  3. Using M.2 5G Modem Addon Board (M0090) on voxl2 , can not found the /dev/ttyHS2 device
3 Posts 2 Posters 558 Views 1 Watching
  • Cheng Sheng WengC Offline
    Cheng Sheng Weng
    I am following https://docs.modalai.com/voxl2-external-flight-controller/
    to connect external flight-controller.
    The VOXL2 (M0054) can have the M.2 5G Modem Board Addon attached, which exposes a UART on M0090 - J9 that is accessible in VOXL2’s application processor as /dev/ttyHS2.
    I can not found /dev/ttyHS2 device. How can I enable this device ?
    Please assist.
      Hi @Cheng-Sheng-Weng ,
      Can you run voxl-version and paste info here? That device should be available as of system image 1.3+
      If you are on a 1.2.x image, please upgrade to the VOXL2 Platform 0.9
      from https://developer.modalai.com/ and install following https://docs.modalai.com/platform-releases/#install
      Cheng Sheng WengC 1 Reply Last reply
      • modaltbM modaltb
        Cheng Sheng Weng
        @modaltb Thanks a lot . I have updated to system image 1.3+. The device can be find on /dev
        Best Wishes
