  3. VOXL2 SDK 1.0.0-beta6 voxl-px4 couldn't arm UAV (GPS LED always RED blinking)
voxl-2
33 Posts 2 Posters 6.8k Views 1 Watching
  • A Aaky
    @Eric-Katzfey Yes I tried to arm and got failure. What can be the reason as per the logs?
    @Aaky There isn't really anything in the log declaring a preflight failure. If you keep trying to arm do you get anything in the log? What does QGC tell you if you try to arm?
    A 1 Reply Last reply
      Aaky
      wrote on last edited by Aaky
      #19
      @Eric-Katzfey QGC says, " MAV_CMD_COMPONENT_ARM_DISARM temperorily rejected".
      This happens in manual mode and GPS LED blinks red, even after I have completed calibration of Mag, Accel and gyro.
      Also whenever I ARM, I do not get anything on voxl-px4 logs.
      Should I send over my parameter file? Can that help?
      • A Aaky
        @Aaky What is the contents of /data/modalai/sku.txt?
          @Eric-Katzfey Perhaps run voxl-configure-mpa -f sentinel to reconfigure the system and then reboot and try again
            Aaky
            @Eric-Katzfey I didn't had any file on /data/modalai/sku.txt. I ran "voxl-configure-sku -f sentinel" and this file was generated. Now contents in this file are "MRB-D0006-4-V1-C11".
            I tried running voxl-configure-mpa -f sentinel after configuring sku but it fails with following error "Invalid arg: -f, exiting". So I just ran voxl-configure-mpa and below are logs of ths same.
            voxl2:/$ voxl-configure-mpa -d
            enabling debug mode
                           Welcome to voxl-configure-mpa!
            VOXL is currently thinks it is in the following hardware:
            family code:   MRB-D0006 (sentinel)
            compute board: 4 (voxl2)
            hw version:    1
            cam config:    11
            SKU:           MRB-D0006-4-V1-C11
            If this doesn't look right, quit and run voxl-configure-sku to
            set it correctly. Then run voxl-configure-mpa again.
            Continue? y/n: y
            Continuing
            About to Execute:
            voxl-configure-extrinsics sentinel_v1
            voxl-configure-cameras 11
            voxl-configure-cpu-monitor factory_enable
            voxl-configure-qvio factory_enable_imu_apps
            voxl-configure-dfs factory_disable
            voxl-configure-tag-detector factory_disable
            voxl-configure-tflite factory_disable
            voxl-configure-vision-hub factory_enable
            voxl-configure-mavlink-server factory_enable
            voxl-configure-portal enable
            voxl-configure-lepton disable
            voxl-configure-uvc disable
            voxl-configure-streamer factory_enable
            voxl-configure-modem disable
            voxl-configure-mavcam factory_enable
            voxl-configure-px4-imu-server factory_disable
            voxl-configure-imu factory_enable
            voxl-configure-flow-server disable
            voxl-configure-feature-tracker disable
            voxl-esc setup_sentinel_v1
            voxl-configure-px4 sentinel_v1
            voxl-configure-px4-params -np MRB-D0006
            Continue? y/n: y
            Continuing
            enabling voxl-wait-for-fs service
            executing: voxl-configure-extrinsics sentinel_v1
            wiping old extrinsics config file
            copying /usr/share/modalai/extrinsic_configs/sentinel_v1.conf to /etc/modalai/extrinsics.conf
            loading and updating file with voxl-inspect-extrinsics -q
            done configuring extrinsics
            Success!
            executing: voxl-configure-cameras 11
            Camera Configuration: 11
            calling camera-server-config-helper tracking:ov7251:2 hires:imx214:3 stereo_front:ov7251:0:1 stereo_rear:ov7251:5:4
            successfully wrote this camera config to disk:
            configuration for 4 cameras:
            cam #0
                sensor type:         ov7251
                isEnabled:           1
                camId:               2
                camId2:              -1
                fps:                 30
                en_preview:          1
                pre_width:           640
                pre_height:          480
                pre_format:          raw8
                en_small_video:      0
                small_video_width:   -1
                small_video_height:  -1
                en_large_video:      0
                large_video_width:   -1
                large_video_height:  -1
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
                independent_exposure:0
            cam #1
                sensor type:         imx214
                isEnabled:           1
                camId:               3
                camId2:              -1
                fps:                 30
                en_preview:          0
                pre_width:           640
                pre_height:          480
                pre_format:          nv21
                en_small_video:      1
                small_video_width:   1024
                small_video_height:  768
                en_large_video:      1
                large_video_width:   4096
                large_video_height:  2160
                en_snapshot:         1
                snap_width:          4160
                snap_height:         3120
                ae_mode:             isp
                standby_enabled:     0
                decimator:           1
            cam #2
                sensor type:         ov7251
                isEnabled:           1
                camId:               0
                camId2:              1
                fps:                 30
                en_preview:          1
                pre_width:           640
                pre_height:          480
                pre_format:          raw8
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            cam #3
                sensor type:         ov7251
                isEnabled:           1
                camId:               5
                camId2:              4
                fps:                 30
                en_preview:          1
                pre_width:           640
                pre_height:          480
                pre_format:          raw8
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            camera_server_config_helper is done
            copying required camera drivers in place
            /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin
            /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_0.bin
            /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_1.bin
            /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_3.bin
            /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_4.bin
            /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_5.bin
            enabling voxl-camera-server
            Done Configuring Cameras
            Please power cycle VOXL to load new drivers
            camera server will start on next reboot
            Success!
