  2. VOXL SDK and Software
  3. Build voxl-uvc-server with voxl-cross
mpa
26 Posts 2 Posters 10.0k Views 1 Watching
  • Philemon BennerP Philemon Benner
    Ok so i finally got it working if someone ever needs it, with installing:
    sudo apt-get update
    sudo apt-get install libusb-1.0-0:arm64
    sudo apt-get install libjpeg-turbo8:arm64
    For other third part libraries add the :arm64 architecture when building with 820, because in voxl-cross it will install amd64 by default. Still wondering what 820 exactly is🤔
    Thanks @Eric-Katzfey for the suggestion on the 64-Bit deb package.
    @Philemon-Benner 820 refers to the Qualcomm Snapdragon 820 SoC that is the heart of the Voxl product. https://www.qualcomm.com/products/snapdragon-820-mobile-platform
    • Philemon BennerP Offline
      Philemon Benner
      wrote on last edited by Philemon Benner
      #18
      @Eric-Katzfey Ok i ran into the next problem when trying to run tflite-server.
      voxl:~/tflite-server(master)$ voxl-tflite-server -t -d
      voxl-tflite-server: error while loading shared libraries: libuvc.so.0: cannot open shared object file: No such file or directory
      Tried to install the 64-Bit BInary file but it's throwing the following error:
      voxl:~/tflite-server(master)$ opkg install libuvc_1.0.3.deb
      Collected errors:
       * pkg_extract_control_file_to_stream: Failed to extract control.tar.gz from package 'libuvc_1.0.3.deb'.
       * pkg_init_from_file: Failed to extract control file from libuvc_1.0.3.deb.
      So i tried using this from ur code:
      voxl:~/tflite-server(master)$ dpkg -i --force-downgrade --force-depends /data/libuvc_1.0.3.deb
      -bash: dpkg: command not found
      Normal installation from modalai dev branch still throws the same error after installation:
      opkg install libuvc
      Any suggestions?
        Collected errors:
        opkg install libuvc
        Any suggestions?
        @Philemon-Benner You can only install a Debian package with dpkg, which we have on our qrb5165 based platform, but not on our 820 based Voxl. That only has opkg and you need ipk packages, not debian packages.
        Philemon BennerP 2 Replies Last reply
          Philemon Benner
          #20
            Philemon Benner
            @Eric-Katzfey Ok so i got working now but i am having issues with the Format. So when using UVC Server i got the response that frame format succeed on index 2. In your voxl-uvc-server code at the Top Frame Format 2 should be:
            static enum uvc_frame_format supported_frame_format[NUM_SUPPORTED_FRAME_FORMATS] =
                 {UVC_FRAME_FORMAT_YUYV, UVC_FRAME_FORMAT_UYVY, UVC_FRAME_FORMAT_NV12};
            static int supported_mpa_frame_format[NUM_SUPPORTED_FRAME_FORMATS] =
                 {IMAGE_FORMAT_YUV422, IMAGE_FORMAT_YUV422_UYVY, IMAGE_FORMAT_NV12};
            supported mpa_frame_format = IMAGE_FORMAT_NV12 = 1 // regarding to https://gitlab.com/voxl-public/modal-pipe-architecture/libmodal_pipe/-/blob/master/library/include/modal_pipe_interfaces.h
            frame_format supported_frame_format = FRAME_FORMAT_NV12 = 17
            But still i am getting a real weird looking image(wrong colors) voxl-portal. Are the Configurations right that i use, or is it something else? Can't upload any pictures rn becuase of some server error.
              Philemon Benner
              Ok so apparrently the Frame format stuff is alright when directly writing the frame from the callback to the pipe server. I think it's some fault in the code. One Question why are you using c instead of c++? I'm not an expert at c/c++ stuff but i was told that c++ is generally faster than c.
                Philemon Benner
                #23
                Ok i got it working now.
                @Eric-Katzfey i don't know anything of the qrb thing but in the dev libuvc branch, if you build it in 64-Bit version, why is it then copied in the 32-Bit dir in your make_package.sh L:87-89:
                sudo mkdir -p $DATA_DIR/usr/lib
                sudo cp build/libuvc.so.0.0.6 $DATA_DIR/usr/lib
                sudo cp build/libuvc.a $DATA_DIR/usr/lib
                an if else would be nice.
                sudo mkdir -p $DATA_DIR/usr/lib64
                sudo cp build/libuvc.so.0.0.6 $DATA_DIR/usr/lib64
                sudo cp build/libuvc.a $DATA_DIR/usr/lib64
                also had to add:
                sudo cp /usr/lib/aarch64-linux-gnu/libjpeg.so.8 $DATA_DIR/usr/lib64
                sudo cp /usr/lib/aarch64-linux-gnu/libjpeg.so.8.1.2 $DATA_DIR/usr/lib64
                to make it work on voxl because voxl doesn't have it installed by default.
                  also had to add:
                  @Philemon-Benner I'm not sure where those lines of code came from. The file make_package.sh in the dev branch has this for lines 87-89:
                  	sudo cp $BUILD_TYPE/libuvc.so.0.0.6 $DATA_DIR/usr/lib
                  	sudo cp $BUILD_TYPE/libuvc.a $DATA_DIR/usr/lib
                  Where BUILD_TYPE will be either build32 or build64. It looks like you are taking from lines 65-66 on the master branch.
                  Philemon BennerP 1 Reply Last reply
                    Philemon Benner
                    @Eric-Katzfey yeah that was mb it's the one from the dev branch, but still even if i'ts 64-Bit, files are copied to 32-Bit lib:
                    instead of:
                    for 64-Bit. Correct me if i'm wrong.
                      instead of:
                      @Philemon-Benner Our qrb5165 based platforms put 64 bit libraries into /usr/lib. On Voxl the 64 bit libraries go into /usr/lib64. So the 64 bit support is specifically for our qrb5165 based platforms (e.g. RB5 Flight).
