VOXL TOF and Voxl portal
I am trying to use voxl-portal to see the images from the pmd tof sensor.
According tovoxl-versionI am running system image 3.2 with voxl-suite 3.4.I configured the cameras to use only the TOF on J3.
I can use
voxl-inspect-serviceand I can see that thevoxl-camera-serveris enabled and running.I managed to install
voxl-portalwith the followingppkg install voxl-portaland that seemed fine.So in the voxl I ran
voxl-portaland it started web server with the following.2022-03-10 04:03:31 2 mongoose.c:3317:mg_listen 1 accepting on http://0.0.0.0:80 (port 80)
So then I go to my web browser and I can see the voxl-portal site when I navigate to the site, and head to the drop down for cameras nothing pops up. And then on the voxl terminal it will just close. The voxl-portal web page just shows the green bar at the top and quits when clicking the drop down.
If I run the
voxl-inspect-camera tof_depththat seems to work fine? It outputs like the following.|size(bytes)| height | width |exposure(ms)| gain | frame id |latency(ms)|Framerate(hz)| format
| 154112 | 172 | 224 | 0.0 | 0 | 1118 | 36.5 | 29 | FLOAT32^CAm I missing something? I am also pasting the output of
journalctl -u voxl-camera-server.Jan 01 01:32:21 apq8096 systemd[1]: Started voxl-camera-server. Jan 01 01:32:27 apq8096 bash[2021]: ------ voxl-camera-server INFO: Port J2 Jan 01 01:32:27 apq8096 bash[2021]: Port : port_J2 Jan 01 01:32:27 apq8096 bash[2021]: Name : empty Jan 01 01:32:27 apq8096 bash[2021]: Enabled : 0 Jan 01 01:32:27 apq8096 bash[2021]: Type : Invalid Jan 01 01:32:27 apq8096 bash[2021]: ------ voxl-camera-server INFO: Port J3 Jan 01 01:32:27 apq8096 bash[2021]: ------ voxl-camera-server: Done configuring tof camera Jan 01 01:32:27 apq8096 bash[2021]: Port : port_J3 Jan 01 01:32:27 apq8096 bash[2021]: Name : tof Jan 01 01:32:27 apq8096 bash[2021]: Enabled : 1 Jan 01 01:32:27 apq8096 bash[2021]: Type : tof Jan 01 01:32:27 apq8096 bash[2021]: Api : hal3 Jan 01 01:32:27 apq8096 bash[2021]: P-W : 224 Jan 01 01:32:27 apq8096 bash[2021]: P-H : 1557 Jan 01 01:32:27 apq8096 bash[2021]: P-Fmt : blob Jan 01 01:32:27 apq8096 bash[2021]: Rotation : 0 Jan 01 01:32:27 apq8096 bash[2021]: FPS : 30 Jan 01 01:32:27 apq8096 bash[2021]: Tof Mode : 9 Jan 01 01:32:27 apq8096 bash[2021]: OverrideId : -1 Jan 01 01:32:27 apq8096 bash[2021]: AEAlgo : isp Jan 01 01:32:27 apq8096 bash[2021]: ------ voxl-camera-server INFO: Port J4 Jan 01 01:32:27 apq8096 bash[2021]: Port : port_J4 Jan 01 01:32:27 apq8096 bash[2021]: Name : empty Jan 01 01:32:27 apq8096 bash[2021]: Enabled : 0 Jan 01 01:32:27 apq8096 bash[2021]: Type : Invalid Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof_ir/ channel: 0 Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof_depth/ channel: 1 Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof_confidence/ channel: 2 Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof_noise/ channel: 3 Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof_pc/ channel: 4 Jan 01 01:32:27 apq8096 bash[2021]: Creating pipe: /run/mpa/tof/ channel: 5 Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, attempting again Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 8 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 7 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 6 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 5 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 4 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 3 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 2 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 1 attempts remaining Jan 01 01:32:27 apq8096 bash[2021]: ERROR: Camera module not opened, 0 attempts remaining Jan 01 01:32:46 apq8096 bash[2021]: ERROR: Camera module not opened after 10 attempts, aborting Jan 01 01:32:46 apq8096 bash[2021]: received SIGTERM Jan 01 01:32:46 apq8096 bash[2021]: ------ voxl-camera-server INFO: Camera server is now stopping Jan 01 01:32:46 apq8096 systemd[1]: Stopping voxl-camera-server... Jan 01 01:32:46 apq8096 bash[2021]: ------ voxl-camera-server INFO: Camera server exited gracefully Jan 01 01:32:46 apq8096 systemd[1]: Stopped voxl-camera-server. Jan 01 01:32:46 apq8096 systemd[1]: Started voxl-camera-server. Jan 01 01:32:47 apq8096 bash[3975]: ------ voxl-camera-server INFO: Port J2 Jan 01 01:32:47 apq8096 bash[3975]: Port : port_J2 Jan 01 01:32:47 apq8096 bash[3975]: Name : empty Jan 01 01:32:47 apq8096 bash[3975]: Enabled : 0 Jan 01 01:32:47 apq8096 bash[3975]: Type : Invalid Jan 01 01:32:47 apq8096 bash[3975]: ------ voxl-camera-server INFO: Port J3 Jan 01 01:32:47 apq8096 bash[3975]: ------ voxl-camera-server: Done configuring tof camera Jan 01 01:32:47 apq8096 bash[3975]: Port : port_J3 Jan 01 01:32:47 apq8096 bash[3975]: Name : tof Jan 01 01:32:47 apq8096 bash[3975]: Enabled : 1 Jan 01 01:32:47 apq8096 bash[3975]: Type : tof Jan 01 01:32:47 apq8096 bash[3975]: Api : hal3 Jan 01 01:32:47 apq8096 bash[3975]: P-W : 224 Jan 01 01:32:47 apq8096 bash[3975]: P-H : 1557 Jan 01 01:32:47 apq8096 bash[3975]: P-Fmt : blob Jan 01 01:32:47 apq8096 bash[3975]: Rotation : 0 Jan 01 01:32:47 apq8096 bash[3975]: FPS : 30 Jan 01 01:32:47 apq8096 bash[3975]: Tof Mode : 9 Jan 01 01:32:47 apq8096 bash[3975]: OverrideId : -1 Jan 01 01:32:47 apq8096 bash[3975]: AEAlgo : isp Jan 01 01:32:47 apq8096 bash[3975]: ------ voxl-camera-server INFO: Port J4 Jan 01 01:32:47 apq8096 bash[3975]: Port : port_J4 Jan 01 01:32:47 apq8096 bash[3975]: Name : empty Jan 01 01:32:47 apq8096 bash[3975]: Enabled : 0 Jan 01 01:32:47 apq8096 bash[3975]: Type : Invalid Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof_ir/ channel: 0 Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof_depth/ channel: 1 Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof_confidence/ channel: 2 Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof_noise/ channel: 3 Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof_pc/ channel: 4 Jan 01 01:32:47 apq8096 bash[3975]: Creating pipe: /run/mpa/tof/ channel: 5any help would be greatly appreciated
Check out the voxl-suite releases here: releases
It seems likely you need to update system image though. The latest published is 3.3
@Chad-Sweet Is the 3.3 version on the asset page? https://developer.modalai.com/asset
The latest one that I see is: modalai-3-2-0-0.3.4-b.tar.gz
Or does it go by a different name, such as VOXL Platform Release 3-3-0 0.5.0 a
Look for voxl_platform_3-3-0-0.5.0-a.tar.gz
@Chad-Sweet Thanks it works now.
