4.0]
        -- board config
        -- id config
        -- uart config
        -- tune config
            DONE
            DONE
        disabling bridge
        restarting voxl-px4
        bridge disabled
        Success!
        Success!
        	NAME    		CURRENT    	NEW
        [11]	MAV_TYPE    		N/A		2
        Aaky
        @Eric-Katzfey
        I ran mpa configuration while fresh installation of beta image and below are logs where PX4 parameters were set correctly. Please have a look.
                    Welcome to the voxl-configure-sku Wizard!
        [WARN] Detected both the old sku file /data/modalai/factory_mode.txt
        [WARN] and the new one: /data/modalai/sku.txt
        [WARN] Deleting the old one
        VOXL currently thinks it is in the following hardware:
        hw version:    1
        cam config:    11
        If this is what you want, select 1 (accept and continue) to
        leave it as-is. Otherwise, select the desired product family:
        1) accept and continue	      9) flight-deck
        2) starling		     10) voxl-deck
        3) sentinel		     11) voxl2-flight-deck
        4) fpv			     12) voxl2-test-fixture
        5) m500			     13) voxl2-mini-test-fixture
        6) voxlcam		     14) voxl2-board-only
        7) seeker		     15) voxl2-mini-board-only
        8) rb5-flight
        #? 3
        selected sentinel
        Please choose what camera config is on this drone
        The default camera config for RB5-Flight and Sentinel
        is 11 (hires+tracking+dual_stereo)
        q  Quit The Wizard
        0  None
        1  tracking(ov7251) + Stereo(ov7251)
        2  tracking(ov7251) Only
        3  Hires(imx214) + Stereo(ov7251) + tracking(ov7251)
        4  Hires(imx214) + tracking(ov7251)
        5  TOF + tracking(ov7251)
        6 Hires(imx214) + TOF + tracking(ov7251)
        7  TOF + Stereo(ov7251) + tracking(ov7251)
        8  Hires(imx214) Only
        9  TOF Only
        10 Stereo(ov7251) only
        11 tracking(ov7251) + Hires(imx214) + Dual Stereo
        12 Stereo(OV9782) only
        13 Hires(imx214) + Stereo(ov7251)
        14 Stereo(OV9782) + TOF + tracking(ov7251)
        15 Dual OV9782
        Cam Config Number: 6
        Your answers would construct the following SKU:
        hw version:    1
        cam config:    6
        SKU:           MRB-D0006-4-V1-C6
        Would you like to continue? This sku will be saved
        to persistent memory so VOXL will remember what it
        is installed in, even between system image flashes.
        1) save and continue
        2) quit
        3) restart wizard
        #? 1
        Continuing
        DONE, MRB-D0006-4-V1-C6 has been written to /data/modalai/sku.txt
        Next you will likely want to run voxl-configure-mpa
        Wifi is currently set up as follows:
        	Current mode: softap
        	Current ssid: Aerotitan
        Station mode is for connecting to a normal wifi network.
        In softap mode, the VOXL will broadcast its own wifi network.
        Factory mode will set up softap with the following unique SSID:
        	VOXL-00:30:1a:50:1c:a1
        Please enter the intended Wi-Fi operation
        Options:
        	1) leave as-is
        	2) station
        	3) softap
        	4) factory
        Operation: 3
        Please enter the SSID to broadcast
        SSID: Aerotitan
        Aerotitan
        Please enter a password, or leave blank to use the default password.
        Password [default: 1234567890]: 1234567890
        1234567890
        Configuring...
        editing /data/misc/wifi/hostapd.conf for softap mode, ssid is: Aerotitan
        creating new wpa_supplicant.conf for softap mode, ssid is: Aerotitan
        soft AP Setup Complete!
        Changes should be active in a few seconds
        SoftAP Configuration succeeded!
        enabling non-interactive mode
        hw version:    1
        cam config:    6
        About to Execute:
        voxl-configure-cameras 6
        Success!
        executing: voxl-configure-cameras 6
        Camera Configuration: 6
        calling camera-server-config-helper tof:pmd-tof:0 hires:imx214:1 tracking:ov7251:2
        configuration for 3 cameras:
        cam #0
            sensor type:         pmd-tof
            isEnabled:           1
            camId:               0
            camId2:              -1
            fps:                 5
            en_preview:          1
            pre_width:           224
            pre_height:          1557
            pre_format:          tof
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             off
            standby_enabled:     0
            decimator:           5
        cam #1
            sensor type:         imx214
            isEnabled:           1
            camId:               1
            camId2:              -1
            fps:                 30
            en_preview:          0
            pre_width:           640
            pre_height:          480
            pre_format:          nv21
            en_small_video:      1
            en_large_video:      1
            en_snapshot:         1
            snap_width:          4160
            snap_height:         3120
            ae_mode:             isp
            standby_enabled:     0
            decimator:           1
        cam #2
            sensor type:         ov7251
            isEnabled:           1
            camId:               2
            camId2:              -1
            fps:                 30
            en_preview:          1
            pre_width:           640
            pre_height:          480
            pre_format:          raw8
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            standby_enabled:     0
            decimator:           1
        /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
        /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
        /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-camera-server.service → /etc/systemd/system/voxl-camera-server.service.
