    MAVLink 1
    VOXL
    • JP DroneJ
      JP Drone
      voxl-mavlink seems to support only MAVLink 2.
      https://gitlab.com/voxl-public/voxl-sdk/third-party/voxl-mavlink/-/tree/master/files
      The third-party application I use uses MAVLink1 in part, which results in an error (actually no response).
      Do you plan to support MAVLink v1.0 in the future?
      • JP DroneJ
        JP Drone
        To reproduce:
        set MAV_PROTO_VER to 1 (always use version 1)
        VOXL cannot get any information from PX4.
          Eric Katzfey ModalAI Team @JP Drone
          @JP-Drone Until now we didn't know that there was a use case for v1.0. What is the third party application?
          JP DroneJ 1 Reply Last reply Reply Quote 0
          • JP DroneJ
            JP Drone @Eric Katzfey
            It's UgCS.
            The default is v1.0.
            It's possible to set v2 or auto.
            But if I set auto, it fails to connect.
            Because it tries to negotiate with v1 at first and VOXL doesn't handle it.
              @JP-Drone Does it work if you set it to v2?
              • JP DroneJ
                @Eric-Katzfey Yes, it works.
                I am not sure if changing the settings on the GCS side will affect the connection to other copter.
                But now it seems fine.
                Thanks.
