  3. "Plan to a point" not working
5 Posts 2 Posters 1.1k Views
  • D Offline
    D Offline
    darwin.keem
    I am using Sentinel Drone with voxl-portal and voxl-mapper.
    We've changed voxl-mapper.conf to work with stereo camera.
    However, plan to a point is not working. When we give a point, it generates trajectory, but Sentinel doesn't move at all.
    We've changed offboard to trajectory. Is there any solution to it?
    Thanks.
    • ? Offline
      Hey @darwin-keem,
      Could you please share the output of apt list --installed | grep voxl so we can know which versions you have installed?
      Additionally, are you seeing any error messages from voxl-mapper when you try to follow the path?
      • D Offline
        D Offline
        darwin.keem
        wrote on last edited by darwin.keem
        Hi @Matt-Turi,
        output of apt list --installed | grep voxl is listed below.
        voxl2:~$ apt list --installed | grep voxl
        WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
        libvoxl-cutils/unknown,now 0.1.1 arm64 [installed,automatic]
        mv-voxl/now 0.1-r0 arm64 [installed,local]
        voxl-bind/unknown,now 0.0.1 arm64 [installed,automatic]
        voxl-camera-calibration/unknown,now 0.2.2 arm64 [installed,automatic]
        voxl-camera-server/unknown,now 1.1.0 arm64 [installed,automatic]
        voxl-ceres-solver/unknown,now 1.14.0-7 arm64 [installed,automatic]
        voxl-cpu-monitor/unknown,now 0.2.6 arm64 [installed,automatic]
        voxl-docker-support/unknown,now 1.2.4 arm64 [installed,automatic]
        voxl-jpeg-turbo/unknown,now 2.1.3-4 arm64 [installed,automatic]
        voxl-libgphoto2/unknown,now 0.0.4 arm64 [installed,automatic]
        voxl-libuvc/unknown,now 1.0.6 arm64 [installed,automatic]
        voxl-logger/unknown,now 0.3.2 arm64 [installed,automatic]
        voxl-mapper/unknown,now 0.0.7 arm64 [installed]
        voxl-mavlink/unknown,now 0.1.0 arm64 [installed,automatic]
        voxl-mavlink-server/unknown,now 0.1.3 arm64 [installed,automatic]
        voxl-modem/unknown,now 0.16.0 arm64 [installed,automatic]
        voxl-mongoose/unknown,now 7.6.0 arm64 [installed,automatic]
        voxl-mpa-to-ros/unknown,now 0.3.3 arm64 [installed,automatic]
        voxl-mpa-tools/unknown,now 0.7.2 arm64 [installed,automatic]
        voxl-nlopt/unknown,now 2.5.0-4 arm64 [installed,automatic]
        voxl-opencv/unknown,now 4.5.5-1 arm64 [installed,automatic]
        voxl-portal/unknown,now 0.2.8 arm64 [installed]
        voxl-px4/unknown,now 1.4.16 arm64 [installed,automatic]
        voxl-px4-imu-server/unknown,now 0.1.2 arm64 [installed,automatic]
        voxl-qvio-server/unknown,now 0.7.1 arm64 [installed,automatic]
        voxl-streamer/unknown,now 0.3.6 arm64 [installed,automatic]
        voxl-suite/unknown,now 0.8.1 arm64 [installed]
        voxl-tag-detector/unknown,now 0.0.4 arm64 [installed,automatic]
        voxl-tflite-server/unknown,now 0.2.7 arm64 [installed,automatic]
        voxl-utils/unknown,now 1.1.4 arm64 [installed,automatic]
        voxl-uvc-server/unknown,now 0.1.1 arm64 [installed,automatic]
        voxl-vision-px4/unknown,now 1.2.0 arm64 [installed,automatic]
        voxl-voxblox/unknown,now 1.0.4 arm64 [installed,automatic]
        voxl2-system-image/now 1.3.1-r0 arm64 [installed,local]
        voxl2-wlan/now 1.0-r0 arm64 [installed,local]
        We don't see any error messages from voxl-mapper.
        ERROR fetching tf from tf ringbuffer
        there wasn't sufficient data in the buffer
        This message shows up intermittently, but doesn't seems to effect in mapping function. Message below is the message after using Plan to a point feature.
        Client requested slice level update
        Client requested plan to location
        Using start pose of: x:  -0.08, y:   0.04, z:   0.02
        using goal pose of: x:  -1.04, y:   3.00, z:   0.02
        Map Bounds:
        Lower-> x: -6.40, y: -3.20, z: -3.20
        Upper-> x:  6.40, y:  6.40, z:  3.20
        Switching to 3D checks
        TIMING STATS
        Solve time             ->          1000.01ms
        Total time             ->          1000.04ms
        Random node grab time  -> Average:   0.00ms, TOT:  48.90ms
        Nearest node time      -> Average:   0.01ms, TOT: 508.83ms
        Check motion time      -> Average:   0.00ms, TOT: 354.81ms
        Neighborhood grab time -> Average:   0.00ms, TOT:   6.05ms
        Children update time   -> Average:    nanms, TOT:   0.00ms
        GENERAL STATS
        PATH LENGTH:   3.11
        ATTEMPTS: 42415
        QNEAREST FAILS: 59
        RANDOM TO NEAREST FAILS: 39915
        PARTIAL SEGMENTS ADDED: 2441
        TREE REWIRES: 0
        RRTSTAR FAILED: Exceeded max iterations. Outputting closest path
        Simplifying Path took:   0.07ms
        Removed 0 nodes
        Collisions along base path-> no
        No free constraints set in the vertices. Polynomial can not be optimized. Outputting fully constrained polynomial.
        Loco Smooth took: 467.29ms
        Success-> yes
        However, we found this error in voxl-portal. Would it be the reason of this problem? If so, how can we solve it?
        voxl2:/$ voxl-portal
        exising instance of voxl-portal found, attempting to stop it
        voxl-portal started up
        Server providing: battery connected
        Server providing: flight_info connected
        Server providing: gps connected
        Server not available
        Failed to open pipe: /run/mpa/plan_msgs/
        Server providing pose connected
        Server providing: costmap connected
        Server providing: mesh connected
        Server providing: plan connected
        Server providing: aligned ptcloud connected
        Thanks.
        • D Offline
          D Offline
          darwin.keem
          Additionaly, the Follow Path button doesn't shows up on the GUI of voxl-portal.
          • ? Offline
            @darwin-keem,
            It looks like voxl-mapper failed to reach your goal point, resulting in it sending over the partial trajectory it solved for viewing but not giving you the option to follow the path. You can try giving the RRT solver another second or so by increasing the rrt_max_runtime_nanoseconds param, and it should be able to fully plan to your endpoint.
            The path generation code has been rewritten and thoroughly optimized in the latest dev package, so if you are still having issues with this planner it may be worth checking out some of the updates on our dev repo.
