  3. In VOXL Board: what is user application mamory size allowed?
2 Posts 2 Posters 362 Views 1 Watching
  • shaul KutnerS Offline
    shaul Kutner
    User Application memory size
    • shaul KutnerS shaul Kutner
      @shaul-Kutner I'm not sure I understand your question. The Voxl application processor is running Linux which is a virtual memory system so applications have nearly unlimited memory to use. In terms of non-volatile storage you can see the partitions with the Linux df command:
      / # df -h
      Filesystem      Size  Used Avail Use% Mounted on
      /dev/root       2.8G  1.9G  906M  68% /
      devtmpfs        1.8G     0  1.8G   0% /dev
      tmpfs           1.9G     0  1.9G   0% /dev/shm
      tmpfs           1.9G  8.8M  1.9G   1% /run
      tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
      tmpfs           1.9G  4.0K  1.9G   1% /var/volatile
      /dev/sda2       2.2M   80K  2.0M   4% /persist
      /dev/sda3        58M   40K   57M   1% /cache
      /dev/sde12       12M  4.1M  7.4M  36% /dsp
      /dev/sde11       95M   33M   63M  35% /firmware
      /dev/mmcblk0p1   15G  5.6G  8.3G  41% /mnt/sdcard
      /dev/sda9        15G  138M   14G   1% /data
      And for RAM you can check out the Linux /proc/meminfo file:
      MemTotal:        3861320 kB
      MemFree:         3144828 kB
      MemAvailable:    3377772 kB
      Buffers:           18844 kB
      Cached:           229416 kB
      SwapCached:            0 kB
      Active:           246908 kB
      Inactive:         212448 kB
      Active(anon):     211300 kB
      Inactive(anon):    16984 kB
      Active(file):      35608 kB
      Inactive(file):   195464 kB
      Unevictable:           0 kB
      Mlocked:               0 kB
      SwapTotal:             0 kB
      SwapFree:              0 kB
      Dirty:                 0 kB
      Writeback:             0 kB
      AnonPages:        211144 kB
      Mapped:            50512 kB
      Shmem:             17196 kB
      Slab:              87524 kB
      SReclaimable:      31308 kB
      SUnreclaim:        56216 kB
      KernelStack:        9744 kB
      PageTables:         2624 kB
      NFS_Unstable:          0 kB
      Bounce:                0 kB
      WritebackTmp:          0 kB
      CommitLimit:     1930660 kB
      Committed_AS:    2012136 kB
      VmallocTotal:   258998208 kB
      VmallocUsed:       68020 kB
      VmallocChunk:   258812108 kB
