  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Unable to takeoff in hitl simulation in VIO mode
5 Posts 3 Posters 983 Views
  • Tamas Pal 0T Offline
    Tamas Pal 0
    I am trying to run hitl simulation in VIO mode with voxl 2. When I was trying to take off in vio mode it is getting rejected everytime although I can arm it. This is the terminal output for voxl 2
    voxl2:/$ voxl-px4-hitl -v
    Found DSP signature file
    Setting VIO Parameters for HITL
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl-vio-parameters.config 0
      CBRK_SUPPLY_CHK: curr: 0 -> new: 894281
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CBRK_SUPPLY_CHK
      COM_DISARM_PRFLT: curr: 10.0000 -> new: -1.0000
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_PRFLT
      COM_RC_IN_MODE: curr: 0 -> new: 1
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_RC_IN_MODE
      NAV_RCL_ACT: curr: 2 -> new: 0
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for NAV_RCL_ACT
      EKF2_AID_MASK: curr: 1 -> new: 280
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_AID_MASK
      SYS_HAS_MAG: curr: 1 -> new: 0
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_HAS_MAG
      EKF2_MAG_TYPE: curr: 0 -> new: 5
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_MAG_TYPE
      EKF2_HGT_MODE: curr: 0 -> new: 3
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_HGT_MODE
    Exiting NOW.
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl.config 0
    INFO  [muorb] SLPI: Creating qurt thread hpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
    INFO  [muorb] SLPI: Creating qurt thread lpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
    INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
    INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
    INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
    INFO  [muorb] SLPI: Creating qurt thread wq_manager
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
    INFO  [muorb] SLPI: Creating qurt thread qshell
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
    INFO  [logger] logger started (mode=all)
    INFO  [logger] Start file log (type: full)
    INFO  [logger] [logger] /data/px4/log/sess004/log001.ulg
    INFO  [logger] Opened full log file: /data/px4/log/sess004/log001.ulg
    ERROR [logger] No subscriptions added
    INFO  [muorb] SLPI: Advertising remote topic mavlink_log
    INFO  [muorb] SLPI: Advertising remote topic logger_status
    INFO  [qshell] Send cmd: 'icm42688p start -s -h'
    INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -h
    INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77
    INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    INFO  [muorb] SLPI: on SPI bus 1
    INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -h
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 643137190, current timestamp 643137191
    INFO  [uorb] Advertising remote topic qshell_retval
    INFO  [qshell] qshell return value timestamp: 643137190, local time: 643145778
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    ERROR [muorb] SLPI: Cannot reset all parameters on client side
    INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic parameter_update
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
    INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
    INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
    INFO  [qshell] Send cmd: 'sensors start -h'
    INFO  [muorb] SLPI: qshell gotten: sensors start -h
    INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 76
    INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 75
    INFO  [muorb] SLPI: Ok executing command: sensors start -h
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 645460873, current timestamp 645460875
    INFO  [uorb] Advertising remote topic sensors_status_imu
    INFO  [qshell] qshell return value timestamp: 645460873, local time: 645462858
    INFO  [commander] LED: open /dev/led0 failed (22)
    INFO  [muorb] SLPI: Advertising remote topic led_control
    INFO  [muorb] SLPI: Advertising remote topic tune_control
    INFO  [PreFlightCheck] Failed barometer preflight check
    INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
    INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status
    INFO  [muorb] SLPI: Advertising remote topic actuator_armed
    INFO  [muorb] SLPI: Advertising remote topic commander_state
    INFO  [PreFlightCheck] Preflight fail EKF couldn't get status
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command
    INFO  [commander] Handling Commander command 176
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 646677913, current timestamp 646677915
    INFO  [qshell] qshell return value timestamp: 646677913, local time: 646679184
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 646755405, current timestamp 646755407
    INFO  [qshell] qshell return value timestamp: 646755405, local time: 646757219
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 646851157, current timestamp 646851159
    INFO  [qshell] qshell return value timestamp: 646851157, local time: 646859901
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 646914221, current timestamp 646914223
    INFO  [qshell] qshell return value timestamp: 646914221, local time: 646914687
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 647035223, current timestamp 647035225
