VOXL2 cannot connect to internet in station mode
Firmware: voxl2_platform_0.9
I currently have an issue where if I have a microhard attached to the voxl2, and a wifi dongle attached through the microhard board, I cannot connect to the internet in station mode.
In the past when I've had this problem, I could disable the interfering network interfaces with "ifconfig eth0 down" or "ifconfig usb0 down." However, if I run "ifconfig eth0 down" on the current voxl2, the internet connection only lasts a few seconds before being interfered again by eth0. While I haven't tested this thoroughly on other voxl2 firmware versions, I currently have only run into this bug on voxl2_platform_0.9, which as of now is the latest firmware version.
This problem has been observed on one voxl2 development kit, and on one Sentinel drone
^the jst cable connected to the microhard is the wifi dongle. The problem has been observed in both ports on the microhard add-on board
An additional note I forgot to mention: I also need to run "ifconfig usb0 down" but I only need to do that once, whereas I need to run "ifconfig eth0 down" every 5-10 seconds to regain internet connection over station mode
this is a standard linux networking system. Have you googled how to manage the network interfaces?
Maybe make sure your routing tables are properly configured for what you are trying to do? https://opensource.com/business/16/8/introduction-linux-network-routing