        Success!
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-cpu-monitor.service → /etc/systemd/system/voxl-cpu-monitor.service.
        Success!
        loading config file
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-qvio-server.service → /etc/systemd/system/voxl-qvio-server.service.
        Success!
        Success!
        Success!
        Success!
        Automatically migrating old config file /etc/modalai/voxl-vision-px4.conf to new location: /etc/modalai/voxl-vision-hub.conf
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-vision-hub.service → /etc/systemd/system/voxl-vision-hub.service.
        Success!
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-mavlink-server.service → /etc/systemd/system/voxl-mavlink-server.service.
        Success!
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-portal.service → /etc/systemd/system/voxl-portal.service.
        Success!
        Success!
        Success!
        parsed config file
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-streamer.service → /etc/systemd/system/voxl-streamer.service.
        Success!
        Success!
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-mavcam-manager.service → /etc/systemd/system/voxl-mavcam-manager.service.
        Success!
        Success!
        missing gyro0_offset, removing old empty file
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-imu-server.service → /etc/systemd/system/voxl-imu-server.service.
        Success!
        Success!
        Success!
        enabling bridge
        bridge enabled
        [GCC 8.4.0]
        [GCC 8.4.0]
        -- board config
        -- id config
        -- uart config
        -- tune config
            DONE
            DONE
        disabling bridge
        bridge disabled
        Success!
        Success!
        [INFO] Voxl-px4 not currently running
        [INFO] Starting voxl-px4 service...
        [INFO] Voxl-px4 started successfully!
        	NAME    		CURRENT    	NEW
        [11]	MAV_TYPE    		N/A		2
        [INFO] Px4 parameter configuration successful!
        [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/outdoor_gps_baro.params
        	NAME    		CURRENT    	NEW
        [1]	SYS_HAS_MAG    		N/A		1
        [2]	SYS_HAS_GPS    		N/A		1
        [3]	EKF2_MAG_TYPE    	N/A		0
        [4]	EKF2_GPS_CTRL    	N/A		7
        [5]	EKF2_EV_CTRL    	N/A		0
        [6]	EKF2_AID_MASK    	N/A		0
        [7]	EKF2_HGT_REF    	N/A		0
        [8]	COM_ARM_WO_GPS    	N/A		1
        [INFO] Loading file: /data/px4/param/parameters_gyro.cal
        	NAME    		CURRENT    	NEW
        [1]	CAL_GYRO0_ID    	N/A		2490378
        [2]	CAL_GYRO0_PRIO    	N/A		50
        [3]	CAL_GYRO0_XOFF    	N/A		0.0227608
        [4]	CAL_GYRO0_YOFF    	N/A		0.00552622
        [5]	CAL_GYRO0_ZOFF    	N/A		-0.0139491
        [6]	CAL_GYRO0_ROT    	N/A		-1
        [INFO] Loading file: /data/px4/param/parameters_level.cal
        	NAME    		CURRENT    	NEW
        [1]	SENS_BOARD_X_OFF    	N/A		-4.80679
        [2]	SENS_BOARD_Y_OFF    	N/A		-2.07214
        [INFO] Loading file: /data/px4/param/parameters_mag.cal
        	NAME    		CURRENT    	NEW
        [1]	CAL_MAG0_ID    		N/A		396809
        [2]	CAL_MAG0_PRIO    	N/A		75
        [3]	CAL_MAG0_XOFF    	N/A		0.0189662
        [4]	CAL_MAG0_YOFF    	N/A		-0.0148698
        [5]	CAL_MAG0_ZOFF    	N/A		0.163498
        [6]	CAL_MAG0_XSCALE    	N/A		1.01365
        [7]	CAL_MAG0_YSCALE    	N/A		0.922817
        [8]	CAL_MAG0_ZSCALE    	N/A		1.10712
        [9]	CAL_MAG0_XODIAG    	N/A		0.0136699
        [10]	CAL_MAG0_YODIAG    	N/A		0.0716552
        [11]	CAL_MAG0_ZODIAG    	N/A		0.0244222
        [12]	CAL_MAG0_XCOMP    	N/A		0
        [13]	CAL_MAG0_YCOMP    	N/A		0
        [14]	CAL_MAG0_ZCOMP    	N/A		0
        [15]	CAL_MAG0_ROT    	N/A		0
        [INFO] Done configuring for platform MRB-D0006
        Success!
                SUCCESSFULLY CONFIGURED MPA SERVICES!
