  3. Partition is larger than filesystem; issue resizing filesystem
voxl
2 Posts 2 Posters 991 Views 1 Watching
  • John NomikosJ Offline
    John Nomikos
    Good afternoon,
    On two of the VOXLs we have, the amount of space partitioned for /dev/sda9 is 23.9G.
    However, the filesystem only has 15G available. I am not sure why the filesystem is so much smaller than the partition.
    voxl:/$ lsblk
    NAME    MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    sda       8:0    0 24.2G  0 disk
    |-sda1    8:1    0    8K  0 part
    |-sda2    8:2    0   32M  0 part /persist
    |-sda3    8:3    0  256M  0 part /cache
    |-sda4    8:4    0    1M  0 part
    |-sda5    8:5    0  512K  0 part
    |-sda6    8:6    0  128K  0 part
    |-sda7    8:7    0  128K  0 part
    |-sda8    8:8    0  512K  0 part
    `-sda9    8:9    0 23.9G  0 part /data
    sdb       8:16   0    4M  0 disk
    `-sdb1    8:17   0    4M  0 part
    sdc       8:32   0    4M  0 disk
    `-sdc1    8:33   0    4M  0 part
    sdd       8:48   0  128M  0 disk
    |-sdd1    8:49   0   32K  0 part
    |-sdd2    8:50   0    4K  0 part
    `-sdd3    8:51   0    1M  0 part
    sde       8:64   0    4G  0 disk
    |-sde1    8:65   0  512K  0 part
    |-sde2    8:66   0  512K  0 part
    |-sde3    8:67   0    2M  0 part
    |-sde4    8:68   0    2M  0 part
    |-sde5    8:69   0  512K  0 part
    |-sde6    8:70   0  512K  0 part
    |-sde7    8:71   0    2M  0 part
    |-sde8    8:72   0   16K  0 part
    |-sde9    8:73   0  512K  0 part
    |-sde10   8:74   0  512K  0 part
    |-sde11   8:75   0   95M  0 part /firmware
    |-sde12   8:76   0   16M  0 part /dsp
    |-sde13   8:77   0    1M  0 part
    |-sde14   8:78   0   32M  0 part
    |-sde15   8:79   0    1M  0 part
    |-sde16 259:0    0    1M  0 part
    |-sde17 259:1    0   64M  0 part
    |-sde18 259:2    0    3G  0 part /
    |-sde19 259:3    0   64M  0 part
    |-sde20 259:4    0  150M  0 part
    |-sde21 259:5    0    4K  0 part
    |-sde22 259:6    0    1M  0 part
    |-sde23 259:7    0  512K  0 part
    |-sde24 259:8    0  512K  0 part
    |-sde25 259:9    0  256K  0 part
    |-sde26 259:10   0  256K  0 part
    |-sde27 259:11   0  512K  0 part
    |-sde28 259:12   0  512K  0 part
    |-sde29 259:13   0  256K  0 part
    |-sde30 259:14   0  256K  0 part
    |-sde31 259:15   0    4K  0 part
    |-sde32 259:16   0 32.7M  0 part
    `-sde33 259:17   0    2M  0 part
    sdf       8:80   0  1.5G  0 disk
    |-sdf1    8:81   0    2M  0 part
    |-sdf2    8:82   0    2M  0 part
    `-sdf3    8:83   0    4K  0 part
    voxl:/$ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root       2.8G  1.9G  892M  68% /
    devtmpfs        1.8G     0  1.8G   0% /dev
    tmpfs           1.9G     0  1.9G   0% /dev/shm
    tmpfs           1.9G   17M  1.9G   1% /run
    tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
    tmpfs           1.9G  4.0K  1.9G   1% /var/volatile
    /dev/sda2       2.2M   80K  2.0M   4% /persist
    /dev/sde11       95M   33M   63M  35% /firmware
    /dev/sda3        58M   40K   57M   1% /cache
    /dev/sde12       12M  4.1M  7.4M  36% /dsp
    /dev/sda9        15G  744M   15G   5% /data
    After doing some research, I know entering the command sudo resize2fs /dev/sda9 should resize the filesystem to be as large as the partition. But, when I enter this command, I get a very strange error.
    voxl:/$ sudo resize2fs /dev/sda9
    resize2fs 1.42.9 (28-Dec-2013)
    Filesystem at /dev/sda9 is mounted on /data; on-line resizing required
    old_desc_blocks = 1, new_desc_blocks = 2
    resize2fs: Invalid argument While checking for on-line resizing support
    Performing an on-line resize of /dev/sda9 to 6261171 (4k) blocks.
    resize2fs: Invalid argument While trying to add group #125
    The only info I could find about the same issue is here, and it's not really helpful: https://debian-bugs-dist.debian.narkive.com/ysLUbdet/bug-805716-resize2fs-invalid-argument-while-checking-for-on-line-resizing-support
    On another drone we have, the difference in filesystem size to partition size is much greater. They only have 4.6 G of space on /dev/sda9 while the partition of sda9 is 24 G.
    Any insights would be appreciated. Thank you.
      We will have to look into this, we don't have any good answer