    INFO  [qshell] qshell return value timestamp: 647035223, local time: 647038832
    INFO  [uorb] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
    INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
    INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 74
    INFO  [uorb] Advertising remote topic test_motor
    INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 648087744, current timestamp 648087745
    INFO  [qshell] qshell return value timestamp: 648087744, local time: 648089970
    INFO  [qshell] Send cmd: 'mixer load /dev/pwm_output0 quad_x.main.mix'
    INFO  [muorb] SLPI: qshell gotten: mixer load /dev/pwm_output0 quad_x.main.mix
    INFO  [muorb] SLPI: Ok executing command: mixer load /dev/pwm_output0 quad_x.main.mix
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 648151227, current timestamp 648151229
    INFO  [qshell] qshell return value timestamp: 648151227, local time: 648156266
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [muorb] SLPI: qshell gotten: ekf2 start
    INFO  [muorb] SLPI: Creating qurt thread wq_INS0
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 4170
    INFO  [muorb] SLPI: Ok executing command: ekf2 start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 649427101, current timestamp 649427103
    INFO  [qshell] qshell return value timestamp: 649427101, local time: 649429257
    INFO  [qshell] Send cmd: 'modalai_dsp start -v -p 2 -b 921600'
    INFO  [muorb] SLPI: qshell gotten: modalai_dsp start -v -p 2 -b 921600
    INFO  [muorb] SLPI: Creating qurt thread modalai_dsp__main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_modalai_dsp__main with tid 73
    INFO  [muorb] SLPI: Ok executing command: modalai_dsp start -v -p 2 -b 921600
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 650497255, current timestamp 650497258
    ERROR [muorb] SLPI: Port is open: 0
    INFO  [qshell] qshell return value timestamp: 650497255, local time: 650498945
    INFO  [uorb] Advertising remote topic sensor_accel
    INFO  [uorb] Advertising remote topic sensor_gyro
    INFO  [muorb] SLPI: Got 5 from orb_subscribe
    INFO  [muorb] SLPI: Got 6 from orb_subscribe
    INFO  [muorb] SLPI: Got 7 from orb_subscribe
    INFO  [muorb] SLPI: Got 8 from orb_subscribe
    INFO  [muorb] SLPI: Heartbeat msg received
    INFO  [uorb] Advertising remote topic battery_status
    INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
    INFO  [uorb] Advertising remote topic vehicle_acceleration
    INFO  [uorb] Advertising remote topic vehicle_angular_velocity
    INFO  [uorb] Advertising remote topic rate_ctrl_status
    INFO  [uorb] Advertising remote topic actuator_controls_0
    INFO  [uorb] Advertising remote topic actuator_outputs
    INFO  [uorb] Advertising remote topic multirotor_motor_limits
    INFO  [uorb] Advertising remote topic vehicle_imu
    INFO  [uorb] Advertising remote topic vehicle_imu_status
    INFO  [uorb] Advertising remote topic sensor_baro
    INFO  [uorb] Advertising remote topic sensor_selection
    INFO  [uorb] Advertising remote topic sensor_combined
    INFO  [uorb] Advertising remote topic ekf2_timestamps
    INFO  [uorb] Advertising remote topic vehicle_air_data
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    pxh> INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [muorb] SLPI: 651882145: reset position to last known position
    INFO  [muorb] SLPI: 651882145: reset velocity to zero
    INFO  [uorb] Marking DeviceNode(vehicle_local_position) as advertised in process_remote_topic
    INFO  [uorb] Advertising remote topic vehicle_odometry
    INFO  [uorb] Advertising remote topic estimator_states
    INFO  [uorb] Advertising remote topic estimator_status
    INFO  [uorb] Advertising remote topic estimator_status_flags
    INFO  [uorb] Advertising remote topic estimator_innovations
    INFO  [uorb] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uorb] Advertising remote topic estimator_innovation_variances
    INFO  [uorb] Advertising remote topic estimator_sensor_bias
    INFO  [muorb] SLPI: 658056317: EKF aligned, (baro hgt, IMU buf: 19, OBS buf: 14)
    INFO  [uorb] Advertising remote topic vehicle_attitude
    INFO  [uorb] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uorb] Advertising remote topic vehicle_rates_setpoint
    pxh> commander INFO  [muorb] SLPI: Heartbeat msg received
    pxh> commander armINFO  [muorb] SLPI: Heartbeat msg received
    pxh> INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    INFO  [commander] Handling Commander command 400
    INFO  [commander] Arming reason 3
    INFO  [commander] Armed by internal command
    INFO  [commander] Armed state changed. Was 0, now 1
    INFO  [muorb] SLPI: Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
    pxh> comINFO  [muorb] SLPI: Heartbeat msg received
    pxh> commandINFO  [muorb] SLPI: Heartbeat msg received
    pxh> commandedrINFO  [muorb] SLPI: Heartbeat msg received
    pxh> commanderINFO  [muorb] SLPI: Heartbeat msg received
    pxh> commander takeoffINFO  [muorb] SLPI: Heartbeat msg received
    INFO  [commander] Handling Commander command 22
    ERROR [commander] Takeoff denied! Please disarm and retry
    This is the terminal ouput for gazebo
    ~/Develop/PX4-Autopilot$ gazebo Tools/sitl_gazebo/worlds/hitl_iris.world
    Opened serial device /dev/ttyUSB0
    ../src/intel/isl/isl.c:2220: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
    How to solve it ?