            executing: voxl-configure-cpu-monitor factory_enable
            wiping old config file
            Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
            enabling  voxl-cpu-monitor systemd service
            Done configuring voxl-cpu-monitor
            Success!
            executing: voxl-configure-qvio factory_enable_imu_apps
            loading config file
            Creating new config file: /etc/modalai/voxl-qvio-server.conf
            enabling  voxl-qvio-server systemd service
            Done configuring voxl-qvio-server
            Success!
            executing: voxl-configure-dfs factory_disable
            Creating new config file: /etc/modalai/voxl-dfs-server.conf
            disabling voxl-dfs-server systemd service
            stopping voxl-dfs-server systemd service
            Done configuring voxl-dfs-server
            Success!
            executing: voxl-configure-tag-detector factory_disable
            Creating new config file: /etc/modalai/voxl-tag-detector.conf
            disabling voxl-tag-detector systemd service
            stopping voxl-tag-detector systemd service
            Done configuring voxl-tag-detector
            Success!
            executing: voxl-configure-tflite factory_disable
            Creating new config file: /etc/modalai/voxl-tflite-server.conf
            The config file was modified during parsing, saving the changes to disk
            disabling voxl-tflite-server systemd service
            stopping voxl-tflite-server systemd service
            Done configuring voxl-tflite-server
            Success!
            executing: voxl-configure-vision-hub factory_enable
            Created new json file: /etc/modalai/voxl-vision-hub.conf
            The JSON config file data was modified during parsing, saving the changes to disk
            enabling  voxl-vision-hub systemd service
            Done configuring voxl-vision-hub
            service will start on next reboot
            Success!
            executing: voxl-configure-mavlink-server factory_enable
            Created new json file: /etc/modalai/voxl-mavlink-server.conf
            enabling  voxl-mavlink-server systemd service
            Done configuring voxl-mavlink-server
            Success!
            executing: voxl-configure-portal enable
            enabling  voxl-portal systemd service
            Done configuring voxl-portal
            Success!
            executing: voxl-configure-lepton disable
            disabling voxl-lepton-server systemd service
            stopping voxl-lepton-server systemd service
            Done configuring voxl-lepton-server
            Success!
            executing: voxl-configure-uvc disable
            disabling voxl-uvc-server systemd service
            stopping voxl-uvc-server systemd service
            Done configuring voxl-uvc-server
            Success!
            executing: voxl-configure-streamer factory_enable
            Creating new config file: /etc/modalai/voxl-streamer.conf
            writing /etc/modalai/voxl-streamer.conf to disk
            parsed config file
            enabling  voxl-streamer systemd service
            Done configuring voxl-streamer, it will start on next reboot
            Success!
            executing: voxl-configure-modem disable
            disabling voxl-modem systemd service
            stopping voxl-modem systemd service
            Done configuring voxl-modem
            Success!
            executing: voxl-configure-mavcam factory_enable
            Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
            writing /etc/modalai/voxl-mavcam-manager.conf to disk
            enabling  voxl-mavcam-manager systemd service
            Done configuring voxl-mavcam-manager
            It will start automatically on the next reboot
            Success!
            executing: voxl-configure-px4-imu-server factory_disable
            disabling voxl-px4-imu-server systemd service
            stopping voxl-px4-imu-server systemd service
            Done configuring voxl-px4-imu-server
            Success!
            executing: voxl-configure-imu factory_enable
            Creating new config file: /etc/modalai/voxl-imu-server.conf
            voxl-imu-server currently has no calibration file
            enabling  voxl-imu-server systemd service
            Done configuring voxl-imu-server
            Success!
            executing: voxl-configure-flow-server disable
            disabling voxl-flow-server systemd service
            stopping voxl-flow-server systemd service
            Done configuring voxl-flow-server
            Success!
            executing: voxl-configure-feature-tracker disable
            disabling voxl-feature-tracker systemd service
            stopping voxl-feature-tracker systemd service
            Done configuring voxl-feature-tracker
            Success!
            executing: voxl-esc setup_sentinel_v1
            enabling bridge
            detected voxl-px4 is enabled
            Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
            detected voxl-px4 is running, stopping it now
            bridge enabled
            [INFO] Scanning for ESC...
