  3. voxl-mapper does not show the trajectory
2 Posts 1 Posters 424 Views 1 Watching
  • chou zhiC Offline
    chou zhiC Offline
    chou zhi
    Hello Modalai. I'm currently testing voxl-mapper with tracking and TOF camera. The camera server and vixion-px4 are functioning properly.
    I was able to take off in position mode and switch to offboard mode successfully. However, when I click on a point in Portal UI, it fails to generate the trajectory and there's only the point:
    The terminal displays the following error message:
    Using start pose of: x:  -0.03, y:   0.02, z:   0.09
    Using goal pose of: x:  -0.74, y:   1.67, z:  -2.11
    Starting RRTConnect planner
    ERROR: End point is in collision
    I 'm certain that the end-point is in right position(the value of z is negative, which means that it's off the ground). But why there is no trajectory?
    • chou zhiC Offline
      chou zhiC Offline
      chou zhi
      wrote on last edited by chou zhi
      I came across a former-topic discussing a similar issue to mine.
      BTW, about a month ago, when I tried using voxl-mapper based on your YouTube video (hands-on test without flying), it was able to generate the path successfully.
      During that time, I accidentally turned over the TOF camera, resulting in a reversed image. I'm wondering if that could be the cause of the problem I'm currently facing?
