  3. VIO Indoor Navigation
18 Posts 4 Posters 4.5k Views 4 Watching
  • Maha RiyadM Offline
    Maha RiyadM Offline
    Maha Riyad
    Hello @modaltb ,
    We are trying to run MAVROS on voxl m500, but we're facing issues with the VIO. The VIO is enabled in the voxl-vision-px4 configuration file. However, when checking the x and y values in the odometry mavlink telemetry packets they're found to be 0s.
    The position mode is continuously rejected and it seems like the VIO data is not being transmitted. We did not change the flight core's PX4-EKF2 settings yet we tried to use the helper file here: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/ekf2_indoor_vio.params
    and we still did not manage to get it to work. Could you please help?
      Hi @Maha-Riyad ,
      One way to debug is using voxl-vision-px4 via command line, with the 0.6.8 production release, there's a -o option that prints out odometry data straight out of voxl-vision-px4 which is useful.
      https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/7b9f76c468045a023b35747deeef52e4f524b7de/src/main.c#L99
      If you run voxl-vision-px4 -o from command line, how are things looking there?
        I forgot, James has a great video here too: https://www.youtube.com/watch?v=0j7CjmDvluM&feature=emb_logo
        Lynn KoudsiL 1 Reply Last reply
        • modaltbM modaltb
          Lynn KoudsiL Offline
          Lynn Koudsi
          wrote on last edited by Lynn Koudsi
          Hi @modaltb,
          I'm getting the exact same problem with the same parameter settings. I tried running voxl-vision-px4 -o and I was seeing no messages when attempting to switch to position control. I'm also not seeing any Odometry section in MAVLink Inspector.
          I'm seeing no errors when running voxl-vision-px4 as a service or in command line.
            Hi @Lynn-Koudsi ,
            Hmmm, this one is confusing me a bit, if you're available maybe we could setup a screen share on Monday to troubleshoot? I'm be available 8:15-10:00, 12-2 and 4-5 PST, or Tuesday anytime after 8:15 AM PST.
            Thanks!!
            • modaltbM modaltb
              Hi @Lynn-Koudsi ,
              Thanks!!
              Lynn Koudsi
              @modaltb 12-2 works!
              Also just for more context, I had done a clean image installation at V3.1.0 and had removed my data folder. I'm thinking the issue is that calibration files are not there. I tried running voxl-cam-ros but it's not finding left and right yaml files. I tried just pushing the sample calibration files from https://gitlab.com/voxl-public/utilities/voxl-camera-calibration but it won't find ost.yaml.
              So I guess my question is, is there a default data folder available online? Or can you provide the default factory data folder?
                Just sent out an invite for tomorrow, if I can get the SN of the m500 I can get you the calibration files we have in our production database in advance and that might get things going!
                • modaltbM modaltb
                  Lynn Koudsi
                  @modaltb Thank you!
                  Serial# is M20000000TJ
                  • LipingL Offline
                    LipingL Offline
                    Liping
                    Hi @modaltb
                    I'm getting the same problem as described by Lynn. I had also done a clean image installation at V3.1.0 and had removed my data folder.
