    Unable to takeoff in hitl simulation in VIO mode
    • Tamas Pal 0T
      Tamas Pal 0
      I am trying to run hitl simulation in VIO mode with voxl 2. When I was trying to take off in vio mode it is getting rejected everytime although I can arm it. This is the terminal output for voxl 2
      voxl2:/$ voxl-px4-hitl -v
      Found DSP signature file
      Setting VIO Parameters for HITL
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl-vio-parameters.config 0
        CBRK_SUPPLY_CHK: curr: 0 -> new: 894281
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CBRK_SUPPLY_CHK
        COM_DISARM_PRFLT: curr: 10.0000 -> new: -1.0000
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_PRFLT
        COM_RC_IN_MODE: curr: 0 -> new: 1
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_RC_IN_MODE
        NAV_RCL_ACT: curr: 2 -> new: 0
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for NAV_RCL_ACT
        EKF2_AID_MASK: curr: 1 -> new: 280
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_AID_MASK
        SYS_HAS_MAG: curr: 1 -> new: 0
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_HAS_MAG
        EKF2_MAG_TYPE: curr: 0 -> new: 5
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_MAG_TYPE
        EKF2_HGT_MODE: curr: 0 -> new: 3
      ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_HGT_MODE
      Exiting NOW.
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl.config 0
      INFO  [muorb] SLPI: Creating qurt thread hpwork
      INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
      INFO  [muorb] SLPI: Creating qurt thread lpwork
      INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
      INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
      INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
      INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
      INFO  [muorb] SLPI: Creating qurt thread wq_manager
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
      INFO  [muorb] SLPI: Creating qurt thread qshell
      INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
      INFO  [logger] Start file log (type: full)
      INFO  [logger] [logger] /data/px4/log/sess004/log001.ulg
      INFO  [logger] Opened full log file: /data/px4/log/sess004/log001.ulg
      ERROR [logger] No subscriptions added
      INFO  [muorb] SLPI: Advertising remote topic mavlink_log
      INFO  [muorb] SLPI: Advertising remote topic logger_status
      INFO  [qshell] Send cmd: 'icm42688p start -s -h'
      INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -h
      INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77
      INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -h
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 643137190, current timestamp 643137191
      INFO  [uorb] Advertising remote topic qshell_retval
      INFO  [qshell] qshell return value timestamp: 643137190, local time: 643145778
      ERROR [muorb] SLPI: Cannot reset all parameters on client side
      INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
      INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
      INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
      INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
      INFO  [qshell] Send cmd: 'sensors start -h'
      INFO  [muorb] SLPI: qshell gotten: sensors start -h
      INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 76
      INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 75
      INFO  [muorb] SLPI: Ok executing command: sensors start -h
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 645460873, current timestamp 645460875
      INFO  [uorb] Advertising remote topic sensors_status_imu
      INFO  [qshell] qshell return value timestamp: 645460873, local time: 645462858
      INFO  [commander] LED: open /dev/led0 failed (22)
      INFO  [muorb] SLPI: Advertising remote topic led_control
      INFO  [muorb] SLPI: Advertising remote topic tune_control
      INFO  [PreFlightCheck] Failed barometer preflight check
      INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
      INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
      INFO  [muorb] SLPI: Advertising remote topic vehicle_status
      INFO  [muorb] SLPI: Advertising remote topic actuator_armed
      INFO  [muorb] SLPI: Advertising remote topic commander_state
      INFO  [PreFlightCheck] Preflight fail EKF couldn't get status
      INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
      INFO  [muorb] SLPI: Advertising remote topic vehicle_command
      INFO  [commander] Handling Commander command 176
      INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 646677913, current timestamp 646677915
      INFO  [qshell] qshell return value timestamp: 646677913, local time: 646679184
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 646755405, current timestamp 646755407
      INFO  [qshell] qshell return value timestamp: 646755405, local time: 646757219
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 646851157, current timestamp 646851159
      INFO  [qshell] qshell return value timestamp: 646851157, local time: 646859901
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 646914221, current timestamp 646914223
      INFO  [qshell] qshell return value timestamp: 646914221, local time: 646914687
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 647035223, current timestamp 647035225
      INFO  [qshell] qshell return value timestamp: 647035223, local time: 647038832
      INFO  [uorb] Advertising remote topic vehicle_land_detected
      INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
      INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
      INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 74
      INFO  [uorb] Advertising remote topic test_motor
      INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 648087744, current timestamp 648087745
      INFO  [qshell] qshell return value timestamp: 648087744, local time: 648089970
