    Systems Architecture Review
    • Kavin KailashK
      Kavin Kailash
      Dear ModalAI team,
      We are in the process of finalizing the (ModalAI-powered) flight systems architecture for our upcoming projects, and would love to hear your thoughts regarding the same.
      We are using VOXL2 (2X TOFs, 1 HiRes & 1 Tracking) as a OBC for high-level functions and Flight Core v2 for the low-level sensor interfacing and flight stabilisation running PX4. These are connected via UART and the voxl-mavlink-server is configured for external FC support. FlightCore is further integrated with 1x UART LiDAR, 1x CAN-based Optical Flow and 1xGPS (optionally)
      While we understand that VOXL2 is capable of running PX4 on-board we found the HW interfaces to the DSP on the VOXL2 a bit limited in terms of adding new sensors like (UART Rangefinder and CAN-based Optical Flow). Additionally we enjoy a few small quirks like the ability to restart the PX4 independent of the whole board.
      While adding Flight Core might initially feel a bit redundant in terms of available HW, we do eliminate the need for the IO Board entirely by going this route.
      While we still await hard flight test data, the hopes of adding the Optical Flow sensor is to enable the MAV to sustain flight in Position-enabled modes until VIO recovers (instead of falling over to AltHold or other manual modes). The range-finder was added to enable accurate indoor flights, as we found the in-built barometer to have quite a bit of altitude offset and drift.
      We would like to hear your views on whether the route we are taking is optimal and your recommendations on how to better suite your ecosystem with our requirements (the sensor setup mentioned above).
      Kavin Kailash Ravie
      UAVIO Labs
      • Chad SweetC
        Chad Sweet ModalAI Team
        Thank you very much for proactively posting your question. From a high-level, this looks reasonable. We do not have experience with all of those sensors, but don't see any major roadblocks.
        If you are comfortable, it would be very helpful to share a block diagram of what you plan to connect to which connectors for a little deeper review.
        • Kavin KailashK
          Kavin Kailash
          Thanks, for your quick response @Chad-Sweet .
          We have already flight tested part of the setup above (except HereFlow), and it seems to work great.
          Please find connection details in the attached picture below:VOXL2_SysArch.png
