  3. Trying to make my own custom tflite model for voxl-tflite-server
8 Posts 2 Posters 2.0k Views
  • Steve AriasS Offline
    Steve Arias
    I made a virtualenv environment which has Python3.7 and Tensorflow (version 2.2.3). I am trying to convert the faster_rcnn_resnet101_coco model (labelled as "faster_rcnn_resnet101_coco" in https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/tf1_detection_zoo.md) to a tflite model so that I can put it on the board and run via voxl-tflite-server. I have read the documentation on the voxl-tflite-server. I understand that quantization will allow GPU support for the model. Here's what my conversion code looks like so far:
      converter =  tf.compat.v1.lite.TFLiteConverter.from_frozen_graph(
        graph_def_file = 'faster_rcnn_resnet101_coco_2018_01_28/frozen_inference_graph.pb',
        input_arrays = ['normalized_input_image_tensor'],
        input_shapes={'normalized_input_image_tensor': [1,300,300,3]},
        output_arrays = ['TFLite_Detection_PostProcess', 'TFLite_Detection_PostProcess:1', 'TFLite_Detection_PostProcess:2', 'TFLite_Detection_PostProcess:3']
      converter.use_experimental_new_converter = True
      converter.allow_custom_ops = True
      converter.target_spec.supported_types = [tf.float16]
      tflite_model = converter.convert()
      # Save the model.
      with open('custom_model.tflite', 'wb') as f:
        f.write(tflite_model)
    I get the following output:
    (tflite_env) stevearias@Steves-Macbook-Pro tflite_env % python3 convert_to_tflite_model.py
    2022-02-12 19:48:02.033093: I tensorflow/core/platform/cpu_feature_guard.cc:143] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
    2022-02-12 19:48:02.071654: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f925aaec760 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
    2022-02-12 19:48:02.071679: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Host, Default Version
    Traceback (most recent call last):
      File "convert_to_tflite_model.py", line 22, in <module>
        main()
      File "convert_to_tflite_model.py", line 8, in main
      File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/python/lite.py", line 780, in from_frozen_graph
        sess.graph, input_arrays)
      File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/python/util.py", line 128, in get_tensors_from_tensor_names
        ",".join(invalid_tensors)))
    ValueError: Invalid tensors 'normalized_input_image_tensor' were found.
    Did you encounter this error when trying to convert the ssdlite_mobilenet_v2_coco model to a tflite model?
    • ? Offline
      Hey @Steve-Arias,
      the input + output tensor names may change per model. Opening up the saved_model.pb from faster_rcnn_resnet101_coco in netron shows that the input tensor for this graph is just titled "image_tensor". If you would rather do this programmatically, this stack overflow post shows how to parse out tensor names:
      https://stackoverflow.com/questions/52918051/how-to-convert-pb-to-tflite-format.
      Netron link: https://github.com/lutzroeder/netron
      Steve AriasS 1 Reply Last reply
      • ? A Former User
        Hey @Steve-Arias,
        Steve Arias
        wrote on last edited by Steve Arias
        @Matt-Turi Yep, looks like 'image_tensor' and 'detection_classes' are the input and outputs names, respectively.
            input_arrays = ['image_tensor'],
            input_shapes={'image_tensor': [1,300,300,3]},
            output_arrays = ['detection_classes']
          # Save the model.
        When I run the code now, I get the following:
        2022-02-14 14:41:58.792670: I tensorflow/core/platform/cpu_feature_guard.cc:143] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
        2022-02-14 14:41:58.827082: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f9606206700 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
        2022-02-14 14:41:58.827104: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Host, Default Version
            main()
          File "convert_to_tflite_model.py", line 14, in main
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/python/lite.py", line 1084, in convert
            **converter_kwargs)
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/python/convert.py", line 496, in toco_convert_impl
            enable_mlir_converter=enable_mlir_converter)
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/python/convert.py", line 227, in toco_convert_protos
            raise ConverterError("See console for info.\n%s\n%s\n" % (stdout, stderr))
        tensorflow.lite.python.convert.ConverterError: See console for info.
        2022-02-14 14:42:07.697347: W tensorflow/compiler/mlir/lite/python/graphdef_to_tfl_flatbuffer.cc:144] Ignored output_format.
        2022-02-14 14:42:07.697406: W tensorflow/compiler/mlir/lite/python/graphdef_to_tfl_flatbuffer.cc:147] Ignored drop_control_dependency.
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/bin/toco_from_protos", line 8, in <module>
            sys.exit(main())
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/toco/python/toco_from_protos.py", line 93, in main
            app.run(main=execute, argv=[sys.argv[0]] + unparsed)
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/python/platform/app.py", line 40, in run
            _run(main=main, argv=argv, flags_parser=_parse_flags_tolerate_undef)
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/absl/app.py", line 312, in run
            _run_main(main, args)
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/absl/app.py", line 258, in _run_main
            sys.exit(main(argv))
          File "/Users/stevearias/Documents/src/ece-498-repo/python-scripts/tflite_env/tflite_env/lib/python3.7/site-packages/tensorflow/lite/toco/python/toco_from_protos.py", line 56, in execute
        Exception: Merge of two inputs that differ on more than one predicate {s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater:0,else), s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/cond/cond/pred_id/_564__cf__570:0,then), s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/cond/Greater/_563__cf__569:0,then)} and {s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Greater:0,else), s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/cond/cond/pred_id/_564__cf__570:0,else), s(SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/cond/Greater/_563__cf__569:0,else)}
        	for node {{node SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/cond/cond/Merge}}
        Any idea on what the issue is?
        • ? Offline
          @Steve-Arias said in Trying to make my own custom tflite model for voxl-tflite-server:
          Sorry for the confusion on this, the tensorflow docs / resources on proper model conversion are a bit sparse. However, as per this link https://github.com/tensorflow/tensorflow/issues/40059, it seems that may be an issue exclusive to tensorflow 2.2. Since these models were trained in a tf1 environment, it should be safe to attempt the conversion with a different, more current release that should fix these bugs. Let me try to convert this graph on my end now and see if I can solve these issues with just a fresher tf version.
          • ? Offline
            Update: did some digging and was able to reproduce the error in tf1/tf2 with no fix in any versions. For this model architecture in particular, there does not seem to be much support for the "lite" or mobile version of the operations implemented. That said, it would require a full retraining with some modifications to the pipeline.config file in order to utilize, see some good info here: https://github.com/tensorflow/tensorflow/issues/37401.
            However, in this post they claim that the tf2 versions (https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/tf2_detection_zoo.md) of these models should fix these issues, specifically the ssd versions like SSD ResNet101 V1 FPN 640x640 (RetinaNet101), and can be converted following this guide. I will validate this process now and get back to you.
            • ? A Former User
              Steve Arias
              @Matt-Turi Any update?
              • ? Offline
                I was unable properly convert the resnet tf2 architecture on my end. It may be worth attempting the tf1 model conversion with tensorflow v1.12.0 as that was what they used for creation, but it would be much easier to use a model that has clearer support. Is there any particular reason you want to use the resnet architecture over something like mobilenet/mobiledet?
                • ? A Former User
                  Steve Arias
                  @Matt-Turi I wanted to try the resnet architecture as the accuracy/speed ratio is a bit better than the mobilenet architecture. But it's not a hard requirement, so I'll just use the mobilenet architectures. Thanks!
