  2. VOXL SDK and Software
  3. Error Response from Daemon: Cannot Start Container... write /sys/fs/cgroup/cpuset/system.slice/cpuset.cpus: invalid argument
2 Posts 1 Posters 767 Views
  • S Offline
    S Offline
    SMRC
    wrote on last edited by SMRC
    I am having an issue where I consistently cannot run any docker image on the drone (m500) due to a docker error:
    $ docker run -i hello-world
    Error response from daemon: Cannot start container 3b55c8ca8aac3d04d5015591df127777f40a568306dacc5a1fb40d7293f6ea4b: [8] System error: write /sys/fs/cgroup/cpuset/system.slice/cpuset.cpus: invalid argument
    this also happens with different flags and different images, as well as with docker or voxl-docker.
    Context/Things I've Tried:
    • Docker is being launched manually and pointed at the /data partition (by running 'docker daemon -g /data)
    • I have run opkg install (with needed forces) on the resulting package from voxl-docker-support.
    • I found this old thread with a similar topic, but their resolution (adding hello world) did not work for me:Docker System error: write /sys/fs/cgroup/cpuset/system.slice/cpuset.cpus: invalid
    If anyone has any insight as to what could be wrong here, I'd be very grateful. Thank you!
    Additional info:
    voxl:~$ docker info
    Containers: 4
    Images: 53
    Server Version: 1.9.0
    Storage Driver: overlay
    Backing Filesystem: extfs
    Execution Driver: native-0.2
    Logging Driver: json-file
    Kernel Version: 3.18.71-perf
    Operating System: msm-perf ModalAI 3.8.0
    CPUs: 4
    Total Memory: 3.682 GiB
    WARNING: No swap limit support
    This is the detailed error from the docker daemon log:
    • S Offline
      S Offline
      SMRC
      With the updates to this page (specifically running the setup script voxl-configure-docker-support), this issue is resolved.
      Thank you @Chad-Sweet for updating the page!