    • Zachary LowellZ Offline
      Zachary Lowell
      Hi Tamas, what is your setup inside the gazebo world? Are you leveraging the iris_vision inside the world setup? Furthermore, are you leveraging the iris_hitl inside the iris_vision.sdf file?
      • Zachary LowellZ Zachary Lowell
        Tamas Pal 0
        wrote on last edited by Tamas Pal 0
        @Zachary-Lowell
        The vehicle is taking off but it is getting landed everytime without any command. I am giving all the details for the files as well as terminal ouput and the video of the gazebo simulation here.
        Gazebo terminal:
        hitl_iris.world file:
        https://drive.google.com/file/d/1XmbLVB8hupB-iQIu15NqTMwbjZcBds8C/view?usp=sharing
        https://drive.google.com/file/d/1gzevFQDfHWjrVt0asj6yaoXJ5xidLbEE/view?usp=sharing
        iris_hitl.sdf file
        https://drive.google.com/file/d/1TXZl4kGkAtvqfhoLy_pqRjdJQqlDe876/view?usp=sharing
        VOXL 2 terminal :
        voxl-px4-hitl -v
        ______  __   __    ___
        | ___ \ \ \ / /   /   |
        | |_/ /  \ V /   / /| |
        |  __/   /   \  / /_| |
        | |     / /^\ \ \___  |
        \_|     \/   \/     |_/
        px4 starting.
        Exiting NOW.
        ______  __   __    ___
        | ___ \ \ \ / /   /   |
        | |_/ /  \ V /   / /| |
        |  __/   /   \  / /_| |
        | |     / /^\ \ \___  |
        \_|     \/   \/     |_/
        px4 starting.
        INFO  [logger] [logger] /data/px4/log/sess011/log001.ulg
        INFO  [logger] Opened full log file: /data/px4/log/sess011/log001.ulg
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 83649315, current timestamp 83649316
        INFO  [qshell] qshell return value timestamp: 83649315, local time: 83651914
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 85955877, current timestamp 85955879
        INFO  [qshell] qshell return value timestamp: 85955877, local time: 85960166
        INFO  [commander] Mission #2 loaded, 6 WPs, curr: 0
        INFO  [muorb] SLPI: Advertising remote topic mission
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 87137181, current timestamp 87137183
        INFO  [qshell] qshell return value timestamp: 87137181, local time: 87150601
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 87224721, current timestamp 87224723
        INFO  [qshell] qshell return value timestamp: 87224721, local time: 87225799
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 87324545, current timestamp 87324547
        INFO  [qshell] qshell return value timestamp: 87324545, local time: 87325976
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 87381934, current timestamp 87381936
        INFO  [qshell] qshell return value timestamp: 87381934, local time: 87382996
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 87488002, current timestamp 87488004
        INFO  [qshell] qshell return value timestamp: 87488002, local time: 87489521
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 88531571, current timestamp 88531573
        INFO  [qshell] qshell return value timestamp: 88531571, local time: 88533242
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 88596133, current timestamp 88596135
        INFO  [qshell] qshell return value timestamp: 88596133, local time: 88596950
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 89876494, current timestamp 89876496
        INFO  [qshell] qshell return value timestamp: 89876494, local time: 89880326
        INFO  [muorb] SLPI: Sending qshell retval with timestamp 90931967, current timestamp 90931969
        INFO  [qshell] qshell return value timestamp: 90931967, local time: 90933817
        INFO  [uorb] Advertising remote topic vehicle_visual_odometry
        INFO  [muorb] SLPI: Heartbeat msg receivedINFO  [muorb] SLPI: Heartbeat msg received
        pxh> INFO  [muorb] SLPI: Heartbeat msg received
        INFO  [muorb] SLPI: 91928958: reset position to last known position
        INFO  [muorb] SLPI: 91928958: reset velocity to zero
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 35 -> 37
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 53 -> 55
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 72 -> 74
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 74 -> 76
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 158 -> 160
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 179 -> 181
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 194 -> 196
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 196 -> 198
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 211 -> 213
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 230 -> 232
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 246 -> 248
        INFO  [muorb] SLPI: 98115057: EKF aligned, (ev hgt, IMU buf: 19, OBS buf: 14)
        INFO  [muorb] SLPI: 98146494: starting vision yaw fusion
        INFO  [muorb] SLPI: 98178823: reset position to ev position
        INFO  [muorb] SLPI: 98178823: starting vision pos fusion
        INFO  [muorb] SLPI: 98178823: reset to vision velocity
        INFO  [muorb] SLPI: 98178823: starting vision vel fusion
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 268 -> 270
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 283 -> 285
        INFO  [muorb] SLPI: Advertising remote topic home_position
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 324 -> 326
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 336 -> 338
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 409 -> 411
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 430 -> 432
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 449 -> 451
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 451 -> 453
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 488 -> 490
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 509 -> 511
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 546 -> 548
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 548 -> 550
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 550 -> 552
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 566 -> 568
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 583 -> 585
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 586 -> 588
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 671 -> 673
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 715 -> 717