                    yocto:~# voxl-vision-px4 -o
                    loading our own config file
                    qgc_ip:                     192.168.43.84
                    en_localhost_mavlink_udp    1
                    en_secondary_qgc:           0
                    secondary_qgc_ip:           192.168.1.214
                    qgc_udp_port_number:        14550
                    localhost_udp_port_number:  14551
                    en_vio:                     1
                    en_voa:                     0
                    en_send_vio_to_qgc:         0
                    en_send_voa_to_qgc:         0
                    en_adsb:                    1
                    adsb_uart_bus:              7
                    adsb_uart_baudrate:         57600
                    px4_uart_bus:               5
                    px4_uart_baudrate:          921600
                    offboard_mode:              off
                    follow_tag_id:              0
                    en_apriltag_fixed_frame:    0
                    fixed_frame_filter_len:     5
                    loading extrinsics and apriltag external config files
                    #0:
                        tag id:          0
                        size_m:            0.400
                        T_tag_wrt_fixed: 0.0  0.0  0.0
                        R_tag_to_fixed:  0.0 -1.0  0.0
                                         1.0  0.0  0.0
                                         0.0  0.0  1.0
                    #1:
                        tag id:          1
                        size_m:            0.400
                                         1.0  0.0  0.0
                                         0.0  0.0  1.0
                    loaded in 2 fixed apriltags
                    #0:
                        parent:                imu1
                        child:                 imu0
                        T_child_wrt_parent:   -0.048   0.037   0.002
                        RPY_parent_to_child:   0.0     0.0     0.0
                        R_child_to_parent:     1.000  -0.000   0.000
                                               0.000   1.000  -0.000
                                               0.000   0.000   1.000
                    #1:
                        parent:                imu0
                        child:                 tracking
                        T_child_wrt_parent:    0.065  -0.014   0.013
                        RPY_parent_to_child:   0.0    45.0    90.0
                        R_child_to_parent:     0.000  -0.707   0.707
                                               1.000   0.000  -0.000
                                              -0.000   0.707   0.707
                    #2:
                        parent:                imu1
                        child:                 tracking
                        T_child_wrt_parent:    0.017   0.015   0.013
                                               1.000   0.000  -0.000
                                              -0.000   0.707   0.707
                    #3:
                        parent:                body
                        child:                 imu0
                        T_child_wrt_parent:    0.020   0.014  -0.008
                                               0.000   1.000  -0.000
                                               0.000   0.000   1.000
                    #4:
                        parent:                body
                        child:                 imu1
                        T_child_wrt_parent:    0.068  -0.015  -0.008
                                               0.000   1.000  -0.000
                                               0.000   0.000   1.000
                    #5:
                        parent:                body
                        child:                 stereo_l
                        T_child_wrt_parent:    0.100  -0.040   0.000
                        RPY_parent_to_child:   0.0    90.0    90.0
                        R_child_to_parent:     0.000  -0.000   1.000
                                               1.000   0.000  -0.000
                                              -0.000   1.000   0.000
                    #6:
                        parent:                body
                        child:                 tof
                        T_child_wrt_parent:    0.100   0.000   0.000
                                               1.000   0.000  -0.000
                                              -0.000   1.000   0.000
                    #7:
                        parent:                body
                        child:                 ground
                        T_child_wrt_parent:    0.000   0.000   0.100
                                               0.000   1.000  -0.000
                                               0.000   0.000   1.000
                    exising instance of voxl-vision-px4 found, attempting to stop it
                    starting geometry module
                    starting uart mavlink
                    Successfully opened mavparser
                    starting udp mavlink
                    Detected PX4 Mavlink SYSID 1
                    Adding manual QGC IP address to udp connection list: 192.168.43.84
                    Added new UDP connection to 192.168.43.84
                    starting px4 shell
                    starting fixed pose input
                    starting vio manager
                    starting apriltag manager
                    starting adsb manager
                    ADSB thread starting
                    PX4 Connected over UART with sysid 1
                    But when I run 'voxl-test-vision-lib -o' I can see the VIO works.
                    [6619.210687] SNAV INFO: IMU sensor finished initializing.
                    [6619.211066] SNAV INFO: IMU sensor settings retrieved.
                    [6619.211122] SNAV INFO: Creating IMU thread.
                    [6619.211332] SNAV INFO: Creating VISLAM processing thread.
                    [6619.211463] SNAV INFO: ImuManager thread has tid = 3558, nice = -15
                    [6619.211483] SNAV INFO: Creating VISLAM publishing thread.
