  3. VOXL_Flight Deck : Issue in Viewing Point Cloud from TOF Sensor/ tracking image sensors
flight-deck
1 Posts 1 Posters 805 Views
  • Prasanth Kumar DubaP Offline
    Prasanth Kumar Duba
    I would like to view the point cloud data from TOF , tracking image and stereo image sensors data in ROS platform. After gone through the steps, identified the tof and stereo are not advertising. Please check the console output and help me in this regard.
    roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/e9401558-1dd3-11b2-8acb-18473db1c7ad/roslaunch-apq8096-3329.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    started roslaunch server http://192.168.8.1:45675/
    SUMMARY
    PARAMETERS
    • /mpa/voxl_mpa_to_ros_node/image0_pipe: tracking
    • /mpa/voxl_mpa_to_ros_node/image0_publish: True
    • /mpa/voxl_mpa_to_ros_node/image1_pipe: hires_preview
    • /mpa/voxl_mpa_to_ros_node/image1_publish: True
    • /mpa/voxl_mpa_to_ros_node/image2_pipe: qvio_overlay
    • /mpa/voxl_mpa_to_ros_node/image2_publish: True
    • /mpa/voxl_mpa_to_ros_node/image3_pipe:
    • /mpa/voxl_mpa_to_ros_node/image3_publish: False
    • /mpa/voxl_mpa_to_ros_node/image4_pipe:
    • /mpa/voxl_mpa_to_ros_node/image4_publish: False
    • /mpa/voxl_mpa_to_ros_node/image5_pipe:
    • /mpa/voxl_mpa_to_ros_node/image5_publish: False
    • /mpa/voxl_mpa_to_ros_node/imu0_pipe: imu0
    • /mpa/voxl_mpa_to_ros_node/imu0_publish: True
    • /mpa/voxl_mpa_to_ros_node/imu1_pipe: imu1
    • /mpa/voxl_mpa_to_ros_node/imu1_publish: True
    • /mpa/voxl_mpa_to_ros_node/stereo_pipe: stereo
    • /mpa/voxl_mpa_to_ros_node/stereo_publish: True
    • /mpa/voxl_mpa_to_ros_node/tof_cutoff: 100
    • /mpa/voxl_mpa_to_ros_node/tof_pipe: tof
    • /mpa/voxl_mpa_to_ros_node/tof_publish: True
    • /mpa/voxl_mpa_to_ros_node/vio0_pipe: qvio
    • /mpa/voxl_mpa_to_ros_node/vio0_publish: True
    • /mpa/voxl_mpa_to_ros_node/vio1_pipe:
    • /mpa/voxl_mpa_to_ros_node/vio1_publish: False
    • /rosdistro: indigo
    • /rosversion: 1.11.21
    NODES
    /mpa/
    voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
    auto-starting new master
    process[master]: started with pid [3348]
    ROS_MASTER_URI=http://localhost:11311/
    setting /run_id to e9401558-1dd3-11b2-8acb-18473db1c7ad
    process[rosout-1]: started with pid [3361]
    process[mpa/voxl_mpa_to_ros_node-2]: started with pid [3375]
    Param: "image3_publish" set to false, not publishing associated interface
    Param: "image4_publish" set to false, not publishing associated interface
    Param: "image5_publish" set to false, not publishing associated interface
    Param: "vio1_publish" set to false, not publishing associated interface
    Starting Manager Thread with 8 interfaces
    MPA to ROS app is now running
    Did not find pipe for interface: tracking,
    interface will be idle until its pipe appears
    Did not find pipe for interface: hires_preview,
    Did not find pipe for interface: qvio_overlay,
    Did not find pipe for interface: stereo,
    Found pipe for interface: tof, now advertising
    Found pipe for interface: imu0, now advertising
    Found pipe for interface: imu1, now advertising
    Found pipe for interface: qvio, now advertising
    Thanks & Regards
    Prasanth Kumar Duba
    IIT Hyderabad