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 730 -> 732
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 732 -> 734
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 761 -> 763
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 798 -> 800
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 851 -> 853
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 853 -> 855
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 885 -> 887
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 905 -> 907
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 929 -> 931
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 947 -> 949
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 953 -> 955
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 969 -> 971
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1004 -> 1006
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1041 -> 1043
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1081 -> 1083
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1118 -> 1120
        ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1122 -> 1124
        Continued...
        • Tamas Pal 0T Tamas Pal 0
          @Zachary-Lowell
          Gazebo terminal:
          iris_hitl.sdf file
          VOXL 2 terminal :
          voxl-px4-hitl -v
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          Exiting NOW.
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          INFO  [muorb] SLPI:
          Continued...
          Tamas Pal 0
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1149 -> 1151
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1194 -> 1196
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1197 -> 1199
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1235 -> 1237
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1237 -> 1239
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1253 -> 1255
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1294 -> 1296
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1351 -> 1353
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1353 -> 1355
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1375 -> 1377
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1393 -> 1395
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1444 -> 1446
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1446 -> 1448
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1460 -> 1462
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1476 -> 1478
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1497 -> 1499
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1547 -> 1549
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1567 -> 1569
          pxh> coINFO  [muorb] SLPI: Heartbeat msg received
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1616 -> 1618
          pxh> comERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1618 -> 1620
          pxh> commanINFO  [muorb] SLPI: Heartbeat msg received
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1652 -> 1654
          pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1654 -> 1656
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1656 -> 1658
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1662 -> 1664
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1723 -> 1725
          pxh> commander arINFO  [muorb] SLPI: Heartbeat msg received
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1742 -> 1744
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1777 -> 1779
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1779 -> 1781
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1819 -> 1821
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1858 -> 1860
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1871 -> 1873
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1901 -> 1903
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1917 -> 1919
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1934 -> 1936
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1936 -> 1938
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1990 -> 1992
          pxh> cINFO  [muorb] SLPI: Heartbeat msg received
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2067 -> 2069
          pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2071 -> 2073
          pxh> commander taINFO  [muorb] SLPI: Heartbeat msg received
          pxh> commander takeERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2174 -> 2176
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2183 -> 2185
          pxh> commander takeofERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2202 -> 2204
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2228 -> 2230
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2238 -> 2240
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2355 -> 2357
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2419 -> 2421
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2421 -> 2423
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2456 -> 2458
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2462 -> 2464
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2545 -> 2547
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2547 -> 2549
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2564 -> 2566
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2569 -> 2571
          INFO  [navigator] Using minimum takeoff altitude: 2.50 m
          INFO  [muorb] SLPI: Advertising remote topic mission_result
          INFO  [muorb] SLPI: Advertising remote topic trajectory_setpoint
          INFO  [muorb] SLPI: Advertising remote topic vehicle_constraints
          INFO  [muorb] SLPI: Advertising remote topic takeoff_status
          INFO  [muorb] SLPI: Advertising remote topic landing_gear
          INFO  [uorb] Advertising remote topic vehicle_local_position_setpoint
          INFO  [uorb] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
          INFO  [commander] Takeoff detected
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2600 -> 2602
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2626 -> 2628
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2677 -> 2679
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2710 -> 2712
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2712 -> 2714
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2714 -> 2716
