  3. Vision failure everytime during takeoff
28 Posts 5 Posters 8.6k Views 1 Watching
  • modaltbM modaltb
    @Tamas-Pal-0 ...
    I still have nothing to report as far as finding root cause of something, after our tune tweaks I was up and going. I am still testing though for this use case to see if there's some edge case I'm not seeing, I'm just a bit slow with this debugging.
    As far as sharing my params that got me flying, I don't even know if my approach here is valid, you have different motor/prop setup, and frames aren't identical, battery type?...
    My lawyer told me to tell you "not to use these since we don't have the same setup and the author/developer in the post here isn't really a pilot so...." You've been warned by the lawyer! 😉
    # Pitch PID
    1	1	MC_PITCH_P	5.5	9
    1	1	MC_PITCHRATE_P	0.065	9
    1	1	MC_PITCHRATE_I	0.150	9
    1	1	MC_PITCHRATE_D	0.002	9
    1	1	MC_PITCHRATE_K	1.0	9
    # Roll PID
    1	1	MC_ROLL_P	5.5	9
    1	1	MC_ROLLRATE_P	0.065	9
    1	1	MC_ROLLRATE_I	0.150	9
    1	1	MC_ROLLRATE_D	0.002	9
    1	1	MC_ROLLRATE_K	1.0	9
    # Yaw PID
    1	1	MC_YAW_P	2.0	9
    1	1	MC_YAWRATE_P	0.15	9
    1	1	MC_YAWRATE_I	0.10	9
    1	1	MC_YAWRATE_D	0.0	9
    1	1	MC_YAWRATE_K	1.0	9
    # Noise management
    1	1	MOT_SLEW_MAX	0.0	9
    1	1	IMU_DGYRO_CUTOFF	30.0	9
    1	1	IMU_ACCEL_CUTOFF	30.0	9
    1	1	IMU_GYRO_CUTOFF	30.0	9
    Checkout out noise management here... I've had some nasty flights due to cutoff frequencies.
    Tamas Pal 0T Offline
    Tamas Pal 0
    @modaltb I have tried with your parameters. It is still the same. I am able to hover it but it is going here and there uncontrollably and a bit of wobbling is still there.
      Any chance you could post a link to a video of a flight to help us understand the failure mode even more? Sorry to this going, but we're struggling to find a smoking gun.
      • modaltbM modaltb
        Tamas Pal 0
        @modaltb I am using your parameters here and disbaled the modalai_esc driver. The video link is here
        https://drive.google.com/file/d/1cbBXsEFMLztR7F1_en4i77F1ww4LbQ1t/view?usp=sharing
          OK thanks for the data. This is where I'm at now with my VOXL2 / VOXL2 IO setup sentinel, it's not super clean yet but but flyable for sure:
          https://www.youtube.com/watch?v=1INto92k-v0
          I'm getting our team to do a real tune and early this week and will post info.
          • modaltbM modaltb
            Tamas Pal 0
            wrote on last edited by Tamas Pal 0
            #25
            @modaltb Thanks. which escs are you using for this?
              Hi @Tamas-Pal-0 ,
              These are BLHeli 20A, should be similar/same as the ones from this kit: https://shop.holybro.com/spare-parts-s500-kit_p1251.html
              Here's my setup:
              • modaltbM modaltb
                Hi @Tamas-Pal-0 ,
                Here's my setup:
                Tamas Pal 0
                @modaltb so, the problem is solved for you by tuning only ?
                  On my setup yes that was all I needed to do, but we are still going to do a "full proper tune" on our S500 based frame (Sentinel dev drone) and I will confirm with you that we are getting performance as expected after this and share a video. Our flight test team will be doing that this week, thanks for the patience!!!
