    "Plan to a point" not working
    • D
      darwin.keem
      I am using Sentinel Drone with voxl-portal and voxl-mapper.
      We've changed voxl-mapper.conf to work with stereo camera.
      However, plan to a point is not working. When we give a point, it generates trajectory, but Sentinel doesn't move at all.
      We've changed offboard to trajectory. Is there any solution to it?
      Thanks.
        Hey @darwin-keem,
        Could you please share the output of apt list --installed | grep voxl so we can know which versions you have installed?
        Additionally, are you seeing any error messages from voxl-mapper when you try to follow the path?
        • D
          darwin.keem
          Hi @Matt-Turi,
          output of apt list --installed | grep voxl is listed below.
          voxl2:~$ apt list --installed | grep voxl
          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
          libvoxl-cutils/unknown,now 0.1.1 arm64 [installed,automatic]
          mv-voxl/now 0.1-r0 arm64 [installed,local]
          voxl-bind/unknown,now 0.0.1 arm64 [installed,automatic]
          voxl-camera-calibration/unknown,now 0.2.2 arm64 [installed,automatic]
          voxl-camera-server/unknown,now 1.1.0 arm64 [installed,automatic]
          voxl-ceres-solver/unknown,now 1.14.0-7 arm64 [installed,automatic]
          voxl-cpu-monitor/unknown,now 0.2.6 arm64 [installed,automatic]
          voxl-docker-support/unknown,now 1.2.4 arm64 [installed,automatic]
          voxl-jpeg-turbo/unknown,now 2.1.3-4 arm64 [installed,automatic]
          voxl-libgphoto2/unknown,now 0.0.4 arm64 [installed,automatic]
          voxl-libuvc/unknown,now 1.0.6 arm64 [installed,automatic]
          voxl-logger/unknown,now 0.3.2 arm64 [installed,automatic]
          voxl-mapper/unknown,now 0.0.7 arm64 [installed]
          voxl-mavlink/unknown,now 0.1.0 arm64 [installed,automatic]
          voxl-mavlink-server/unknown,now 0.1.3 arm64 [installed,automatic]
          voxl-modem/unknown,now 0.16.0 arm64 [installed,automatic]
          voxl-mongoose/unknown,now 7.6.0 arm64 [installed,automatic]
          voxl-mpa-to-ros/unknown,now 0.3.3 arm64 [installed,automatic]
          voxl-mpa-tools/unknown,now 0.7.2 arm64 [installed,automatic]
          voxl-nlopt/unknown,now 2.5.0-4 arm64 [installed,automatic]
          voxl-opencv/unknown,now 4.5.5-1 arm64 [installed,automatic]
          voxl-portal/unknown,now 0.2.8 arm64 [installed]
          voxl-px4/unknown,now 1.4.16 arm64 [installed,automatic]
          voxl-px4-imu-server/unknown,now 0.1.2 arm64 [installed,automatic]
          voxl-qvio-server/unknown,now 0.7.1 arm64 [installed,automatic]
          voxl-streamer/unknown,now 0.3.6 arm64 [installed,automatic]
          voxl-suite/unknown,now 0.8.1 arm64 [installed]
          voxl-tag-detector/unknown,now 0.0.4 arm64 [installed,automatic]
          voxl-tflite-server/unknown,now 0.2.7 arm64 [installed,automatic]
          voxl-utils/unknown,now 1.1.4 arm64 [installed,automatic]
          voxl-uvc-server/unknown,now 0.1.1 arm64 [installed,automatic]
          voxl-vision-px4/unknown,now 1.2.0 arm64 [installed,automatic]
          voxl-voxblox/unknown,now 1.0.4 arm64 [installed,automatic]
          voxl2-system-image/now 1.3.1-r0 arm64 [installed,local]
          voxl2-wlan/now 1.0-r0 arm64 [installed,local]
          We don't see any error messages from voxl-mapper.
          ERROR fetching tf from tf ringbuffer
          there wasn't sufficient data in the buffer
          This message shows up intermittently, but doesn't seems to effect in mapping function. Message below is the message after using Plan to a point feature.
          Client requested slice level update
          Client requested plan to location
          Using start pose of: x:  -0.08, y:   0.04, z:   0.02
          using goal pose of: x:  -1.04, y:   3.00, z:   0.02
          Map Bounds:
          Lower-> x: -6.40, y: -3.20, z: -3.20
          Upper-> x:  6.40, y:  6.40, z:  3.20
          Switching to 3D checks
          TIMING STATS
          Solve time             ->          1000.01ms
          Total time             ->          1000.04ms
          Random node grab time  -> Average:   0.00ms, TOT:  48.90ms
          Nearest node time      -> Average:   0.01ms, TOT: 508.83ms
          Check motion time      -> Average:   0.00ms, TOT: 354.81ms
          Neighborhood grab time -> Average:   0.00ms, TOT:   6.05ms
          Children update time   -> Average:    nanms, TOT:   0.00ms
          GENERAL STATS
          PATH LENGTH:   3.11
          ATTEMPTS: 42415
          QNEAREST FAILS: 59
          RANDOM TO NEAREST FAILS: 39915
          PARTIAL SEGMENTS ADDED: 2441
          TREE REWIRES: 0
          RRTSTAR FAILED: Exceeded max iterations. Outputting closest path
          Simplifying Path took:   0.07ms
          Removed 0 nodes
          Collisions along base path-> no
          No free constraints set in the vertices. Polynomial can not be optimized. Outputting fully constrained polynomial.
          Loco Smooth took: 467.29ms
          Success-> yes
          However, we found this error in voxl-portal. Would it be the reason of this problem? If so, how can we solve it?
          voxl2:/$ voxl-portal
          exising instance of voxl-portal found, attempting to stop it
          voxl-portal started up
          Server providing: battery connected
          Server providing: flight_info connected
          Server providing: gps connected
          Server not available
          Failed to open pipe: /run/mpa/plan_msgs/
          Server providing pose connected
          Server providing: costmap connected
          Server providing: mesh connected
          Server providing: plan connected
          Server providing: aligned ptcloud connected
          Thanks.
          • D
            darwin.keem
            Additionaly, the Follow Path button doesn't shows up on the GUI of voxl-portal.
              @darwin-keem,
              It looks like voxl-mapper failed to reach your goal point, resulting in it sending over the partial trajectory it solved for viewing but not giving you the option to follow the path. You can try giving the RRT solver another second or so by increasing the rrt_max_runtime_nanoseconds param, and it should be able to fully plan to your endpoint.
              The path generation code has been rewritten and thoroughly optimized in the latest dev package, so if you are still having issues with this planner it may be worth checking out some of the updates on our dev repo.