                    [6619.211768] SNAV INFO: VISLAM publishing thread has tid = 3560, nice = -5
                    VIO camera frame: points:  0 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
                    [6619.211958] SNAV INFO: VISLAM processing thread has tid = 3559, nice = -5
                    VIO camera frame: points: 39 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
                    VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z: -0.000 R: -0.000 P: -0.000 Y: -0.000
                    VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z:  0.000 R: -0.000 P:  0.000 Y: -0.000
                    VIO camera frame: points: 39 X: -0.000 Y:  0.001 Z:  0.000 R: -0.001 P: -0.000 Y: -0.000
                    VIO camera frame: points: 39 X: -0.001 Y: -0.002 Z: -0.005 R:  0.001 P: -0.001 Y: -0.000
                    VIO camera frame: points: 39 X:  0.000 Y: -0.000 Z: -0.008 R:  0.000 P: -0.001 Y: -0.001
                    VIO camera frame: points: 39 X: -0.000 Y: -0.001 Z: -0.010 R:  0.001 P: -0.002 Y: -0.001
                    VIO camera frame: points: 39 X: -0.000 Y: -0.000 Z: -0.014 R:  0.002 P: -0.003 Y: -0.001
                    VIO camera frame: points: 39 X:  0.002 Y:  0.002 Z: -0.019 R:  0.001 P: -0.003 Y: -0.002
                    VIO camera frame: points: 39 X:  0.003 Y:  0.002 Z: -0.022 R:  0.001 P: -0.004 Y: -0.002
                    VIO camera frame: points: 39 X:  0.004 Y:  0.002 Z: -0.023 R:  0.001 P: -0.004 Y: -0.001
                    VIO camera frame: points: 39 X:  0.004 Y:  0.001 Z: -0.020 R:  0.001 P: -0.004 Y: -0.001
                    VIO camera frame: points: 39 X:  0.002 Y:  0.001 Z: -0.015 R:  0.001 P: -0.004 Y: -0.001
                    In QGroundControl, I can not see the ODOMETRY section in the MAVLink inspector.
                    My serial # M20000005GT
                    • LipingL Liping
                      Hi @modaltb
                      en_secondary_qgc:           0
                      en_vio:                     1
                      en_voa:                     0
                      en_adsb:                    1
                      adsb_uart_bus:              7
                      px4_uart_bus:               5
                      offboard_mode:              off
                      follow_tag_id:              0
                      #0:
                          tag id:          0
                          size_m:            0.400
                                           1.0  0.0  0.0
                                           0.0  0.0  1.0
                      #1:
                          tag id:          1
                          size_m:            0.400
                                           1.0  0.0  0.0
                                           0.0  0.0  1.0
                      #0:
                          parent:                imu1
                          child:                 imu0
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #1:
                          parent:                imu0
                          child:                 tracking
                                                 1.000   0.000  -0.000
                                                -0.000   0.707   0.707
                      #2:
                          parent:                imu1
                          child:                 tracking
                                                 1.000   0.000  -0.000
                                                -0.000   0.707   0.707
                      #3:
                          parent:                body
                          child:                 imu0
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #4:
                          parent:                body
                          child:                 imu1
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #5:
                          parent:                body
                          child:                 stereo_l
                                                 1.000   0.000  -0.000
                                                -0.000   1.000   0.000
                      #6:
                          parent:                body
                          child:                 tof
                                                 1.000   0.000  -0.000
                                                -0.000   1.000   0.000
                      #7:
                          parent:                body
                          child:                 ground
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      starting px4 shell
                      Lynn Koudsi
                      #10
                      @Liping My issue was resolved by installing voxl-qvio. You can reference the diagram here to learn what services are needed for the different interactions.
                      LipingL 1 Reply Last reply
                      • Lynn KoudsiL Lynn Koudsi
                        LipingL Offline
                        LipingL Offline
                        Liping
                        @Lynn-Koudsi Thanks Lynn. But in my case, the issue still exists after installing the voxl-qvio.
                        What are your installed voxl package versions?