                Services will start up on next reboot
        SDK Install Completed
        But even after this installation success as compared to previous installation I am facing same problem of not able to arm the UAV and GPS LED blinking red always. On the exact same indoor location where I am testing 1.14 firmware version I downgraded complete system image to platform 0.9.5 with PX4 version 1.12.31 and I am able to arm the UAV and holybro GPS LED blows Green and QGC goes in "Ready to fly condition."
        Please guide ahead.
        • A Aaky
          @Eric-Katzfey
          hw version:    1
          cam config:    11
          8) rb5-flight
          #? 3
          selected sentinel
          q  Quit The Wizard
          0  None
          9  TOF Only
          15 Dual OV9782
          hw version:    1
          cam config:    6
          2) quit
          3) restart wizard
          #? 1
          Continuing
          Options:
          	1) leave as-is
          	2) station
          	3) softap
          	4) factory
          Operation: 3
          SSID: Aerotitan
          Aerotitan
          1234567890
          Configuring...
          hw version:    1
          cam config:    6
          About to Execute:
          Success!
          cam #0
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              pre_format:          tof
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_preview:          0
              pre_width:           640
              pre_height:          480
              pre_format:          nv21
              en_small_video:      1
              en_large_video:      1
              en_snapshot:         1
              snap_width:          4160
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_preview:          1
              pre_width:           640
              pre_height:          480
              pre_format:          raw8
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          Success!
          Success!
          loading config file
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          parsed config file
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          Success!
          enabling bridge
          bridge enabled
          [GCC 8.4.0]
          [GCC 8.4.0]
          -- board config
          -- id config
          -- uart config
          -- tune config
              DONE
              DONE
          disabling bridge
          bridge disabled
          Success!
          Success!
          	NAME    		CURRENT    	NEW
          [11]	MAV_TYPE    		N/A		2
          	NAME    		CURRENT    	NEW
          	NAME    		CURRENT    	NEW
          	NAME    		CURRENT    	NEW
          	NAME    		CURRENT    	NEW
          Success!
          Please guide ahead.
          @Aaky At the PX4 console prompt can you enter the command listener input_rc? Is this a Sentinel drone or a custom drone? Can you calibrate the RC?
            Aaky
            wrote on last edited by Aaky
            #25
            @Eric-Katzfey This is custom drone with sentinel configuration via voxl-configure-mpa.
            I tried "px4-listener input_rc" and it say's "Never published". I am not using any RC at the moment and just relying on radio modem based link with QGC for controlling the UAV. Is RC essential?
            Also I was not getting console on VOXL-PX4 when I ran it from commandline so used px4-listener.
            A Eric KatzfeyE 2 Replies Last reply
            • A Aaky
              Aaky
              @Eric-Katzfey Any update on this issue?
              In my opinion you should be able to replicate this problem easily on your end with fresh flashed beta image.
              Please help ahead.
              • A Aaky
                @Aaky Even if getting RC commands over data link from QGC it will still publish input_rc topics. You need that to be able to arm in manual mode.
                  Aaky
                  @Eric-Katzfey Hi Eric, I did connect joystick and enabled mavlink based RC to UAV. This worked to arm the UAV in manual mode but in GPS mode, arming is still not working and blocking me to start using your newer beta image along with PX4 1.14 firmware version. GPS continues to blink red even in good GPS conditions outdoor and never allows to arm even after proper calibration process for MAG, Accel and Gyro.
                  Please help to debug this further.
                  • A Aaky
                    @Aaky Well that sounds like some progress. When you transition from manual mode to position mode does it allow the transition? Does QGC or voxl-px4 give you any messages at all?
                    A 2 Replies Last reply
                      Aaky
                      #30
                      @Eric-Katzfey
                      I upgraded to official SDK 1.0.0 version now. I am able to transition from manual to position mode on QGC with my joystick connected as RC source. But when I try to arm in position mode QGC again say's "ARM_DISARM command temperorily rejected".
                      Please check logs on this link. When in position mode if I try to arm I do not get any preflight check failure message on PX4 logs.
                      GPS LED still blinks RED continously even in good GPS area outdoor.
                      Please help to debug further.
                        Aaky
                        @Eric-Katzfey One more update. I got all preflight checks cleared by again keeping my UAV in outdoor conditions with joystick RC connected. Now GPS LED glows green. Now I am getting one preflight check problem which is regarding "ESC failure". I tried disabling ModalAI ESC with MODAL_IO_CONFIG = Disabled, but still I am facing problem but I think by connecting ESC this problem should be solved.
                        On a seperate note, Is VOXL2 IO board (M0065) supported now on PX4 1.14 on new SDK? I have use case where I need to connect servo to PX4 (Only option I see is with M0065 + PWM breakout board) along with MODALAI ESC. Please provide some information on this point.
                        • A Aaky
                          @Aaky No, M0065 is not yet supported with 1.14.0. We will be supporting that product on 1.14.0 in a future release.
                          • A Aaky
                            @Eric-Katzfey
                            @Aaky What format is that logs file? Is it an archive?
