    uvc-camera rtsp
    VOXL
    552
    • 張
      張為超
      Hello 😊 ,
      I'm trying to use rtsp to stream a uvc camera. After I finish the connection(using fast boot module) and setting(using voxl-uvc-server and streamer), i get a stream from my computer like following:
      Screenshot 2022-08-25 18:07:55.png
      Here's my voxl-streamer.conf about uvc:
      "uvc-generic": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "uvc" },
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
                      "bitrate": 1000000 } }
      My camera is logitech C930c and Luminous C30 and both have similar image.
      Any suggestion is welcome, big thanks : )
      E 1 Reply Last reply 25 Aug 2022, 15:22 Reply Quote 0
      • E
        Eric Katzfey ModalAI Team @張為超
        @張為超 This looks like a mismatch in video format. There are some helpful debugging tips here: https://docs.modalai.com/voxl-uvc-server/#helpful-tips. Can you show the output when you run voxl-uvc-server -s and also voxl-uvc-server -d -v?
        • 張
          張為超
          Thanks for answering me.😊
          here's output for voxl-uvc-server -s :
          voxl:~$ voxl-uvc-server -s
          *** START DEVICE LIST ***
          Found device 1
          Got device descriptor for 046d:0891 E1127E0E
          Found device 046d:0891
          DEVICE CONFIGURATION (046d:0891/E1127E0E) ---
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	bEndpointAddress: 129
          	Formats:
          	UncompressedFormat(1)
          		  bits per pixel: 16
          		  GUID: 5955593200001000800000aa00389b71 (YUY2)
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  bit rate: 24576000-147456000
          			  max frame size: 614400
          			  default interval: 1/30
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(2)
          			  capabilities: 00
          			  bit rate: 1536000-9216000
          			  max frame size: 38400
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(3)
          			  capabilities: 00
          			  bit rate: 2027520-12165120
          			  max frame size: 50688
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(4)
          			  capabilities: 00
          			  bit rate: 4608000-27648000
          			  max frame size: 115200
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(5)
          			  capabilities: 00
          			  bit rate: 6144000-36864000
          			  max frame size: 153600
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(6)
          			  capabilities: 00
          			  bit rate: 8110080-48660480
          			  max frame size: 202752
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(7)
          			  capabilities: 00
          			  bit rate: 8140800-48844800
          			  max frame size: 203520
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(8)
          			  capabilities: 00
          			  bit rate: 10368000-62208000
          			  max frame size: 259200
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(9)
          			  capabilities: 00
          			  bit rate: 18432000-110592000
          			  max frame size: 460800
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(10)
          			  capabilities: 00
          			  bit rate: 28672000-172032000
          			  max frame size: 716800
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(11)
          			  capabilities: 00
          			  bit rate: 38400000-184320000
          			  max frame size: 960000
          			  default interval: 1/24
          			  interval[0]: 1/24
          			  interval[1]: 1/20
          			  interval[2]: 1/15
          			  interval[3]: 1/10
          			  interval[4]: 1/7
          			  interval[5]: 1/5
          			FrameDescriptor(12)
          			  capabilities: 00
          			  bit rate: 32563200-195379200
          			  max frame size: 814080
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(13)
          			  capabilities: 00
          			  bit rate: 41472000-124416000
          			  max frame size: 1036800
          			  default interval: 1/15
          			  interval[0]: 1/15
          			  interval[1]: 1/10
          			  interval[2]: 1/7
          			  interval[3]: 1/5
          			FrameDescriptor(14)
          			  capabilities: 00
          			  bit rate: 47185920-141557760
          			  max frame size: 1179648
          			  interval[0]: 1/15
          			  interval[1]: 1/10
          			  interval[2]: 1/7
          			  interval[3]: 1/5
          			FrameDescriptor(15)
          			  capabilities: 00
          			  bit rate: 73728000-147456000
          			  max frame size: 1843200
          			  default interval: 1/10
          			  interval[0]: 1/10
          			  interval[1]: 1/7
          			  interval[2]: 1/5
          			FrameDescriptor(16)
          			  capabilities: 00
          			  bit rate: 114688000-172032000
          			  max frame size: 2867200
          			  default interval: 1/7
          			  interval[0]: 1/7
          			  interval[1]: 1/5
          			FrameDescriptor(17)
          			  capabilities: 00
          			  bit rate: 165888000-165888000
          			  max frame size: 4147200
          			  default interval: 1/5
          			  interval[0]: 1/5
          			FrameDescriptor(18)
          			  capabilities: 00
          			  bit rate: 238878720-238878720
          			  max frame size: 5971968
