    ERROR validating VIO data
    VOXL-CAM
    • A
      Anubhav
      When I am running command voxl-vixion-px4 -d, I am getting an error saying "ERROR validating VIO data received through pipe: read partial packet".
      Can you tell me how to resolve this error. Output is shown below.
      voxl:~$ voxl-vision-px4 -d
      detected platform APQ8096
      loading our own config file
      config file version:        1
      qgc_ip:                     192.168.1.27
      en_secondary_qgc:           0
      qgc_udp_port_number:        14550
      udp_mtu:                    512
      en_localhost_mavlink_udp    1
      en_vio:                     1
      en_voa:                     1
      en_send_vio_to_qgc:         1
      en_send_voa_to_qgc:         1
      voa_upper_bound_m:          -0.150000
      voa_lower_bound_m:          0.150000
      en_set_clock_from_gps:      1
      en_force_onboard_mav1_mode: 1
      en_reset_px4_on_error:      1
      qvio_auto_reset_quality:    0.000500
      horizon_cal_tolerance:      0.300000
      offboard_mode:              trajectory
      follow_tag_id:              0
      figure_eight_move_home:     1
      en_tag_fixed_frame:         0
      fixed_frame_filter_len:     5
      starting geometry module
      starting px4 monitor
      starting px4 mavlink
      from PX4 recv msgid:   1 sysid:  1 compid:  1
      Detected PX4 Mavlink SYSID 1
      starting udp mavlink
      Adding manual QGC IP address to udp connection list: 192.168.1.27
      Added new UDP connection to 192.168.1.27
      starting px4 shell
      starting fixed pose input
      starting vio manager
      Connected to voxl-qvio-server
      updating to use imu: imu1
      done updating transforms to use imu: imu1
      starting tag manager
      starting voa manager
      starting offboard trajectory
      Connected to TOF
      starting control input pipe
      from PX4 recv msgid: 141 sysid:  1 compid:  1
      read 156 bytes, but it should be a multiple of 324
      from PX4 recv msgid: 111 sysid:  1 compid:  1
      from PX4 recv msgid: 245 sysid:  1 compid:  1
      • modaltbM
        modaltb ModalAI Team
        Hi @Anubhav ,
        Can you please run voxl-version for us and paste here? Are you building code yourself or running the standard VOXL SDK?
        • A
          Anubhav
          Hi @modaltb,
          The output of voxl-version is shown below.
          voxl:~$ voxl-version
          system-image: 3.8.0
          kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
          hw version:   VOXL
          voxl-suite:   0.8.1
          0.7.0
          No, I am not building code myself, and running standard VOXL SDK. I have flashed new image of voxl because I was getting issue posted here. And the reason for choosing 3.8 system image was because of voxl-mavlink-server which is present in voxl-suite v0.7 and v0.8 and both requires voxl system image 3.8+.
