  3. voxl2 not coming out of fastboot
2 Posts 1 Posters 699 Views
    I am using VOXL2 with system image 1.4.1 and voxl-suite 0.9. Since past day I was unable to boot up voxl2 with adb shell on my custom drone. This started to happen all of sudden whereas I was able to operate VOXL2 correctly on my custom drone. I tried all the following steps :
    • Flashing system image 1.4.1 again. Didn't work. VOXL2 never comes out of fastboot mode into adb shell.
    • I tried putting VOXL2 into fastboot mode manually via Switch 1, where it went into fastboot mode and initiated flashing but again got stuck at "Waiting for ADB"
    • I tried installing QDL whereas it got flashed correctly as per the tutorial but after I turned off EDL switch, voxl2 was unable to go into ADB shell and is always running in fastboot mode.
    So current scenerio is VOXL2 is stuck in fastboot mode even after performing QDL and system image flashing. I tried following command to check if I am able to boot out from fastboot.
    sudo fastboot continue
    resuming boot...
    FAILED (remote: Failed to load image from partition: Load Error)
    finished. total time: 0.000s
    This command shows failed to load image from partition. I have tried everything mentioned on unbricking voxl2 related queries on forum and also followed all the documentation. Please help me in resolving this. I would highly appreciate if I can get some urgent help over here @Chad-Sweet
      @Chad-Sweet We would be doing RMA for this VOXL2 chip since it is not in recoverable stage from our tests.
      • wilkinsafW wilkinsaf referenced this topic on
