  2. FAQs
  3. Calibration yaml for M0061
Scheduled Pinned Locked Moved FAQs
3 Posts 3 Posters 3.2k Views 1 Watching
  • Wei Cui 0W Offline
    Wei Cui 0W Offline
    Wei Cui 0
    Does anyone have the calibration yaml for the following hi-res camera with M12 Lens SL-HD3125BMP? Thank you.
    Link Preview Image
    Assembled in USA | Autopilots that Accelerate Drone and Robot Autonomy
    ModalAI develops sUAS, drone and robotics autonomous computer vision, flight control and communications systems, and manufactures in the USA. ModalAI's VOXL platform advances Qualcomm Flight, combining ROS and PX4 for Obstacle Avoidance and GPS-Denied indoor navigation, in ready for development to upgrade your drone.
    favicon
    ModalAI, Inc. (www.modalai.com)
    D 1 Reply Last reply
    • Wei Cui 0W Wei Cui 0
      Link Preview Image
      favicon
      D Offline
      D Offline
      daz_22
      wrote on last edited by daz_22
      @Wei-Cui-0 @Alex-Kushleyev I would also like to see the intrinsics calibration yaml for the M0161 if available. Couldn't find it on the VOXL2. Thanks!
      • D daz_22
        Alex KushleyevA Online
        Hello @daz_22 ,
        The ideal intrinsics of the IMX412 camera module (M0161) are as follows:
        Full resolution:
        • focal length : 1999 (~2000) pixels
        • principal points: 2028, 1520 (for full frame image, such as 4056x3040 or 4040x3040)
        2x2 Binned resolution
        • focal length : 1000 pixels
        • principal points : 2028/2, 1520/2
        For other resolutions, you can adjust the principal points to be half of the width and height because the cropped image (in case of 3840x2160 or 1920x1080) will be centered.
        The lens model is fisheye and you should set the distortion coefficients to zeros unless you calibrate them.
        If you are going to calibrate the camera using voxl-calibrate-camera, it is very slow at full resolution, so i suggest calibrating at half resolution.
        Here is an old calibration result I found for one of these cameras, just for reference:
        %YAML:1.0
        M: !!opencv-matrix
           rows: 3
           cols: 3
           dt: d
           data: [ 999.5391440104593, 0.0, 1016.522606127024,
                   0.0, 998.2572561064064, 750.2875966666587,
                   0.0, 0.0, 1.0 ]
        D: !!opencv-matrix
           rows: 4
           cols: 1
           dt: d
           data: [ -0.02176119101007071, 0.01025514886831165,
                   -0.01688007838706262, 0.006525270203215156 ]
        reprojection_error: 0.72238
        width: 2020
        height: 1520
        distortion_model: fisheye
        calibration_time: "2024-11-15 16:38:58"