      INFO  [qshell] Send cmd: 'mixer load /dev/pwm_output0 quad_x.main.mix'
      INFO  [muorb] SLPI: qshell gotten: mixer load /dev/pwm_output0 quad_x.main.mix
      INFO  [muorb] SLPI: Ok executing command: mixer load /dev/pwm_output0 quad_x.main.mix
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 648151227, current timestamp 648151229
      INFO  [qshell] qshell return value timestamp: 648151227, local time: 648156266
      INFO  [muorb] SLPI: Creating qurt thread wq_INS0
      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 4170
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 649427101, current timestamp 649427103
      INFO  [qshell] qshell return value timestamp: 649427101, local time: 649429257
      INFO  [qshell] Send cmd: 'modalai_dsp start -v -p 2 -b 921600'
      INFO  [muorb] SLPI: qshell gotten: modalai_dsp start -v -p 2 -b 921600
      INFO  [muorb] SLPI: Creating qurt thread modalai_dsp__main
      INFO  [muorb] SLPI: Successfully created px4 task PX4_modalai_dsp__main with tid 73
      INFO  [muorb] SLPI: Ok executing command: modalai_dsp start -v -p 2 -b 921600
      INFO  [muorb] SLPI: Sending qshell retval with timestamp 650497255, current timestamp 650497258
      ERROR [muorb] SLPI: Port is open: 0
      INFO  [qshell] qshell return value timestamp: 650497255, local time: 650498945
      INFO  [uorb] Advertising remote topic sensor_accel
      INFO  [uorb] Advertising remote topic sensor_gyro
      INFO  [muorb] SLPI: Got 5 from orb_subscribe
      INFO  [muorb] SLPI: Got 6 from orb_subscribe
      INFO  [muorb] SLPI: Got 7 from orb_subscribe
      INFO  [muorb] SLPI: Got 8 from orb_subscribe
      INFO  [muorb] SLPI: Heartbeat msg received
      INFO  [uorb] Advertising remote topic battery_status
      INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
      INFO  [uorb] Advertising remote topic vehicle_acceleration
      INFO  [uorb] Advertising remote topic vehicle_angular_velocity
      INFO  [uorb] Advertising remote topic rate_ctrl_status
      INFO  [uorb] Advertising remote topic actuator_controls_0
      INFO  [uorb] Advertising remote topic actuator_outputs
      INFO  [uorb] Advertising remote topic multirotor_motor_limits
      INFO  [uorb] Advertising remote topic vehicle_imu
      INFO  [uorb] Advertising remote topic vehicle_imu_status
      INFO  [uorb] Advertising remote topic sensor_baro
      INFO  [uorb] Advertising remote topic sensor_selection
      INFO  [uorb] Advertising remote topic sensor_combined
      INFO  [uorb] Advertising remote topic ekf2_timestamps
      INFO  [uorb] Advertising remote topic vehicle_air_data
      INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
      pxh> INFO  [muorb] SLPI: Advertising remote topic telemetry_status
      INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
      INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
      INFO  [muorb] SLPI: Advertising remote topic timesync_status
      INFO  [muorb] SLPI: 651882145: reset position to last known position
      INFO  [muorb] SLPI: 651882145: reset velocity to zero
      INFO  [uorb] Marking DeviceNode(vehicle_local_position) as advertised in process_remote_topic
      INFO  [uorb] Advertising remote topic vehicle_odometry
      INFO  [uorb] Advertising remote topic estimator_states
      INFO  [uorb] Advertising remote topic estimator_status
      INFO  [uorb] Advertising remote topic estimator_status_flags
      INFO  [uorb] Advertising remote topic estimator_innovations
      INFO  [uorb] Advertising remote topic estimator_innovation_test_ratios
      INFO  [uorb] Advertising remote topic estimator_innovation_variances
      INFO  [uorb] Advertising remote topic estimator_sensor_bias
      INFO  [muorb] SLPI: 658056317: EKF aligned, (baro hgt, IMU buf: 19, OBS buf: 14)
      INFO  [uorb] Advertising remote topic vehicle_attitude
      INFO  [uorb] Advertising remote topic vehicle_attitude_setpoint
      INFO  [uorb] Advertising remote topic vehicle_rates_setpoint
      pxh> commander INFO  [muorb] SLPI: Heartbeat msg received
      pxh> commander armINFO  [muorb] SLPI: Heartbeat msg received
      pxh> INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
      INFO  [commander] Handling Commander command 400
      INFO  [commander] Arming reason 3
      INFO  [commander] Armed by internal command
      INFO  [commander] Armed state changed. Was 0, now 1
      INFO  [muorb] SLPI: Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
      pxh> comINFO  [muorb] SLPI: Heartbeat msg received
      pxh> commandINFO  [muorb] SLPI: Heartbeat msg received
      pxh> commandedrINFO  [muorb] SLPI: Heartbeat msg received
      pxh> commanderINFO  [muorb] SLPI: Heartbeat msg received
      pxh> commander takeoffINFO  [muorb] SLPI: Heartbeat msg received
      INFO  [commander] Handling Commander command 22
      ERROR [commander] Takeoff denied! Please disarm and retry
      This is the terminal ouput for gazebo
      ~/Develop/PX4-Autopilot$ gazebo Tools/sitl_gazebo/worlds/hitl_iris.world
      Opened serial device /dev/ttyUSB0
      ../src/intel/isl/isl.c:2220: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
      How to solve it ?
      • Zachary LowellZ
        Zachary Lowell ModalAI Team
        Hi Tamas, what is your setup inside the gazebo world? Are you leveraging the iris_vision inside the world setup? Furthermore, are you leveraging the iris_hitl inside the iris_vision.sdf file?
        Tamas Pal 0T 1 Reply Last reply Reply Quote 0
        • Tamas Pal 0T
          Tamas Pal 0 @Zachary Lowell
          @Zachary-Lowell
          The vehicle is taking off but it is getting landed everytime without any command. I am giving all the details for the files as well as terminal ouput and the video of the gazebo simulation here.
          Gazebo terminal:
          hitl_iris.world file:
          https://drive.google.com/file/d/1XmbLVB8hupB-iQIu15NqTMwbjZcBds8C/view?usp=sharing
