  3. Resetting ssh password
m500
8 Posts 3 Posters 1.5k Views
  • Dean HartD Offline
    Dean HartD Offline
    Dean Hart
    I purchased the VOXL M500 over a year ago. I set it up initially but due to other projects I’m just getting back to it. Unable to ssh in using root/oelinux123 so worried I may have changed the password. How do I go about resetting it?
      If you're just getting back to it after a while anyways i'd recommend reflashing the board with our latest software stack from downloads.modalai.com . You'll find it under voxl1 platform releases and then platform 3.8.0-0.7. This will both reset the voxl's environment and get you up to date with our latest stuff.
      Dean HartD 1 Reply Last reply
      • ? A Former User
        Dean HartD Offline
        Dean HartD Offline
        Dean Hart
        wrote on last edited by Dean Hart
        Thanks @Alex-Gardner . I reflashed the board. Went through all the setup instructions but I'm stuck at https://docs.modalai.com/voxl-m500-user-guide-px4/#connect-m500-to-qgroundcontrol.
        QGC can see the drone, I can see telemetry streaming, but when trying to access vehicle settings I encounter the message Vehicle settings and info will display after connecting your vehicle.
        When attempting to arm I encounter the error Vehicle did not respond to command: MAV_CMD_COMPONENT_ARM_DISARM.
        This is what's running on the drone:
        root@apq8096:~# voxl-inspect-services  --version
         Service Name         |  Version  |  Enabled  |   Running   |  CPU Usage
         docker-autorun       |    1.2.4  | Disabled  | Not Running |
         docker-daemon        |    1.2.4  | Disabled  | Not Running |
         modallink-relink     |   0.15.1  | Disabled  | Not Running |
         voxl-camera-server   |    0.9.1  |  Enabled  |   Running   |     2.0
         voxl-cpu-monitor     |    0.2.5  |  Enabled  |   Running   |     0.0
         voxl-dfs-server      |    0.2.6  | Disabled  | Not Running |
         voxl-imu-server      |    1.0.1  |  Enabled  |   Running   |     0.0
         voxl-mavlink-server  |    0.1.1  |  Enabled  |   Running   |     0.0
         voxl-modem           |   0.15.1  | Disabled  | Not Running |
         voxl-portal          |    0.2.6  |  Enabled  |   Running   |     0.0
         voxl-qvio-server     |    0.4.6  |  Enabled  |   Running   |    10.1
         voxl-streamer        |    0.3.1  | Disabled  | Not Running |
         voxl-tag-detector    |    0.0.4  | Disabled  | Not Running |
         voxl-tflite-server   |    0.2.3  | Disabled  | Not Running |
         voxl-time-sync       |    1.1.1  | Disabled  | Not Running |
         voxl-vision-px4      |    1.0.5  |  Enabled  |   Running   |     0.0
         voxl-wait-for-fs     |    1.1.1  |  Enabled  |  Completed  |
        Any ideas?
        • James StrawsonJ Offline
          James Strawson
          Sounds like QGC is in the state where it failed to load all of the PX4 params and appears connected but not fully. When connecting to QGC does the green progress bar at the top of the QGC window completely go from left to right or does it get stuck halfway and throw a warning that it failed to load params?
            Dean HartD Offline
            Dean HartD Offline
            Dean Hart
            @James-Strawson Just restarted QGC to test. Correct. Green line stops just over 1/3 of the way and error Vehicle 1 did not respond to request for parameters. This will cause QGroundControl to be unable to display its full user interface is displayed.
              James Strawson
              wrote on last edited by James Strawson
              Are you trying to connect over Wifi? I generally see this when trying to get QGC to connect over a really slow data link instead of wifi. QGC is particularly sensitive to dropped packets during that initial param load phase.
                Dean HartD Offline
                Dean HartD Offline
                Dean Hart
                @James-Strawson Yes wifi (softAP mode).
                  Dean HartD Offline
                  Dean Hart
                  Seems to be an issue with QGC itself. The latest v4.2.3 I’m running is where it’s failing. If I revert back to the latest 4.1.* (4.1.7) it works.