            [INFO] M0117-1 detected
            [INFO] has for most recent firmware: 83faccfa
            [INFO] Expected ESC firmware info:
            	Firmware: modalai_esc_firmware_m0117_1_v0_38_83faccfa.bin
            	Firmware hash: 83faccfa
            [INFO] Number of ESCs with correct FW: 4
            [INFO] All of the ESCs have the correct firmware loaded
            uploading params file ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
            [GCC 8.4.0]
            VOXL Platform: M0054
            Detected VOXL2 M0054 or M0104!
            Found previous connection information in .voxl_esc_cache ..
            Prioritizing /dev/slpi-uart-2 @ 2000000
            Sending library name request: libslpi_uart_bridge_slpi.so
            INFO: Additional Information:
            INFO: ---------------------
            	Board      : version 34: ModalAi 4-in-1 ESC (M0117-1)
            	UID        : 0x203034305743570C00270034
            	Firmware   : version   38, hash 83faccfa
            	Bootloader : version  183, hash 25317f42
            	UID        : 0x203034305743570C003A0054
            	UID        : 0x203034305743570C00210050
            	UID        : 0x203034305743570C00280028
            successfully pinged ESCs
            [GCC 8.4.0]
            INFO: Params file name : ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
            INFO: Params file size : 7591 bytes
            INFO: ESCs detected:
            ID: 0, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            ID: 1, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            ID: 2, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            ID: 3, SW: 38, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            INFO: Loading XML config file...
            INFO: Uploading params...
            -- board config
            -- id config
            -- uart config
            -- tune config
                DONE
            INFO: Resetting ESCs...
                DONE
            disabling bridge
            re-enabling voxl-px4
            Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
            restarting voxl-px4
            bridge disabled
            Success!
            executing: voxl-configure-px4 sentinel_v1
            enabling  voxl-px4 systemd service
            Success!
            executing: voxl-configure-px4-params -np MRB-D0006
            [INFO] Voxl-px4 service found and active.
            [INFO] about to load the following param files:
            ('platforms/Sentinel_V1.params', 'EKF2_helpers/outdoor_gps_baro.params')
            [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Sentinel_V1.params
            [INFO] Scanning currently loaded parameters...
            The following parameters about to be loaded differ from those currently loaded:
            	NAME    		CURRENT    	NEW
            [1]	CBRK_IO_SAFETY    	N/A		22027
            [2]	CBRK_SUPPLY_CHK    	N/A		894281
            [3]	COM_CPU_MAX    		N/A		-1
            [4]	COM_OF_LOSS_T    	N/A		3.0
            [5]	NAV_ACC_RAD    		N/A		2.0
            [6]	GPS_UBX_DYNMODEL    	N/A		6
            [7]	RTL_RETURN_ALT    	N/A		30
            [8]	RTL_DESCEND_ALT    	N/A		10
            [9]	IMU_GYRO_RATEMAX    	N/A		800
            [10]	SYS_AUTOSTART    	N/A		4001
            [11]	MAV_TYPE    		N/A		2
            [12]	SENS_BOARD_ROT    	N/A		0
            [13]	BAT1_N_CELLS    	N/A		3
            [14]	BAT1_R_INTERNAL    	N/A		0.003
            [15]	BAT1_CAPACITY    	N/A		4700
            [16]	BAT1_V_CHARGED    	N/A		4.15
            [17]	BAT1_V_EMPTY    	N/A		3.50
            [18]	BAT_LOW_THR    		N/A		0.15
            [19]	BAT_CRIT_THR    	N/A		0.10
            [20]	BAT_EMERGEN_THR    	N/A		0.05
            [21]	MPC_THR_HOVER    	N/A		0.41
            [22]	THR_MDL_FAC    		N/A		0.80
            [23]	MODAL_IO_RPM_MAX    	N/A		7000
            [24]	MODAL_IO_RPM_MIN    	N/A		1000
            [25]	MODAL_IO_FUNC1    	N/A		103
            [26]	MODAL_IO_FUNC2    	N/A		102
            [27]	MODAL_IO_FUNC3    	N/A		104
            [28]	MODAL_IO_FUNC4    	N/A		101
            [29]	MODAL_IO_SDIR1    	N/A		0
            [30]	MODAL_IO_SDIR2    	N/A		0
            [31]	MODAL_IO_SDIR3    	N/A		0
            [32]	MODAL_IO_SDIR4    	N/A		0
            [33]	MODAL_IO_BAUD    	N/A		2000000
            [34]	MODAL_IO_CONFIG    	N/A		1
