    Error/failure in voxl-build ...
    • Ed SutterE
      Ed Sutter
      Hi, I've done this before and it built clean, but tonight when I attempt to walk through the steps outlined in voxl-build README.md it fails when applying patch cci-direct-cam-info-opcode.patch.
      Did something change?
        There was a recent kernel update that includes this patch which is most likely why the build has failed. I'll have to test this on my end and see what the issue is. I'll keep you updated as I see why the error is occuring.
        Also, just to confirm, are you currently up to date on the master branch?
          Just an update, I was able to fix the patching issue. You can go ahead and try the build again and see if the issue persists.
          • Ed SutterE
            Ed Sutter
            Ok... whatever you did seems to have fixed it.
