  3. Safety Setup parameters missing from firmware
7 Posts 2 Posters 918 Views
  • Dylan LauD Offline
    Dylan LauD Offline
    Dylan Lau
    wrote on last edited by Dylan Lau
    I just setup the Sentinel and managed to connect to QGroundControl.
    However there seems to be an error when I try to configure the Safety Setup. Is there something wrong with my firmware?
    eeabc846-c6d7-4195-be62-a2d2b1d1c049-Screenshot from 2022-12-05 14-54-09.png /home/amokduke/Pictures/Screenshots/Screenshot from 2022-12-05 14-54-09.png
    These other the other settings...
    f8632f08-8ac1-4358-a160-a56f25511412-Screenshot from 2022-12-19 11-46-05.png file:///home/amokduke/Pictures/Screenshots/Screenshot%20from%202022-12-19%2011-46-05.png
    Cheers~
    Dylan
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      @Dylan-Lau, sorry to hear you're having troubles with your Sentinel. Let's see if we can solve this.
      First off, it seems you may be running an older software release. Current version is 2e58365f-5870-4724-99f4-d5265ac3c3b5-image.png
      Secondly, what version of QGC have you downloaded?
      The reason I ask is that we have seen that if either QGC or Voxl release software is mismatched, it can cause the warning that you're currently seeing.
      I would recommend installing the latest QGC if you haven't already done so. Next would be to upgrade to the latest Voxl release.
      Hope that helps
      Dylan LauD 1 Reply Last reply
        Dylan LauD Offline
        Dylan Lau
        Thanks Adrian for the quick response!
        I am using QGC v 4.2.4. Will upgrade to the latest Voxl release then and see how it goes. 😃
        Cheers~
        Dylan
          Hope that helps
          Dylan LauD Offline
          Dylan LauD Offline
          Dylan Lau
          Hi @Adrian-Hidalgo, the same error message persist after the upgrade to the latest Voxl release.
          Any ideas? It says missing params: 1:5DLOG_MODE
          Is there a parameter file for the sentinel that we need to upload/configure beforehand?
          Cheers~
          Dylan
            Adrian Hidalgo
            @Dylan-Lau, hmm which safety are you attempting to load?
            Could you provide us a px4 parameter file you have? In QGC, in the parameters, to to tools --> upper right hand corner, select it and the drop down select save to file. If you could send that, we can look through it.
              Dylan LauD Offline
              Dylan LauD Offline
              Dylan Lau
              @Adrian-Hidalgo Here is the px4 parameter file: link text
              • Dylan LauD Dylan Lau
                Dylan LauD Offline
                Dylan LauD Offline
                Dylan Lau
                @Dylan-Lau said in Safety Setup parameters missing from firmware:
                Hi @Adrian-Hidalgo, may I know if there is an update? We thought of some workarounds but since it deals with safety, it is better to implement something with the support team's expertise.
                We found https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/master/temp1.params and https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/platforms/v1.13/M500 and so should we use this instead of the default one we have from the system image?
                Cheers
                Dylan