            [35]	MODAL_IO_MODE    	N/A		0
            [36]	MODAL_IO_REV    	N/A		0
            [37]	MODAL_IO_T_COSP    	N/A		0.990000009536743164
            [38]	MODAL_IO_T_DEAD    	N/A		20
            [39]	MODAL_IO_T_EXPO    	N/A		35
            [40]	MODAL_IO_T_MINF    	N/A		0.150000005960464478
            [41]	MODAL_IO_T_PERC    	N/A		90
            [42]	MODAL_IO_VLOG    	N/A		1
            [43]	MC_BAT_SCALE_EN    	N/A		0
            [44]	EKF2_IMU_POS_X    	N/A		0.033
            [45]	EKF2_IMU_POS_Y    	N/A		0.008
            [46]	EKF2_IMU_POS_Z    	N/A		-0.036
            [47]	EKF2_EV_POS_X    	N/A		0.0
            [48]	EKF2_EV_POS_Y    	N/A		0.0
            [49]	EKF2_EV_POS_Z    	N/A		0.0
            [50]	CA_AIRFRAME    		N/A		0
            [51]	CA_ROTOR_COUNT    	N/A		4
            [52]	CA_ROTOR0_PX    	N/A		0.17
            [53]	CA_ROTOR0_PY    	N/A		0.17
            [54]	CA_ROTOR1_PX    	N/A		-0.17
            [55]	CA_ROTOR1_PY    	N/A		-0.17
            [56]	CA_ROTOR2_PX    	N/A		0.17
            [57]	CA_ROTOR2_PY    	N/A		-0.17
            [58]	CA_ROTOR3_PX    	N/A		-0.17
            [59]	CA_ROTOR3_PY    	N/A		0.17
            [60]	CA_ROTOR0_AX    	N/A		0.0
            [61]	CA_ROTOR0_AY    	N/A		0.0
            [62]	CA_ROTOR1_AX    	N/A		0.0
            [63]	CA_ROTOR1_AY    	N/A		0.0
            [64]	CA_ROTOR2_AX    	N/A		0.0
            [65]	CA_ROTOR2_AY    	N/A		0.0
            [66]	CA_ROTOR3_AX    	N/A		0.0
            [67]	CA_ROTOR3_AY    	N/A		0.0
            [68]	CA_ROTOR0_KM    	N/A		0.05
            [69]	CA_ROTOR1_KM    	N/A		0.05
            [70]	CA_ROTOR2_KM    	N/A		-0.05
            [71]	CA_ROTOR3_KM    	N/A		-0.05
            [72]	MOT_SLEW_MAX    	N/A		0.0
            [73]	IMU_DGYRO_CUTOFF    	N/A		40.0
            [74]	IMU_ACCEL_CUTOFF    	N/A		40.0
            [75]	IMU_GYRO_CUTOFF    	N/A		40.0
            [76]	IMU_GYRO_DNF_EN    	N/A		1
            [77]	IMU_GYRO_DNF_HMC    	N/A		3
            [78]	IMU_GYRO_DNF_BW    	N/A		15
            [79]	MC_AIRMODE    		N/A		0
            [80]	MC_PITCH_P    		N/A		5.5
            [81]	MC_PITCHRATE_P    	N/A		0.080
            [82]	MC_PITCHRATE_I    	N/A		0.400
            [83]	MC_PITCHRATE_D    	N/A		0.00
            [84]	MC_PITCHRATE_K    	N/A		1.0
            [85]	MC_ROLL_P    		N/A		5.5
            [86]	MC_ROLLRATE_P    	N/A		0.080
            [87]	MC_ROLLRATE_I    	N/A		0.400
            [88]	MC_ROLLRATE_D    	N/A		0.00
            [89]	MC_ROLLRATE_K    	N/A		1.0
            [90]	MC_YAW_P    		N/A		2.0
            [91]	MC_YAWRATE_P    	N/A		0.13
            [92]	MC_YAWRATE_I    	N/A		0.30
            [93]	MC_YAWRATE_D    	N/A		0.0
            [94]	MC_YAWRATE_K    	N/A		1.0
            [95]	MC_ROLLRATE_MAX    	N/A		150.0
            [96]	MC_PITCHRATE_MAX    	N/A		150.0
            [97]	MC_YAWRATE_MAX    	N/A		150.0
            [98]	MPC_POS_MODE    	N/A		4
            [99]	MPC_YAW_EXPO    	N/A		0.30
            [100]	MPC_XY_MAN_EXPO    	N/A		0.45
            [101]	MPC_Z_MAN_EXPO    	N/A		0.10
            [102]	MPC_ACC_HOR    		N/A		3.0
            [103]	MPC_JERK_MAX    	N/A		40.0
            [104]	MPC_TILTMAX_AIR    	N/A		30.0
            [105]	MPC_ACC_HOR_MAX    	N/A		6.0
            [106]	MPC_ACC_UP_MAX    	N/A		3.0
            [107]	MPC_ACC_DOWN_MAX    	N/A		3.0
            [108]	MPC_VEL_MANUAL    	N/A		5.0
            [109]	MPC_XY_VEL_MAX    	N/A		5.0
            [110]	MPC_XY_CRUISE    	N/A		5.0
            [111]	MPC_Z_VEL_MAX_DN    	N/A		1.5
            [112]	MPC_Z_VEL_MAX_UP    	N/A		4.0
            [113]	MPC_LAND_SPEED    	N/A		1.0
            [114]	MPC_THR_MAX    		N/A		0.75
            [115]	MPC_THR_MIN    		N/A		0.12
            [116]	MPC_MANTHR_MIN    	N/A		0.12
            [117]	MPC_XY_P    		N/A		0.95
            [118]	MPC_XY_VEL_P_ACC    	N/A		3.00
            [119]	MPC_XY_VEL_I_ACC    	N/A		0.10
            [120]	MPC_XY_VEL_D_ACC    	N/A		0.00
            [121]	MPC_Z_P    		N/A		1.0
            [122]	MPC_Z_VEL_P_ACC    	N/A		8.0
            [123]	MPC_Z_VEL_I_ACC    	N/A		2.0
            [124]	MPC_Z_VEL_D_ACC    	N/A		0.0
            [125]	MPC_TKO_RAMP_T    	N/A		2.00
            [126]	MPC_TKO_SPEED    	N/A		1.50
            [127]	COM_SPOOLUP_TIME    	N/A		1.0
            [128]	LNDMC_ROT_MAX    	N/A		30.0
            [129]	COM_DISARM_LAND    	N/A		0.1
            [130]	COM_DISARM_PRFLT    	N/A		20
            [INFO] Setting params...