          			  interval[0]: 1/2
          			FrameDescriptor(19)
          			  capabilities: 00
          			  bit rate: 283115520-283115520
          			  max frame size: 7077888
          			  interval[0]: 1/2
          	MJPEGFormat(2)
          		  bits per pixel: 0
          		  GUID: 4d4a5047000000000000000000000000 (MJPG)
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(11)
          			  capabilities: 00
          			  bit rate: 38400000-230400000
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(12)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(13)
          			  capabilities: 00
          			  bit rate: 41472000-248832000
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(14)
          			  capabilities: 00
          			  bit rate: 47185920-283115520
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(15)
          			  capabilities: 00
          			  bit rate: 73728000-442368000
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(16)
          			  capabilities: 00
          			  bit rate: 114688000-688128000
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(17)
          			  capabilities: 00
          			  bit rate: 165888000-995328000
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          END DEVICE CONFIGURATION
          *** END DEVICE LIST ***
          voxl-uvc-server -d -v :
          voxl:~$ voxl-uvc-server -d -v 046d
          Enabling debug messages
          voxl-uvc-server starting
          Vendor ID 0x046d chosen
          Image resolution 640x480, 30 fps chosen
          UVC initialized
          Device 046d:0000 found
          Device opened
          uvc_get_stream_ctrl_format_size succeeded for format 0
          Streaming starting
          Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
           * got image 30
           * got image 60
           * got image 90
           * got image 120
          I use gstream to watch rtsp from laptop by using:
          gst-launch-1.0 -v playbin uri=rtsp://192.168.8.1:8900/live uridecodebin0::source::latency=0
          Maybe here's the problem? But I also check VLC media player and got pretty much same image.
          E 1 Reply Last reply 26 Aug 2022, 16:23 Reply Quote 0
          • E
            @張為超 I don't see anything incorrect. Can you also show output when manually launching voxl-streamer with the -d option?
            張 1 Reply Last reply 29 Aug 2022, 02:29 Reply Quote 0
            • 張
              張為超 @Eric Katzfey
              @Eric-Katzfey hello,sorry for responding late.
              here's output for voxl-streamer -d :
              voxl:~$ voxl-streamer -d
              Using configuration file /etc/modalai/voxl-streamer.conf
              MPA interface chosen
              Input pipe name /run/mpa/uvc/
              Output stream width 640
              Output stream height 480
              Output stream bitrate 1000000
              Output stream rotation 0
              Output frame decimator 2
              No image overlay specified
              Camera server Connected
              Meta data from incoming frame:
              	magic_number 0x564F584C
              	timestamp_ns: 67575140926
              	frame_id: 720
              	width: 640
              	height: 480
              	size_bytes: 614400
              	stride: 1280
              	exposure_ns: 100
              	gain: 100
              	format: 8
              Input parameters initialized
              Made rtsp_server
              Created RTSP server main loop context
              Created RTSP server main loop source for callback
              Got 2 from gst_rtsp_server_attach
              Stream available at rtsp://127.0.0.1:8900/live
              A new client has connected to the RTSP server
              Creating media pipeline for RTSP client
              Made empty pipeline
              Made app_source
              Made parser_queue
              Made raw_video_parser
              Made scaler_queue
              Made scaler
              Made converter_queue
              Made video_converter
              Made rotator_queue
              Made video_rotate
              Made video_rotate_filter
              Made encoder_queue
              Made omx_encoder
              Made rtp_filter
              Made rtp_queue
              Made rtp_payload
              Made video_info
              Made video_caps
              E 1 Reply Last reply 29 Aug 2022, 15:22 Reply Quote 0
              • E
                @張為超 Everything still looks normal. We will order a couple of Logitech C930e and see if we can recreate your issue.
                張 2 Replies Last reply 30 Aug 2022, 02:02 Reply Quote 0
                • 張
                  張為超 @Eric Katzfey
                  • 張
                    張為超 @Eric Katzfey
                    @Eric-Katzfey Hey, I just update my voxl-platform from 3.6.0 to 3.8.0 and reinstall some package include uvc-server.
                    And I find out that the image become nice and clear. So I guess the problem is solved for me. Hope you guys still have time to refund C930e. Really big thanks for helping me to resolve problem. Cheers 😃
                    E 1 Reply Last reply 30 Aug 2022, 14:49 Reply Quote 0
                    • E
                      @張為超 Great, glad to hear it is working for you now!
                      1 out of 9