          https://drive.google.com/file/d/1gzevFQDfHWjrVt0asj6yaoXJ5xidLbEE/view?usp=sharing
          iris_hitl.sdf file
          https://drive.google.com/file/d/1TXZl4kGkAtvqfhoLy_pqRjdJQqlDe876/view?usp=sharing
          VOXL 2 terminal :
          voxl-px4-hitl -v
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          Exiting NOW.
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          INFO  [logger] [logger] /data/px4/log/sess011/log001.ulg
          INFO  [logger] Opened full log file: /data/px4/log/sess011/log001.ulg
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 83649315, current timestamp 83649316
          INFO  [qshell] qshell return value timestamp: 83649315, local time: 83651914
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 85955877, current timestamp 85955879
          INFO  [qshell] qshell return value timestamp: 85955877, local time: 85960166
          INFO  [commander] Mission #2 loaded, 6 WPs, curr: 0
          INFO  [muorb] SLPI: Advertising remote topic mission
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 87137181, current timestamp 87137183
          INFO  [qshell] qshell return value timestamp: 87137181, local time: 87150601
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 87224721, current timestamp 87224723
          INFO  [qshell] qshell return value timestamp: 87224721, local time: 87225799
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 87324545, current timestamp 87324547
          INFO  [qshell] qshell return value timestamp: 87324545, local time: 87325976
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 87381934, current timestamp 87381936
          INFO  [qshell] qshell return value timestamp: 87381934, local time: 87382996
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 87488002, current timestamp 87488004
          INFO  [qshell] qshell return value timestamp: 87488002, local time: 87489521
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 88531571, current timestamp 88531573
          INFO  [qshell] qshell return value timestamp: 88531571, local time: 88533242
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 88596133, current timestamp 88596135
          INFO  [qshell] qshell return value timestamp: 88596133, local time: 88596950
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 89876494, current timestamp 89876496
          INFO  [qshell] qshell return value timestamp: 89876494, local time: 89880326
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 90931967, current timestamp 90931969
          INFO  [qshell] qshell return value timestamp: 90931967, local time: 90933817
          INFO  [uorb] Advertising remote topic vehicle_visual_odometry
          INFO  [muorb] SLPI: Heartbeat msg receivedINFO  [muorb] SLPI: Heartbeat msg received
          pxh> INFO  [muorb] SLPI: Heartbeat msg received
          INFO  [muorb] SLPI: 91928958: reset position to last known position
          INFO  [muorb] SLPI: 91928958: reset velocity to zero
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 35 -> 37
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 53 -> 55
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 72 -> 74
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 74 -> 76
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 158 -> 160
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 179 -> 181
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 194 -> 196
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 196 -> 198
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 211 -> 213
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 230 -> 232
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 246 -> 248
          INFO  [muorb] SLPI: 98115057: EKF aligned, (ev hgt, IMU buf: 19, OBS buf: 14)
          INFO  [muorb] SLPI: 98146494: starting vision yaw fusion
          INFO  [muorb] SLPI: 98178823: reset position to ev position
          INFO  [muorb] SLPI: 98178823: starting vision pos fusion
          INFO  [muorb] SLPI: 98178823: reset to vision velocity
          INFO  [muorb] SLPI: 98178823: starting vision vel fusion
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 268 -> 270
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 283 -> 285
          INFO  [muorb] SLPI: Advertising remote topic home_position
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 324 -> 326
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 336 -> 338
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 409 -> 411
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 430 -> 432
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 449 -> 451
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 451 -> 453
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 488 -> 490
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 509 -> 511
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 546 -> 548
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 548 -> 550
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 550 -> 552
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 566 -> 568
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 583 -> 585
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 586 -> 588
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 671 -> 673
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 715 -> 717
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 730 -> 732
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 732 -> 734
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 761 -> 763
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 798 -> 800
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 851 -> 853
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 853 -> 855
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 885 -> 887
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 905 -> 907
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 929 -> 931