            [ERROR] Failed to set px4-parameters. Check voxl-px4 status for details.
            FAILED TO EXECUTE: voxl-configure-px4-params -np MRB-D0006
            This is likely because voxl-px4 on the SDSP failed to restart.
            Please try running voxl-configure-mpa again.
            If that doesn't work, power cycle and try again.
            checking /data/modalai/voxl-imu-server.cal
            checking /data/modalai/opencv_tracking_intrinsics.yml
            checking /data/modalai/opencv_stereo_front_intrinsics.yml
            checking /data/modalai/opencv_stereo_front_extrinsics.yml
            checking /data/modalai/opencv_stereo_rear_intrinsics.yml
            checking /data/modalai/opencv_stereo_rear_extrinsics.yml
                     FAILED TO EXECUTE the following steps:
                  Encountered Problems Configuring MPA Services :-/
                    Some Services may not start up on next reboot
            Calibration File Status:
            Missing /data/modalai/voxl-imu-server.cal
            Missing /data/modalai/opencv_tracking_intrinsics.yml
            Missing /data/modalai/opencv_stereo_front_intrinsics.yml
            Missing /data/modalai/opencv_stereo_front_extrinsics.yml
            Missing /data/modalai/opencv_stereo_rear_intrinsics.yml
            Missing /data/modalai/opencv_stereo_rear_extrinsics.yml
            Present /data/px4/param/parameters_gyro.cal
            Present /data/px4/param/parameters_acc.cal
            Present /data/px4/param/parameters_mag.cal
            Present /data/px4/param/parameters_level.cal
            Detected Missing Calibration Files
            please run the required cals
            https://docs.modalai.com/calibration/
                            PLEASE POWER CYCLE YOUR VOXL
            I power cycled VOXL2 after this message but still no luck. I still see some preflight check failing and couldn't arm the uav in manual mode. Even in indoor my GPS data is ok with HDOP of 0.9.
            Do you see any problem with execution of voxl-configure-mpa?
            • A Aaky
              enabling debug mode
              hw version:    1
              cam config:    11
              Continue? y/n: y
              Continuing
              About to Execute:
              Continue? y/n: y
              Continuing
              Success!
              cam #0
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               2
                  camId2:              -1
                  fps:                 30
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  pre_format:          raw8
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              cam #1
                  sensor type:         imx214
                  isEnabled:           1
                  camId:               3
                  camId2:              -1
                  fps:                 30
                  en_preview:          0
                  pre_width:           640
                  pre_height:          480
                  pre_format:          nv21
                  en_small_video:      1
                  en_large_video:      1
                  en_snapshot:         1
                  snap_width:          4160
                  snap_height:         3120
                  ae_mode:             isp
                  standby_enabled:     0
                  decimator:           1
              cam #2
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               0
                  camId2:              1
                  fps:                 30
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  pre_format:          raw8
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              cam #3
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               5
                  camId2:              4
                  fps:                 30
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  pre_format:          raw8
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              Success!
              Success!
              loading config file
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              parsed config file
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              Success!
              enabling bridge
              bridge enabled
              [GCC 8.4.0]
              [GCC 8.4.0]
              -- board config
              -- id config
              -- uart config
              -- tune config
                  DONE
                  DONE
              disabling bridge
              restarting voxl-px4
              bridge disabled
              Success!
              Success!
              	NAME    		CURRENT    	NEW
              [11]	MAV_TYPE    		N/A		2
              Aaky
              I ran mpa configuration while fresh installation of beta image and below are logs where PX4 parameters were set correctly. Please have a look.
