  3. Voxl doesnt show up in either adb devices or fastboot devices
2 Posts 2 Posters 784 Views 2 Watching
  • A Offline
    Arrowtec
    I have a problem where my voxl flight showed up in adb devices, I ran the install.sh script and it failed and afterwards it didnt show up on my computer. Is there anything I can do without the debug board to fix this? Below is the code of the installation.
    ben@ben-desktop:~/Downloads/modalai-3-1-0$ ./install.sh
    [INFO] adb installed
    [INFO] fastboot installed
    This process will completely wipe your VOXL
    Would you like to preserve the /data/ partition which contains
    things like calibration, wifi config, and docker images
    To preserve files in /data/ answer Y
    To wipe /data/ for a full factory flash answer N
    Enter Y or N:
    y
    [INFO] Rebooting into fastboot...
    error: no devices/emulators found
    target reported max download size of 536870912 bytes
    sending 'aboot' (494 KB)...
    OKAY [  0.037s]
    writing 'aboot'...
    OKAY [  0.031s]
    finished. total time: 0.069s
    sending 'boot' (56066 KB)...
    OKAY [  0.469s]
    writing 'boot'...
    OKAY [  0.591s]
    finished. total time: 1.060s
    erasing 'system'...
    OKAY [  0.014s]
    sending sparse 'system' 1/3 (523027 KB)...
    FAILED (data write failure (Cannot send after transport endpoint shutdown))
    finished. total time: 1.236s
      Hi @Arrowtec ,
      I've seen this myself before. In my case the device would then show up after running sudo fastboot devices and I could proceed after trying again.
      If it's not showing up with either sudo fastboot devices or adb devices it would likely need the Debug board which allows you to force it to boot into fastboot....