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 947 -> 949
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 953 -> 955
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 969 -> 971
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1004 -> 1006
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1041 -> 1043
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1081 -> 1083
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1118 -> 1120
          ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1122 -> 1124
          Continued...
          • Tamas Pal 0T
            Tamas Pal 0 @Tamas Pal 0
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1149 -> 1151
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1194 -> 1196
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1197 -> 1199
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1235 -> 1237
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1237 -> 1239
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1253 -> 1255
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1294 -> 1296
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1351 -> 1353
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1353 -> 1355
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1375 -> 1377
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1393 -> 1395
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1444 -> 1446
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1446 -> 1448
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1460 -> 1462
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1476 -> 1478
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1497 -> 1499
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1547 -> 1549
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1567 -> 1569
            pxh> coINFO  [muorb] SLPI: Heartbeat msg received
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1616 -> 1618
            pxh> comERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1618 -> 1620
            pxh> commanINFO  [muorb] SLPI: Heartbeat msg received
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1652 -> 1654
            pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1654 -> 1656
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1656 -> 1658
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1662 -> 1664
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1723 -> 1725
            pxh> commander arINFO  [muorb] SLPI: Heartbeat msg received
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1742 -> 1744
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1777 -> 1779
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1779 -> 1781
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1819 -> 1821
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1858 -> 1860
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1871 -> 1873
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1901 -> 1903
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1917 -> 1919
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1934 -> 1936
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1936 -> 1938
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 1990 -> 1992
            pxh> cINFO  [muorb] SLPI: Heartbeat msg received
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2067 -> 2069
            pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2071 -> 2073
            pxh> commander taINFO  [muorb] SLPI: Heartbeat msg received
            pxh> commander takeERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2174 -> 2176
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2183 -> 2185
            pxh> commander takeofERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2202 -> 2204
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2228 -> 2230
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2238 -> 2240
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2355 -> 2357
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2419 -> 2421
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2421 -> 2423
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2456 -> 2458
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2462 -> 2464
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2545 -> 2547
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2547 -> 2549
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2564 -> 2566
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2569 -> 2571
            INFO  [navigator] Using minimum takeoff altitude: 2.50 m
            INFO  [muorb] SLPI: Advertising remote topic mission_result
            INFO  [muorb] SLPI: Advertising remote topic trajectory_setpoint
            INFO  [muorb] SLPI: Advertising remote topic vehicle_constraints
            INFO  [muorb] SLPI: Advertising remote topic takeoff_status
            INFO  [muorb] SLPI: Advertising remote topic landing_gear
            INFO  [uorb] Advertising remote topic vehicle_local_position_setpoint
            INFO  [uorb] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
            INFO  [commander] Takeoff detected
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2600 -> 2602
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2626 -> 2628
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2677 -> 2679
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2710 -> 2712
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2712 -> 2714
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2714 -> 2716
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2733 -> 2735
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2737 -> 2739
            ERROR [commander] Critical navigation failure! Check sensor calibration
            ERROR [commander] Failsafe enabled: no local position
            INFO  [commander] Failsafe mode activated
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2824 -> 2826
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2843 -> 2845