                          Welcome to the voxl-configure-sku Wizard!
              [WARN] Detected both the old sku file /data/modalai/factory_mode.txt
              [WARN] and the new one: /data/modalai/sku.txt
              [WARN] Deleting the old one
              VOXL currently thinks it is in the following hardware:
              hw version:    1
              cam config:    11
              If this is what you want, select 1 (accept and continue) to
              leave it as-is. Otherwise, select the desired product family:
              1) accept and continue	      9) flight-deck
              2) starling		     10) voxl-deck
              3) sentinel		     11) voxl2-flight-deck
              4) fpv			     12) voxl2-test-fixture
              5) m500			     13) voxl2-mini-test-fixture
              6) voxlcam		     14) voxl2-board-only
              7) seeker		     15) voxl2-mini-board-only
              8) rb5-flight
              #? 3
              selected sentinel
              Please choose what camera config is on this drone
              The default camera config for RB5-Flight and Sentinel
              is 11 (hires+tracking+dual_stereo)
              q  Quit The Wizard
              0  None
              1  tracking(ov7251) + Stereo(ov7251)
              2  tracking(ov7251) Only
              3  Hires(imx214) + Stereo(ov7251) + tracking(ov7251)
              4  Hires(imx214) + tracking(ov7251)
              5  TOF + tracking(ov7251)
              6 Hires(imx214) + TOF + tracking(ov7251)
              7  TOF + Stereo(ov7251) + tracking(ov7251)
              8  Hires(imx214) Only
              9  TOF Only
              10 Stereo(ov7251) only
              11 tracking(ov7251) + Hires(imx214) + Dual Stereo
              12 Stereo(OV9782) only
              13 Hires(imx214) + Stereo(ov7251)
              14 Stereo(OV9782) + TOF + tracking(ov7251)
              15 Dual OV9782
              Cam Config Number: 6
              Your answers would construct the following SKU:
              hw version:    1
              cam config:    6
              SKU:           MRB-D0006-4-V1-C6
              Would you like to continue? This sku will be saved
              to persistent memory so VOXL will remember what it
              is installed in, even between system image flashes.
              1) save and continue
              2) quit
              3) restart wizard
              #? 1
              Continuing
              DONE, MRB-D0006-4-V1-C6 has been written to /data/modalai/sku.txt
              Next you will likely want to run voxl-configure-mpa
              Wifi is currently set up as follows:
              	Current mode: softap
              	Current ssid: Aerotitan
              Station mode is for connecting to a normal wifi network.
              In softap mode, the VOXL will broadcast its own wifi network.
              Factory mode will set up softap with the following unique SSID:
              	VOXL-00:30:1a:50:1c:a1
              Please enter the intended Wi-Fi operation
              Options:
              	1) leave as-is
              	2) station
              	3) softap
              	4) factory
              Operation: 3
              Please enter the SSID to broadcast
              SSID: Aerotitan
              Aerotitan
              Please enter a password, or leave blank to use the default password.
              Password [default: 1234567890]: 1234567890
              1234567890
              Configuring...
              editing /data/misc/wifi/hostapd.conf for softap mode, ssid is: Aerotitan
              creating new wpa_supplicant.conf for softap mode, ssid is: Aerotitan
              soft AP Setup Complete!
              Changes should be active in a few seconds
              SoftAP Configuration succeeded!
              enabling non-interactive mode
              hw version:    1
              cam config:    6
              About to Execute:
              voxl-configure-cameras 6
              Success!
              executing: voxl-configure-cameras 6
              Camera Configuration: 6
              calling camera-server-config-helper tof:pmd-tof:0 hires:imx214:1 tracking:ov7251:2
              configuration for 3 cameras:
              cam #0
                  sensor type:         pmd-tof
                  isEnabled:           1
                  camId:               0
                  camId2:              -1
                  fps:                 5
                  en_preview:          1
                  pre_width:           224
                  pre_height:          1557
                  pre_format:          tof
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             off
                  standby_enabled:     0
                  decimator:           5
              cam #1
                  sensor type:         imx214
                  isEnabled:           1
                  camId:               1
                  camId2:              -1
                  fps:                 30
                  en_preview:          0
                  pre_width:           640
                  pre_height:          480
                  pre_format:          nv21
                  en_small_video:      1
                  en_large_video:      1
                  en_snapshot:         1
                  snap_width:          4160
                  snap_height:         3120
                  ae_mode:             isp
                  standby_enabled:     0
                  decimator:           1
              cam #2
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               2
                  camId2:              -1
                  fps:                 30
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  pre_format:          raw8
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
              /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
              /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-camera-server.service → /etc/systemd/system/voxl-camera-server.service.
              Success!
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-cpu-monitor.service → /etc/systemd/system/voxl-cpu-monitor.service.
