  2. FAQs
  3. Upgrade Tensorflow Version tflite-server
Scheduled Pinned Locked Moved Unsolved FAQs
38 Posts 3 Posters 15.0k Views 1 Watching
  • Philemon BennerP Philemon Benner
    @Matt-Turi I got it working with changing the apm. Thank you for the suggestion. So i looked up my Camera Supports and it should support nv12 and in voxl-uvc-server it shows the following:
    uvc_get_stream_ctrl_format_size succeeded for format 2
    after looking at the voxl-uvc-server:
    https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server/-/blob/dev/src/main.c
    L: 307 There is a for loop looking for a format to choose and format 2 should be NV12 but for some reason when looking at the stream over voxl-portal i get green stripes in the ouput. Do you know what the problem could be?
    The Camera is a Boson 640 Black-White Thermal Camera.
    @Philemon-Benner Can you post the output of lsusb, voxl-uvc-server -s, and voxl-uvc-server -d -m -r 640x512?
    • Philemon BennerP Offline
      Philemon Benner
      wrote on last edited by Philemon Benner
      #18
      lsusb:
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 002: ID 09cb:4007
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      voxl-uvc-server -s:
      *** START DEVICE LIST ***
      Found device 1
      Got device descriptor for 09cb:4007 134275
      Found device 09cb:4007
      DEVICE CONFIGURATION (09cb:4007/134275) ---
      Status: idle
      VideoControl:
      	bcdUVC: 0x0100
      VideoStreaming(1):
      	bEndpointAddress: 129
      	Formats:
      	UncompressedFormat(1)
      		  bits per pixel: 12
      		  GUID: 4934323000001000800000aa00389b71 (I420)
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 02
      			  bit rate: 10592000-235929600
      			  max frame size: 491520
      			  default interval: 1/60
      			  interval[0]: 1/60
      			  interval[1]: 1/30
      	UncompressedFormat(2)
      		  bits per pixel: 16
      		  GUID: 5931362000001000800000aa00389b71 (Y16 )
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 02
      			  bit rate: 10592000-629145600
      			  max frame size: 655360
      			  interval[0]: 1/60
      			  interval[1]: 1/30
      	UncompressedFormat(3)
      		  bits per pixel: 12
      		  GUID: 4e56313200001000800000aa00389b71 (NV12)
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 02
      			  interval[0]: 1/60
      			  interval[1]: 1/30
      	UncompressedFormat(4)
      		  bits per pixel: 12
      		  GUID: 4e56323100001000800000aa00389b71 (NV21)
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 02
      			  interval[0]: 1/60
      			  interval[1]: 1/30
      END DEVICE CONFIGURATION
      *** END DEVICE LIST ***
      voxl-uvc-server -d -m -r 640x512:
      Enabling debug messages
      Enabling MPA debug messages
      voxl-uvc-server starting
      Image resolution 640x512, 30 fps chosen
      UVC initialized
      Device found
      Device opened
      Streaming starting
      Got frame callback! frame_format = 17, width = 640, height = 512, length = 491520, ptr = (nil)
      making new fifo /run/mpa/uvc/voxl-tflite-server0
      opened new pipe for writing after 3 attempt(s)
      write to ch: 0 id: 0 result: 40 errno: 0
      previous client state was 1
      write to ch: 0 id: 0 result: 491520 errno: 0
      previous client state was 2
       * got image 30
        Philemon Benner
        #19
        Just checked the camera on my laptop. Camera it self is working fine
        It's also working fine with nv12 format without the green lines:
        ffplay /dev/video4 -pixel_format nv12
        Output:
        Input #0, video4linux2,v4l2, from '/dev/video4':B sq=    0B f=0/0
          Duration: N/A, start: 33575.082223, bitrate: 235929 kb/s
            Stream #0:0: Video: rawvideo (NV12 / 0x3231564E), nv12, 640x512, 235929 kb/s, 60 fps, 60 tbr, 1000k tbn, 1000k tbc
          lsusb:
          voxl-uvc-server -s:
          Found device 1
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	Formats:
          		  bits per pixel: 12
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 02
          			  interval[0]: 1/60
          			  interval[1]: 1/30
          		  bits per pixel: 16
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 02
          			  interval[0]: 1/60
          			  interval[1]: 1/30
          		  bits per pixel: 12
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 02
          			  interval[0]: 1/60
          			  interval[1]: 1/30
          		  bits per pixel: 12
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 02
          			  interval[0]: 1/60
          			  interval[1]: 1/30
          UVC initialized
          Device found
          Device opened
          Streaming starting
           * got image 30
          @Philemon-Benner It looks like voxl-uvc-server is working fine. The error messages seem to be related to voxl-tflite-server and not voxl-uvc-server. Can you use voxl-streamer to stream the output of voxl-uvc-server to VLC and see if there are still green lines? What are you currently using to stream the output of voxl-uvc-server?