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2866 -> 2868
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2878 -> 2880
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2885 -> 2887
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2903 -> 2905
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2922 -> 2924
            INFO  [uorb] Advertising remote topic hover_thrust_estimate
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2964 -> 2966
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2966 -> 2968
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 2999 -> 3001
            pxh> commINFO  [commander] Landing detected
            pxh> commandERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3074 -> 3076
            pxh> commanderERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3094 -> 3096
            pxh> commander taINFO  [commander] Disarming reason 7
            INFO  [commander] Disarmed by landing
            INFO  [commander] Armed state changed. Was 1, now 0
            INFO  [commander] Failsafe mode deactivated
            INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 12861942 ***
            INFO  [uorb] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
            INFO  [muorb] SLPI: Waiting for parameter_server_set_value_response for LND_FLIGHT_T_LO
            INFO  [parameters] Got parameter_server_set_value_request for LND_FLIGHT_T_LO
            INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
            INFO  [muorb] SLPI: Got parameter_server_set_value_response for LND_FLIGHT_T_LO
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3130 -> 3132
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3132 -> 3134
            pxh> commander takeINFO  [muorb] SLPI: Heartbeat msg received
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3154 -> 3156
            pxh> commander takeoINFO  [logger] closed logfile, bytes written: 2258769
            pxh> commander takeofINFO  [muorb] SLPI: Heartbeat msg received
            INFO  [logger] [logger] /data/px4/log/sess011/log002.ulg
            INFO  [logger] Opened full log file: /data/px4/log/sess011/log002.ulg
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3279 -> 3281
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3283 -> 3285
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3343 -> 3345
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3379 -> 3381
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3382 -> 3384
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3395 -> 3397
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3399 -> 3401
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3457 -> 3459
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3582 -> 3584
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3593 -> 3595
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3612 -> 3614
            pxh> commander takeoffERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3704 -> 3706
            INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 23966079 ***
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3739 -> 3741
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3747 -> 3749
            INFO  [logger] [logger] /data/px4/log/sess011/log003.ulg
            INFO  [logger] closed logfile, bytes written: 508353
            INFO  [logger] Opened full log file: /data/px4/log/sess011/log003.ulg
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3776 -> 3778
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3821 -> 3823
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3843 -> 3845
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3877 -> 3879
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3880 -> 3882
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3901 -> 3903
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3919 -> 3921
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3921 -> 3923
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3928 -> 3930
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3932 -> 3934
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3987 -> 3989
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3990 -> 3992
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 3993 -> 3995
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4007 -> 4009
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4042 -> 4044
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4065 -> 4067
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4069 -> 4071
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4105 -> 4107
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4155 -> 4157
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4179 -> 4181
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4196 -> 4198
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4264 -> 4266
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4286 -> 4288
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4319 -> 4321
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4337 -> 4339
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4339 -> 4341
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4348 -> 4350
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4353 -> 4355
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4355 -> 4357
            INFO  [muorb] SLPI: *** Setting LND_FLIGHT_T_LO to 36946710 ***
            ERROR [muorb] SLPI: 0 - vehicle_visual_odometry lost, generation 4387 -> 4389
            INFO  [logger] closed logfile, bytes written: 547275
            PX4 Exiting...
            Link for the gazebo simulation video:
            https://drive.google.com/file/d/1FT72ZRFp_BoLFyg9e005A3ltwK-s3kOA/view?usp=sharing
            Why the odometry lost message is there ? How to fix this landing issue?
            • Guangyu YangG
              Guangyu Yang
              Hi Tamas, did you solve the problem? I have the same issue.
