<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error Response from Daemon: Cannot Start Container... write &#x2F;sys&#x2F;fs&#x2F;cgroup&#x2F;cpuset&#x2F;system.slice&#x2F;cpuset.cpus: invalid argument]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am having an issue where I consistently cannot run any docker image on the drone (m500) due to a docker error:</p>
<p dir="auto">$ docker run -i hello-world<br />
Error response from daemon: Cannot start container 3b55c8ca8aac3d04d5015591df127777f40a568306dacc5a1fb40d7293f6ea4b: [8] System error: write /sys/fs/cgroup/cpuset/system.slice/cpuset.cpus: invalid argument</p>
<p dir="auto">this also happens with different flags and different images, as well as with docker or voxl-docker.</p>
<p dir="auto">Context/Things I've Tried:</p>
<ul>
<li>Docker is being launched manually and pointed at the /data partition (by running 'docker daemon -g /data)</li>
<li>I have run opkg install (with needed forces) on the resulting package from <a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-docker-support" rel="nofollow ugc">voxl-docker-support</a>.</li>
<li>I found this old thread with a similar topic, but their resolution (adding hello world) did not work for me:<a href="/topic/664/docker-system-error-write-sys-fs-cgroup-cpuset-system-slice-cpuset-cpus-invalid">Docker System error: write /sys/fs/cgroup/cpuset/system.slice/cpuset.cpus: invalid</a></li>
</ul>
<p dir="auto">If anyone has any insight as to what could be wrong here, I'd be very grateful. Thank you!</p>
<p dir="auto"><em>Additional info:</em><br />
voxl:~$ docker info<br />
Containers: 4<br />
Images: 53<br />
Server Version: 1.9.0<br />
Storage Driver: overlay<br />
Backing Filesystem: extfs<br />
Execution Driver: native-0.2<br />
Logging Driver: json-file<br />
Kernel Version: 3.18.71-perf<br />
Operating System: msm-perf ModalAI 3.8.0<br />
CPUs: 4<br />
Total Memory: 3.682 GiB<br />
WARNING: No swap limit support</p>
<p dir="auto">This is the detailed error from the docker daemon log:<br />
<img src="/assets/uploads/files/1673898696672-0da305e9-ad7f-4a32-97a3-5faafe1d4511-image.png" alt="0da305e9-ad7f-4a32-97a3-5faafe1d4511-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/topic/1713/error-response-from-daemon-cannot-start-container-write-sys-fs-cgroup-cpuset-system-slice-cpuset-cpus-invalid-argument</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 18:14:48 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1713.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jan 2023 19:07:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error Response from Daemon: Cannot Start Container... write &#x2F;sys&#x2F;fs&#x2F;cgroup&#x2F;cpuset&#x2F;system.slice&#x2F;cpuset.cpus: invalid argument on Tue, 17 Jan 2023 14:12:43 GMT]]></title><description><![CDATA[<p dir="auto">With the updates to <a href="https://docs.modalai.com/docker-on-voxl/#move-docker-image-from-data-to-mntsdcard" rel="nofollow ugc">this page</a> (specifically running the setup script voxl-configure-docker-support), this issue is resolved.</p>
<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/chad-sweet" aria-label="Profile: Chad-Sweet">@<bdi>Chad-Sweet</bdi></a> for updating the page!</p>
]]></description><link>https://forum.modalai.com/post/7932</link><guid isPermaLink="true">https://forum.modalai.com/post/7932</guid><dc:creator><![CDATA[SMRC]]></dc:creator><pubDate>Tue, 17 Jan 2023 14:12:43 GMT</pubDate></item></channel></rss>
