Using another external Visual System for Localization
I have a VOXL m500 and I was trying to use an external visual system (i.e. mocap) for localization running with MAVROS.
Problem
In MAVROS, I can see the raw data of the sensor, but PX4 seems to not receive the data from it, (local_position_NED is 0).
Steps to reproduce
- I disabled VIO by setting
en_vioto false in the file/etc/modalai/voxl-vision-px4.conf. - Spin up a node for the external visual system that publishes to
vision/pose_cov - Run MAVROS
rostopic echo vision/pose_covgets the correct data from the localization sensor- In QGroundControl
local_position_nedis 0, not getting any data from the external visual localization system
Expected Behavior
QGroundControl is receiving the data from the external visual localization system.
Do you know how can I successfully integrate a visual system for localization in the VOXL?
Thank you in advance - I disabled VIO by setting
@vmassague Hi, I am pretty much doing the same thing and I faced a similar issue with you.
have you solved this issue?
https://forum.modalai.com/topic/919/using-motion-capture-systems-optitrack-for-position-estimation/2?_=1656684369036
