Broken Package? Unable to configure cameras and hires video record.
With the aim to use
voxl-record-video(which is not available in stable branch), I switched the pkg manager to dev. Now when I try to configure cameras usingvoxl-configure-cameras 6(HiRes + tracking + ToF), the following error appears:voxl2:/$ voxl-configure-cameras 6 Camera Configuration: 6 [ERROR] Your system image is too old to support the new camera driver structure [ERROR] Plese update to a system image newer than May 14 2023I have reflashed the Voxl2 and configured the cameras prior to switching to the dev repository. With that, when I try to record a video, It receives nothing on the hires_record pipeline.
voxl2:/$ voxl-record-video hires_record -o cameratest.h264 waiting for server at /run/mpa/hires_record/It’ll be great if someone could help me with this issue.
Thanks in advance for the help.
You can use
voxl-list-pipesto debug your issue -
@Chad-Sweet said in Broken Package? Unable to configure cameras and hires video record.:
voxl-list-pipe
Hi, Thank you for your response.
The following is the output of thevoxl-list-pipesvoxl2:/$ voxl-list-pipes hires tof tof_conf tof_depth tof_ir tof_pc trackingout of these, when I try to inspect the hires pipeline using
voxl-inspect-cam hires, I get a constant flow of frame details as one would normally expect.
I am not sure how to inspect the hires_record pipeline. The full command for hires video recording as given on the ModalAI technical docs is
voxl-record-video hires_record -o /PATH/NAME.h264Which expects a stream to the /run/mpa/hires_record/Your help will be much appreciated. Kindly let me know if I am doing something wrong.
you are using the dev branch, so the docs are not going to match what you are doing
if you are using the dev branch, all of the packages need to be on the dev branch. If just one is on the dev branch, and the rest stable, things will break.
I see. Appreciate your help. Currently everything is on the dev branch. The two issues that I have originally mentioned prevail viz.
(1)voxl-configure-camera 6is giving the error that sysytem image is too old (I am currently on voxl2 image 0.9.5 which is the latest one available in the developer assets). I am able to manually configure the cameras by editing/etc/modalai/voxl-camera-server.conffile to fit my camera arrangement.
I am able to see the stream of cameras on thevoxl-portal.(2)
voxl-record-videocommand Is still showingwaiting for server at /run/mpa/hires_record/Am I supposed to use some other command to be able to record video?
@Jyotish-Kumar i have faced the same issue. the record pipe name has changed in dev branch, try to use
hires_large_encoded or hires_small_encoded based on your resolution requirement. Can find more config parameters in /etc/modalai/voxl-camera-server.conf