              Success!
              loading config file
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-qvio-server.service → /etc/systemd/system/voxl-qvio-server.service.
              Success!
              Success!
              Success!
              Success!
              Automatically migrating old config file /etc/modalai/voxl-vision-px4.conf to new location: /etc/modalai/voxl-vision-hub.conf
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-vision-hub.service → /etc/systemd/system/voxl-vision-hub.service.
              Success!
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-mavlink-server.service → /etc/systemd/system/voxl-mavlink-server.service.
              Success!
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-portal.service → /etc/systemd/system/voxl-portal.service.
              Success!
              Success!
              Success!
              parsed config file
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-streamer.service → /etc/systemd/system/voxl-streamer.service.
              Success!
              Success!
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-mavcam-manager.service → /etc/systemd/system/voxl-mavcam-manager.service.
              Success!
              Success!
              missing gyro0_offset, removing old empty file
              Created symlink /etc/systemd/system/multi-user.target.wants/voxl-imu-server.service → /etc/systemd/system/voxl-imu-server.service.
              Success!
              Success!
              Success!
              enabling bridge
              bridge enabled
              [GCC 8.4.0]
              [GCC 8.4.0]
              -- board config
              -- id config
              -- uart config
              -- tune config
                  DONE
                  DONE
              disabling bridge
              bridge disabled
              Success!
              Success!
              [INFO] Voxl-px4 not currently running
              [INFO] Starting voxl-px4 service...
              [INFO] Voxl-px4 started successfully!
              	NAME    		CURRENT    	NEW
              [11]	MAV_TYPE    		N/A		2
              [INFO] Px4 parameter configuration successful!
              [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/outdoor_gps_baro.params
              	NAME    		CURRENT    	NEW
              [1]	SYS_HAS_MAG    		N/A		1
              [2]	SYS_HAS_GPS    		N/A		1
              [3]	EKF2_MAG_TYPE    	N/A		0
              [4]	EKF2_GPS_CTRL    	N/A		7
              [5]	EKF2_EV_CTRL    	N/A		0
              [6]	EKF2_AID_MASK    	N/A		0
              [7]	EKF2_HGT_REF    	N/A		0
              [8]	COM_ARM_WO_GPS    	N/A		1
              [INFO] Loading file: /data/px4/param/parameters_gyro.cal
              	NAME    		CURRENT    	NEW
              [1]	CAL_GYRO0_ID    	N/A		2490378
              [2]	CAL_GYRO0_PRIO    	N/A		50
              [3]	CAL_GYRO0_XOFF    	N/A		0.0227608
              [4]	CAL_GYRO0_YOFF    	N/A		0.00552622
              [5]	CAL_GYRO0_ZOFF    	N/A		-0.0139491
              [6]	CAL_GYRO0_ROT    	N/A		-1
              [INFO] Loading file: /data/px4/param/parameters_level.cal
              	NAME    		CURRENT    	NEW
              [1]	SENS_BOARD_X_OFF    	N/A		-4.80679
              [2]	SENS_BOARD_Y_OFF    	N/A		-2.07214
              [INFO] Loading file: /data/px4/param/parameters_mag.cal
              	NAME    		CURRENT    	NEW
              [1]	CAL_MAG0_ID    		N/A		396809
              [2]	CAL_MAG0_PRIO    	N/A		75
              [3]	CAL_MAG0_XOFF    	N/A		0.0189662
              [4]	CAL_MAG0_YOFF    	N/A		-0.0148698
              [5]	CAL_MAG0_ZOFF    	N/A		0.163498
              [6]	CAL_MAG0_XSCALE    	N/A		1.01365
              [7]	CAL_MAG0_YSCALE    	N/A		0.922817
              [8]	CAL_MAG0_ZSCALE    	N/A		1.10712
              [9]	CAL_MAG0_XODIAG    	N/A		0.0136699
              [10]	CAL_MAG0_YODIAG    	N/A		0.0716552
              [11]	CAL_MAG0_ZODIAG    	N/A		0.0244222
              [12]	CAL_MAG0_XCOMP    	N/A		0
              [13]	CAL_MAG0_YCOMP    	N/A		0
              [14]	CAL_MAG0_ZCOMP    	N/A		0
              [15]	CAL_MAG0_ROT    	N/A		0
              [INFO] Done configuring for platform MRB-D0006
              Success!
                      SUCCESSFULLY CONFIGURED MPA SERVICES!
                      Services will start up on next reboot
              SDK Install Completed
              But even after this installation success as compared to previous installation I am facing same problem of not able to arm the UAV and GPS LED blinking red always. On the exact same indoor location where I am testing 1.14 firmware version I downgraded complete system image to platform 0.9.5 with PX4 version 1.12.31 and I am able to arm the UAV and holybro GPS LED blows Green and QGC goes in "Ready to fly condition."
              Please guide ahead.