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2733 -> 2735
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2737 -> 2739
          ERROR [commander] Critical navigation failure! Check sensor calibration
          ERROR [commander] Failsafe enabled: no local position
          INFO  [commander] Failsafe mode activated
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2824 -> 2826
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2843 -> 2845
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2866 -> 2868
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2878 -> 2880
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2885 -> 2887
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2903 -> 2905
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2922 -> 2924
          INFO  [uorb] Advertising remote topic hover_thrust_estimate
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2964 -> 2966
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2966 -> 2968
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2999 -> 3001
          pxh> commINFO  [commander] Landing detected
          pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3074 -> 3076
          pxh> commanderERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3094 -> 3096
          pxh> commander taINFO  [commander] Disarming reason 7
          INFO  [commander] Disarmed by landing
          INFO  [commander] Armed state changed. Was 1, now 0
          INFO  [commander] Failsafe mode deactivated
          INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 12861942 ***
          INFO  [uorb] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
          INFO  [muorb] SLPI: Waiting for parameter_server_set_value_response for LND_FLIGHT_T_LO
          INFO  [parameters] Got parameter_server_set_value_request for LND_FLIGHT_T_LO
          INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
          INFO  [muorb] SLPI: Got parameter_server_set_value_response for LND_FLIGHT_T_LO
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3130 -> 3132
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3132 -> 3134
          pxh> commander takeINFO  [muorb] SLPI: Heartbeat msg received
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3154 -> 3156
          pxh> commander takeoINFO  [logger] closed logfile, bytes written: 2258769
          pxh> commander takeofINFO  [muorb] SLPI: Heartbeat msg received
          INFO  [logger] [logger] /data/px4/log/sess011/log002.ulg
          INFO  [logger] Opened full log file: /data/px4/log/sess011/log002.ulg
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3279 -> 3281
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3283 -> 3285
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3343 -> 3345
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3379 -> 3381
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3382 -> 3384
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3395 -> 3397
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3399 -> 3401
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3457 -> 3459
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3582 -> 3584
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3593 -> 3595
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3612 -> 3614
          pxh> commander takeoffERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3704 -> 3706
          INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 23966079 ***
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3739 -> 3741
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3747 -> 3749
          INFO  [logger] [logger] /data/px4/log/sess011/log003.ulg
          INFO  [logger] closed logfile, bytes written: 508353
          INFO  [logger] Opened full log file: /data/px4/log/sess011/log003.ulg
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3776 -> 3778
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3821 -> 3823
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3843 -> 3845
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3877 -> 3879
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3880 -> 3882
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3901 -> 3903
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3919 -> 3921
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3921 -> 3923
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3928 -> 3930
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3932 -> 3934
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3987 -> 3989
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3990 -> 3992
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3993 -> 3995
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4007 -> 4009
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4042 -> 4044
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4065 -> 4067
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4069 -> 4071
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4105 -> 4107
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4155 -> 4157
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4179 -> 4181
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4196 -> 4198
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4264 -> 4266
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4286 -> 4288
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4319 -> 4321
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4337 -> 4339
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4339 -> 4341
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4348 -> 4350
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4353 -> 4355
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4355 -> 4357
          INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 36946710 ***
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4387 -> 4389
          INFO  [logger] closed logfile, bytes written: 547275
          PX4 Exiting...
          Link for the gazebo simulation video:
          https://drive.google.com/file/d/1FT72ZRFp_BoLFyg9e005A3ltwK-s3kOA/view?usp=sharing
          Why the odometry lost message is there ? How to fix this landing issue?
          • Guangyu YangG Offline
            Guangyu Yang
            Hi Tamas, did you solve the problem? I have the same issue.
