    ESC feedback
    ESCs
    • ModeratorM
      Moderator ModalAI Team
      Question from customer - the modalai esc is working fine when commanded, but the RPM and voltage feedback is not available. I have attached a screenshot of the modalai_esc status which shows the feedback isn't coming in. I checked the connections, they seem fine.
      • modaltbM
        modaltb ModalAI Team
        Hello, thanks for reporting. Good news is we already have a fix in for via this commit:
        https://github.com/modalai/px4-firmware/commit/577fec3b9a843b709086fc07b913b2c194367e10
        It's slated to release in our next platform release (platform release 0.9), I can't mention the release date, as the release gods will then delay it... but we are getting close!!!!!
        There are pre-release channels available for developers, captured here: https://docs.modalai.com/configure-pkg-manager/#dev
        • vivek rkV
          vivek rk
          Hey, thanks for that. I was able to pull the voxl-dev branch and got it working on the VOXL2, I can see the feedback of the RPM on the mavlink topic SERVO_OUTPUT_RAW. But the frequency is at 10Hz.
          When I try to use the following command
          mavlink stream -u "port_number" -s SERVO_OUTPUT_RAW -r 100
          I get an error stream SERVO_OUTPUT_RAW not found
          From the uart_esc code in px4-firmware I see that the uorb topic thats being used for RPM information is ESC_STATUS. And doing the following commands yields no result. The frequency is still 10Hz
          mavlink stream -u "port_number" -s ESC_STATUS -r 100
          mavlink stream -u "port_number" -s ESC_INFO -r 100
          Is there anything I can do to increase the frequency of the message ?
          • modaltbM
            Sorry for the lag, what if you use px4-listener esc_status ?
            If it's showing up there, likely we need to modify something to get this offboard....
            • vivek rkV
              vivek rk
              So when i try px4-listener it says command not found.
              The command that works is
              listener esc_status
              This produces the following resutls
              never published
              But after some investigation, the uorb topic with the rpm information is
              actuator_outputs
              I can read the output
              This topic is being published at 500Hz
              I tried to increase the rate of the following mavlink topics
              mavlink stream -u 15446 -s actuator_output -r 100
              mavlink stream -u 15446 -s ACTUATOR_OUTPUT -r 100
              mavlink stream -u 15446 -s actuator_outputs -r 100
              mavlink stream -u 15446 -s ACTUATOR_OUTPUTS -r 100
              Which results in the following error message
              ERROR [mavlink] stream ACTUATOR_OUTPUTS not found (same for all other)
              • vivek rkV
                vivek rk
                Fixed the problem, the mavlink stream name is SERVO_OUTPUT_RAW_0.
                changing that to 200Hz gives us the RPM feedback at 200Hz on mavros