              • A Aaky
                hw version:    1
                cam config:    11
                8) rb5-flight
                #? 3
                selected sentinel
                q  Quit The Wizard
                0  None
                9  TOF Only
                15 Dual OV9782
                hw version:    1
                cam config:    6
                2) quit
                3) restart wizard
                #? 1
                Continuing
                Options:
                	1) leave as-is
                	2) station
                	3) softap
                	4) factory
                Operation: 3
                SSID: Aerotitan
                Aerotitan
                1234567890
                Configuring...
                hw version:    1
                cam config:    6
                About to Execute:
                Success!
                cam #0
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 5
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    pre_format:          tof
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    standby_enabled:     0
                    decimator:           5
                cam #1
                    sensor type:         imx214
                    isEnabled:           1
                    camId:               1
                    camId2:              -1
                    fps:                 30
                    en_preview:          0
                    pre_width:           640
                    pre_height:          480
                    pre_format:          nv21
                    en_small_video:      1
                    en_large_video:      1
                    en_snapshot:         1
                    snap_width:          4160
                    snap_height:         3120
                    ae_mode:             isp
                    standby_enabled:     0
                    decimator:           1
                cam #2
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               2
                    camId2:              -1
                    fps:                 30
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    pre_format:          raw8
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    standby_enabled:     0
                    decimator:           1
                Success!
                Success!
                loading config file
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                parsed config file
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                Success!
                enabling bridge
                bridge enabled
                [GCC 8.4.0]
                [GCC 8.4.0]
                -- board config
                -- id config
                -- uart config
                -- tune config
                    DONE
                    DONE
                disabling bridge
                bridge disabled
                Success!
                Success!
                	NAME    		CURRENT    	NEW
                [11]	MAV_TYPE    		N/A		2
                	NAME    		CURRENT    	NEW
                	NAME    		CURRENT    	NEW
                	NAME    		CURRENT    	NEW
                	NAME    		CURRENT    	NEW
                Success!
                Please guide ahead.
                @Aaky At the PX4 console prompt can you enter the command listener input_rc? Is this a Sentinel drone or a custom drone? Can you calibrate the RC?
                  Aaky
                  #25
                  @Eric-Katzfey This is custom drone with sentinel configuration via voxl-configure-mpa.
                  I tried "px4-listener input_rc" and it say's "Never published". I am not using any RC at the moment and just relying on radio modem based link with QGC for controlling the UAV. Is RC essential?
                  Also I was not getting console on VOXL-PX4 when I ran it from commandline so used px4-listener.
                  A Eric KatzfeyE 2 Replies Last reply
                  • A Aaky
                    Aaky
                    @Eric-Katzfey Any update on this issue?
                    In my opinion you should be able to replicate this problem easily on your end with fresh flashed beta image.
                    Please help ahead.
                    • A Aaky
                      @Aaky Even if getting RC commands over data link from QGC it will still publish input_rc topics. You need that to be able to arm in manual mode.
                        Aaky
                        @Eric-Katzfey Hi Eric, I did connect joystick and enabled mavlink based RC to UAV. This worked to arm the UAV in manual mode but in GPS mode, arming is still not working and blocking me to start using your newer beta image along with PX4 1.14 firmware version. GPS continues to blink red even in good GPS conditions outdoor and never allows to arm even after proper calibration process for MAG, Accel and Gyro.
                        Please help to debug this further.
                        • A Aaky
                          @Aaky Well that sounds like some progress. When you transition from manual mode to position mode does it allow the transition? Does QGC or voxl-px4 give you any messages at all?
                          A 2 Replies Last reply
                            Aaky
                            #30
                            I upgraded to official SDK 1.0.0 version now. I am able to transition from manual to position mode on QGC with my joystick connected as RC source. But when I try to arm in position mode QGC again say's "ARM_DISARM command temperorily rejected".
                            Please check logs on this link. When in position mode if I try to arm I do not get any preflight check failure message on PX4 logs.
                            GPS LED still blinks RED continously even in good GPS area outdoor.
                            Please help to debug further.
                              Aaky
                              @Eric-Katzfey One more update. I got all preflight checks cleared by again keeping my UAV in outdoor conditions with joystick RC connected. Now GPS LED glows green. Now I am getting one preflight check problem which is regarding "ESC failure". I tried disabling ModalAI ESC with MODAL_IO_CONFIG = Disabled, but still I am facing problem but I think by connecting ESC this problem should be solved.
                              On a seperate note, Is VOXL2 IO board (M0065) supported now on PX4 1.14 on new SDK? I have use case where I need to connect servo to PX4 (Only option I see is with M0065 + PWM breakout board) along with MODALAI ESC. Please provide some information on this point.
                              • A Aaky
                                @Aaky No, M0065 is not yet supported with 1.14.0. We will be supporting that product on 1.14.0 in a future release.
                                • A Aaky
                                  @Aaky What format is that logs file? Is it an archive?