                        I installed some latest stable version packages.
                        yocto:~#  opkg list-installed | grep "voxl"
                        libvoxl_io - 0.5.4
                        voxl-cam-manager - 0.2.2
                        voxl-docker-support - 1.1.1
                        voxl-hal3-tof-cam-ros - 0.0.2
                        voxl-modem - 0.10.0
                        voxl-mpa-tools - 0.1.6
                        voxl-nodes - 0.0.8
                        voxl-qvio-server - 0.2.1
                        voxl-rtsp - 1.0.2
                        voxl-time-sync - 0.0.1
                        voxl-utils - 0.5.2
                        voxl-vision-px4 - 0.8.1
                        voxl-vpn - 0.0.2
                        voxl_imu - 0.0.4
                        • LipingL Liping
                          libvoxl_io - 0.5.4
                          voxl-modem - 0.10.0
                          voxl-nodes - 0.0.8
                          voxl-rtsp - 1.0.2
                          voxl-utils - 0.5.2
                          voxl-vpn - 0.0.2
                          voxl_imu - 0.0.4
                          Lynn Koudsi
                          @Liping Is voxl-qvio actually running? You can check by calling systemctl status voxl-qvio-server it might be that you need calibration files for the tracking camera
                            LipingL Offline
                            LipingL Offline
                            Liping
                            @Lynn-Koudsi It shows waiting for imu and camera. Could you help to point out where is the calibration file located? Is it this calibration process (https://docs.modalai.com/calibrate-cameras/) that you refer to?
                            yocto:~# systemctl status voxl-qvio-server
                            ● voxl-qvio-server.service - voxl-qvio-server
                               Loaded: loaded (/usr/bin/voxl-qvio-server; disabled; vendor preset: enabled)
                               Active: active (running) since Mon 2021-03-08 15:13:41 UTC; 7min ago
                             Main PID: 3199 (voxl-qvio-serve)
                               CGroup: /system.slice/voxl-qvio-server.service
                                       └─3199 /usr/bin/voxl-qvio-server
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_8096 supported? 1
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_IA64 supported? 1
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: WINDOWS supported? 0
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: AR ERROR: arFileOpen(): Failed to open file: //vislam/Configuration.SF.xml
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: FASTCV: fcvAvailableHardware Linux
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: mempool cur block size 307200, new block size 307200
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: Please ignore the error about Configuration.SF.xml above. ^^^
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: It's an optional file, and should be a warning not an error
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for imu
                            Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for cam
                            Before, I was using the following two command to set the configuration file:
                            voxl-configure-vision-px4
                            voxl-configure-modalai-vl
                            • LipingL Liping
                              Lynn Koudsi
                              #14
                              @Liping that's a curious problem... try checking the status of the imu and camera servers:
                              systemctl status voxl-camera-server
                              systemctl status voxl-imu-server
                              If you check the status of voxl-qvio again, does it say it failed? or it waits forever?
                              You should have the following calibration files:
                              etc/snav/calibration.stereo.xml
                              home/root/.ros/camera_info/left.yaml
                              home/root/.ros/camera_info/right.yaml
                              etc/snav/calibration.downward.xml
                              home/root/.ros/camera_info/downward.yaml
                              But I'm pretty sure you're going to need
                              /data/modalai/opencv_stereo_intrinsics.yml
                              /data/modalai/opencv_stereo_extrinsics.yml
                              I got those by running the calibration process you referenced.
                                Lynn Koudsi
                                @Liping I just realized that you don't have voxl-camera-server installed. You will need that. I also found that having both voxl-camera-server and voxl-cam-manager has given me some issues so I would recommend uninstalling voxl-cam-manager
                                Lynn KoudsiL LipingL 2 Replies Last reply
                                  Lynn Koudsi
                                  @Liping I'm also curious as to where you got voxl_imu from... I don't think I've ever seen that. The correct package is voxl-imu-server and you can find it here. You would have to uninstall voxl_imu
                                    LipingL Offline
                                    LipingL Offline
                                    Liping
                                    @Lynn-Koudsi Thanks a lot! The issue has been solved. The QGroundControl shows meaningful ODOMETRY data now. As you mentioned, the issue comes from the voxl-camera-server and voxl-imu-server. voxl-qvio can not get data from both the camera and the imu.
