  3. Uvc and voxl-streamer
10 Posts 2 Posters 1.7k Views 1 Watching
  • Luis Fernando LandivarL Offline
    currently using a 5g modem add-on with the voxl 2. i am not able to connect to the stream using the ip of the voxl2's vpn or the ip it gives when i run voxl-streamer. here is what it shows when running voxl-streamer -i hires.
    and when on qgoundcontrol, it does not show up
    im in the process of trying to setup voxl-streamer for the hires, and then test voxl-streamer using a uvc camera as well. any help trying to solve this issue would be of much help, thank you in advance
    • tomT Offline
      @Luis-Fernando-Landivar Did you configure the video stream settings correctly in QGC settings? 49a8660a-2f8c-4d22-b43d-99709cc9c239-image.png
      Luis Fernando LandivarL 1 Reply Last reply
        wrote on last edited by Luis Fernando Landivar
        @tom yes here it is,
        ive tried this one above and below.
        as well as the ip of the vpn voxl2
        using the final ip and after some time, i get this error, then i get some frames, but it is distorted
        • tomT Offline
          @Luis-Fernando-Landivar That last one is the only one that will work. What happens if you choose "Default" for the Video decode" setting? I've never seen that option you're using before.
            @tom using the nvidia decoder uses the nvidia graphics card onboard the ground computer to decode the stream, it should help process incoming frames faster. ive set it to default now, and rebooted. sadly still no difference in distortion
            • tomT Offline
              @Luis-Fernando-Landivar What do you see with voxl-list-pipes ?
                heres the result
                • tomT Offline
                  @Luis-Fernando-Landivar If you pull up the stream with VLC do you have the same issue?
                  Or if you pull up voxl-portal without running the stream are things normal?
                    @tom i havent checked with vlc but i use the portal frequently, and there are no issues, the voxl 2 actually bricked after i last messaged you, i managed to restore it recently. Off topic, but related, i think i mightve had too much running, is stereo cameras used with vio at all?
                    Cause if not i think i should turn it off so that i can have only the hires, tracking and uvc camera on. I would like to be able to use position mode in the end so please let me know if disabling stereo will affect this.
                    I will try the uvc again later today,
                    Thanks in advance
                    • tomT Offline
                      @Luis-Fernando-Landivar Stereo is not used by VIO, however, tracking is.