          Philemon BennerP 2 Replies Last reply
            lsusb:
            voxl-uvc-server -s:
            Found device 1
            Status: idle
            VideoControl:
            	bcdUVC: 0x0100
            VideoStreaming(1):
            	Formats:
            		  bits per pixel: 12
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 02
            			  interval[0]: 1/60
            			  interval[1]: 1/30
            		  bits per pixel: 16
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 02
            			  interval[0]: 1/60
            			  interval[1]: 1/30
            		  bits per pixel: 12
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 02
            			  interval[0]: 1/60
            			  interval[1]: 1/30
            		  bits per pixel: 12
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 02
            			  interval[0]: 1/60
            			  interval[1]: 1/30
            UVC initialized
            Device found
            Device opened
            Streaming starting
             * got image 30
            @Philemon-Benner I'm guessing that there may be a version mismatch somewhere in there.
              Philemon Benner
              @Eric-Katzfey Yeah i will try that today. I'm currently showing the stream with voxl Portal but with the voxl-tflite-server pipe. So voxl-uvc-server --> voxl-tflite-server --> voxl-portal(green lines output).
              Philemon BennerP 1 Reply Last reply
                Philemon Benner
                #23
                @Eric-Katzfey what a exactly do you mean with version mismatch, and where. The thing i could think of is tflite server 0.2.0 as seen above in the first try of installation i had some errors because of existing dependencies.
                  Philemon Benner
                  @Eric-Katzfey Ok so i tried using it with voxl-streamer. It's working completely fine. Any suggestions?
                    Philemon Benner
                    I also tried changing the model but still the same result.
                      Philemon Benner
                      Update:
                      So i stepped back to TF1 and trained the ssdlite_mobilenet_v2. It's working great on the drone with tflite-server 0.1.8. Thanks for all the suggestions ·@Matt-Turi . But i am looking forward to using the tflite-server 0.2.0. If you still have suggestions for fixing the green stripes in the new version please let me know, because for custom models the new tflite-version is way easier to integrate and the code is more understandable for me.
                        Update:
                        @Philemon-Benner Thanks for the follow up on this! We'll take a look.
                          Philemon Benner
                          @Matt-Turi is there a way to change small stuff in tflite-server code without building from source? Or is there a way to do it over ssh?. I can't access the usb slot from the voxl of the drone. I just wanna change the box color and confidence threshhold.
                          • ? Offline
                            @Philemon-Benner If you make any changes to the code you will need to rebuild it from source. Once built, you can push this package over ssh either manually or using the deploy_to_voxl.sh script that is up on dev, which has an arg for ssh and send ip. Lines 106 and 107 of the script have the scp and opkg install commands that are used.
                            • ? A Former User
                              Philemon Benner
                              @Matt-Turi Thank you for the fast answer. Then i will build it from source. 🤔 But could be a cool feature in the future, if Box Color, Box Thickness and Confidence Threshhold would be in the config file.
                              • ? Offline
                                @Philemon-Benner great suggestion, I'll add that in soon. As for the green stripes issue seen with the dev version using a Flir Boson camera and voxl-uvc-server, I was able to successfully start and run tflite-server (mobilenetv2 w/gpu) with the same setup and only saw a few green "flickers" every few seconds due to the high input rate (60 fps) of the boson camera. I will work on some handling for this case, but have you tried your latest ssdlite_mobilenet_v2 model with the dev version of voxl-tflite-server (0.2.0)?
                                • ? A Former User
                                  Philemon Benner
                                  @Matt-Turi No i think because if you just update with opkg just the package is updatet and not the folders like the ones in /usr/bin/dnn where the models are stored. But yeah i will have a look at it. And also is the flickering happening on the in- or output? Because if it's happening in the input the inference results obviously will be less accurate, because of the green stripes.
                                  • ? Offline
                                    @Philemon-Benner when you update with opkg, all included files will also be updated including the /usr/bin/dnn/ directory. In regards to v0.2.0, I pushed up a patch yesterday that should fix the flickering (was only on output). As long as the skip_n_frames parameter is set to at least 1 with the boson camera (since it comes in at a fixed 60fps), you should be good to go!
                                    A note on inference with the Boson 640 Black-White Thermal Camera, I had some interesting results as the included mobilenet/most general models are not trained on thermal datasets, so keep that in mind when evaluating inference.
                                    • ? A Former User
                                      Philemon Benner
                                      @Matt-Turi yeah thanks for updating that i will definitely try it today. Yeah i know i already trained a complete dataset on thermal camera recordings and it's working like a charm. But really hot things are a source of false detection but i guess that just needs more training. Thank you for all the suggestions you made and for the fast response times. One last Question i'm really interested in how you made the boxes following so clean even with shakey Camera, as if we would inference every frame?
                                        Philemon Benner
                                        @Matt-Turi thanks for the update on the dev branch. It's now able to show the stream without any flickering. I also managed to add the conf_tresh and box_thickness to the config file and it works really nice.
                                          Philemon Benner
                                          @Matt-Turi is there a way that i can text you in private? I have a question and video material that i want to ask for but it shouldn't be publicly shown.