                                    Besides, I noticed that the configuration of the camera and imu does not work as expected. It may be caused by the conflict of the old (imp_app, voxl-cam-manager)and new (voxl-camera-server, voxl-imu-server) camera and imu ipk.
                                    To make it simple, I flashed the image with the System Image 3.2.0 (https://developer.modalai.com/asset/eula-download/64) without installing the voxl-suite, since I want to use the new Modal Pipe Architecture (https://gitlab.com/voxl-public/modal-pipe-architecture).
                                    I manually installed the following voxl packages:
                                    yocto:/#  opkg list-installed | grep "libmodal"
                                    libmodal_json - 0.3.4
                                    libmodal_pipe - 1.7.6
                                    yocto:/#  opkg list-installed | grep "voxl"
                                    libvoxl_io - 0.5.4
                                    voxl-camera-server - 0.5.5
                                    voxl-dfs-server - 0.0.7
                                    voxl-imu-server - 0.7.8
                                    voxl-utils - 0.5.9
                                    Then I run the configuration commands for the qvio, voxl-vision-px4 and camera (voxl-imu-server has done some default configuration during the ipk installation):
                                    yocto:/# voxl-configure-qvio -f
                                    rm: cannot remove '/etc/modalai/voxl-qvio-server.conf': No such file or directory
                                    loading qvio config file
                                    Creating new config file: /etc/modalai/voxl-qvio-server.conf
                                    The config file was modified during parsing, saving the changes to disk
                                    enabling voxl-qvio-server systemd service
                                    Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-qvio-server.service to /etc/systemd/system/voxl-qvio-server.service.
                                    starting voxl-qvio-server systemd service
                                    Done configuring voxl-qvio-server
                                    yocto:/# voxl-configure-vision-px4 -f
                                    rm: cannot remove '/etc/modalai/voxl-vision-px4.conf': No such file or directory
                                    Created new empty json file: /etc/modalai/voxl-vision-px4.conf
                                    The JSON config file data was modified during parsing, saving the changes to disk
                                    enabling voxl-vision-px4 systemd service
                                    Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-vision-px4.service to /etc/systemd/system/voxl-vision-px4.service.
                                    starting voxl-vision-px4 systemd service
                                    DONE configuring voxl-vision-px4
                                    yocto:/# voxl-configure-cameras
                                    Regarding the configuration of the camera, i was following the guidance in https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-camera-server to use the command voxl-configure-cameras provided by voxl-utils package.
                                    I rebooted the VOXL and checked related services (camera, imu, qvio, voxl-vision-px4) using
                                    systemctl status
                                    But I noticed that the voxl-camera-server was not automaticly started on boot.
                                    So I enabled it with:
                                    yocto:/# systemctl enable voxl-camera-server
                                    @modaltb Please correct me if any step was not right or there is a better way.
                                    In addition, I also followed the https://forum.modalai.com/topic/70/warning-px4-disconnected-error-message-from-voxl-vision-px4 to solve the WARNING PX4 DISCONNECTED error message from voxl-vision-px4
                                      WOW! Thanks @Lynn-Koudsi for the help, when we setup the forum this is the kind of interaction we were hoping for, just awesome!!
                                      Sorry for the setup and 'wonkyness' right now, we've been somewhat caught with getting pre-release software out there without all the setup/docs lined up.... so we're doing a little catchup it seems.
                                      @Liping there until we have our docs updated, if this is working, I'd say this is a good approach!
                                      Thank you both for the details, we'll relay this through the team.
