    voxel-portal shared libraries error
    VOXL
    • Harel YadidH
      Harel Yadid
      Hi.
      I've been trying to calibrate my tracking camera with the voxel-calibration-camera in
      3.3 voxl version.
      The problem is i cannot see the front view of the camera, or any interface.
      I noticed there is voxl-portal , however when i try to run adb shell voxl-portal i receive the following message:
      voxl-portal: error while loading shared libraries: libmongoose.so: cannot open shared object file: No such file or directory
      I tried to create a voxl-portal pkg manually but there are missing third party repos such as mongoose and jpeg-turbo, and I am having difficulties trying to merge them or even build them according to the voxel gitlab (the mongoose holds jpeg-turbo README, and i also couldn't found submodules in the voxel-portal as mentioned ).
      any help?
      if there is a way to push in the libmongoose.so, I would like to know how to do it,
      but if there is a global solution, I would prefer that.
      Thanks in advance
      • Chad SweetC
        Chad Sweet ModalAI Team
        Can you update the entire voxl-suite? It is going to be difficult to pick and choose different versions of software. The latest voxl-suite will have all the tools you need
          This is an issue we are aware of and is due to the renaming of all packages using an underscore(replaced with a dash). To properly install packages that depend on the updated names, you can run this command to remove all affected packages with the added --force-depends flag:
           opkg remove libmodal_json libmodal_pipe libvoxl_cutils libjpeg_turbo --force-depends
          This should forcefully remove all these packages, and if you attempt to install voxl-portal again after running this, it will install the latest dependencies without conflict.
          The same command will fix any updated packages complaining about  "check_data_file_clashes:" with regards to one of the packages in the remove command above, and only needs to be done once.
          • Harel YadidH
            Harel Yadid
            Thanks for the answer, I found another solution as well that worked for me.
            It is probably more intuitive for experts, but i noticed that in the third party from your git you should also imply git submodule init and git submodule update .
            After doing that, the old instructions worked semi-properly, and I could reinstall the voxl-portal package with not farther problems. It's just the README files that were not so obvious in explaining so.
