  3. Booting loop problem
2 Posts 2 Posters 361 Views 1 Watching
  • Tamas Pal 0T Offline
    Tamas Pal 0
    wrote on last edited by Tamas Pal 0
    I am currently using voxl 2 staging pkg vesion and to fly it with voxl2 io board I have also installed voxl-px4-1.4.27. But sometimes, the voxl2 is having problem with boot. It is rebooting again and again (one of the green leds and yellow led are blinking againg and again after 5-10 seconds but no response with adb devices in the terminal). I have reflashed the voxl2 but that did not solve the issue with staging package version and voxl-px4-1.4.27 instlled. How to fix it ?
    • tomT Offline
      @Tamas-Pal-0 We have observed this issue a few times and the solution is always to either swap out the MCBL-0001: https://docs.modalai.com/cable-datasheets/#mcbl-00001 (power module to VOXL2 cable) or insepct the cable closely and push the wires back into the connector if they have come loose. It seems as though after time if these cables are unplugged and re-plugged often that there is enough degradation that the VOXL2 isn't able to pull the current necessary on boot and thus enters the boot cycle. We are actively looking into this issue to determine the root cause. If you aren't able to fix the issue based off this info we can get you a new MCBL-0001.
