  3. Using a custom tflite model in VOXL 2
8 Posts 3 Posters 2.0k Views 1 Watching
  • Siyu ChenS Offline
    Siyu ChenS Offline
    Siyu Chen
    Hello team,
    I would like to use a custom tflite model on VOXL 2. The architecture of the model is EfficientDet-Lite3. I can't see any framed output in the voxl-portal. The output is almost the same as the hires but with a little deley.
    What I've done is push the custom tflite model file and the label file to the VOXL 2 and specify the location in the voxl-tflite-server.conf
    Could you kindly inform me how to deal with it? The picture below is the configuration of voxl-tflite-server.conf and the input and output of the custom model.
    Many thanks!
      Siyu ChenS Offline
      Siyu Chen
      I would like to add that sometimes it will come out a label called (0 person).
      But the label file I specified has no class called 0 person, which is very weird.
      It seems like it is still using this coco_labels.txt as the label file.Voxl2 拷贝.png
        You will need to modify the code to make use of your new model. You will need to code the tflite-server to both read the model, and then post_process the model based on the inputs and outouts of your model
        Link Preview Image
        src/main.cpp · master · voxl / VOXL SDK / Services / voxl-tflite-server · GitLab
        Tensorflow-Lite (TFlite) server that outputs Tflite processed images
        favicon
        GitLab (gitlab.com)
        Siyu ChenS 2 Replies Last reply
        • Chad SweetC Chad Sweet
          Link Preview Image
          favicon
          GitLab (gitlab.com)
          Siyu ChenS Offline
          Siyu ChenS Offline
          Siyu Chen
          @Chad-Sweet Thank you for your reply! I trained another yolov5 model so that I don't need to change too many things in the main.cpp file. Currently I just add the label file path and my model path in the main.cpp file.
          When I deployed the voxl-tflite-server to the VOXL 2, the output looks weird and it will stuck sometimes.
          The difference between the prebuild yolov5 model and my custom model is my model has only one class. Could you please tell me where I am doing wrong?
          Thank you very much for your attention to this matter!
            We don't know how to support you on yolov5, sorry. It might be easier to debug in TensorFlow Lite on your PC
            Siyu ChenS 1 Reply Last reply
              Siyu ChenS Offline
              Siyu ChenS Offline
              Siyu Chen
              @Chad-Sweet Okay, could you kindly inform me which version of yolov5 did you use in the prebuild version? I'm not sure if it's my model's problem, because it works fine in my computer. I'd like to try training an exectly the same yolov5 model for testing becase when I post_process the model most time it will raise an error in the voxl-portal shown below.
                Link Preview Image
                favicon
                GitLab (gitlab.com)
                Siyu ChenS Offline
                Siyu ChenS Offline
                Siyu Chen
                @Chad-Sweet said in Using a custom tflite model in VOXL 2:
                Link Preview Image
                favicon
                GitLab (gitlab.com)
                Problem sovled, there is much more code need to be changed than I expected. Thanks for your assistances!
                • Mihir BalaM Offline
                  Mihir BalaM Offline
                  Mihir Bala
                  I am trying to get pretty much the same thing working on the VOXL 2 with a Yolov5 model that only has one class. I am seeing similar outputs when I deploy it to the drone. @Siyu-Chen, what steps did you go through to get this working on your device? The model inferences just fine on my computer. I think it has something to do with the pre/post-processing. Thanks in advance for your help.
